battens
Posted by billpeggyweber (billpeggyweber@…>)
What type of knot are you guy’s using to tie in your sail battens???
Having just bent on my main I can tell you that I go back and forth a couple of times making sure I don’t over-tighten (easy to do and you will know it if your battens don’t lie pretty flat when the sail is on the boom). I finish up with a reef knot or two.
Sean Mulligan Emmylou #307— On Thu, 5/8/08, billpeggyweber <billpeggyweber@…> wrote:
From: billpeggyweber <billpeggyweber@…>Subject: [freedom21] battensTo: freedom21@yahoogroups.comDate: Thursday, May 8, 2008, 9:15 PM
