Beautiful weekend on Boston Harbor
Posted by svfantasy@… (svfantasy@…)
Thanks Herman, that pretty much explains all the confusion.
Jay
----- Original Message -----From: “Herman Schiller” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Beautiful weekend on Boston HarborDate: Fri, 15 Sep 2006 01:27:03 -0000
After reading the whole discussion about Freedom 40 centerboards, I referred to my collection of (near) ancient F-40 brochures. There may be an explanation for the contrasting opinions expressed. One of the brochures talks of 6000 pound internal lead ballast and a plastic centerboard, and another talks of 4000 pound internal ballast and a 2000 pound cast iron and epoxy centerboard. There are no indications of the age of these brochure items; no copyright notice. Possibly there were two flavors of this boat and centerboard, which would explain why some of you are having trouble grunting the things upward.Herm S.V. Impulse— In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:>> Lance/Norm,> > I own an F-40 CK 1981, hull # 60, My centerboard winch is an Barient> 27-48 (self-tailing) mounted just port of the companionway hatch. I have> 1/2 " double braid line running from the winch to the thimble on the> centerboard. I had the yard replace it when I purchased the boat two> years ago. It just takes a few turns to raise the board, and its fairly> easy. Just to clarify, the board on the F-40 is weighted significantly.> I’ve been trying to determine the weight of the board,however, I’ve not> been successful in finding this info. While hauled out, it is obvious the> board weighs in excess of 500 lbs, and the construction is cast iron with> glass over, at least that is what I was told.> > Jay> > “Fantasy” F40 CK> > San Francisco Bay> > ----- Original Message -----> From: “Norm Friberg”> To: freedomyachts2003@yahoogroups.com> Subject: Re: [freedomyachts2003] Re: Beautiful weekend on Boston> Harbor> Date: Thu, 14 Sep 2006 07:12:57 -0400> > Lance, Yes, I’m interested in seeing your system, and also how your> dodger is set up. Many Thanks,Norm> > ----- Original Message ----- From: lance_ryleyTo:> freedomyachts2003@…: Wednesday, September 13,> 2006 4:36 PMSubject: [freedomyachts2003] Re: Beautiful weekend on> Boston Harbor> > Norm,> if you’re interested, I’ll take some pictures of my arrangement,> which seems entirely different from yours, also from a Freedom 40> CK.> > In the case of Bright Star, the centerboard winch is mounted next> to> the companionway where you can get at it from the cockpit. Our> pennant is cord all the way to the board, but is spliced into> nylon> webbing that actually wraps around the winch. we use a> short-handled> winch handle (so it doesn’t smack the dodger plexiglass), and I> can’t say I’ve ever had a problem getting the centerboard up.> > I may be wrong, but I believe that the centerboard in the 40 is> pretty much neutral buoyancy, as opposed to the 33/35, where they> put some ballast in its construction.> > If you’d like to see the layout, let me know and I’ll send some> pictures along.> > Lance> Bright Star> > — In freedomyachts2003@yahoogroups.com, Norm Friberg> <nfriberg@> wrote:> >> > Michel,> >> > The knob attachment might be a good idea. I am also looking> into> the idea of the right-angle electric drill with the winch bit. I> have to take some measurements to see if it will fit. Maybe the> thinner line would also help. The position of the winch is> forward> of the mizzen, but it is up higher so you can be sitting of> nealing> on the forward cockpit seat (bridge deck?). Not so uncomfortable.> >> > The extra block purchase is also a good idea if I can work out> how> to do it. Thanks for the ideas.> >> > Norm> >> > ----- Original Message -----> > From: michel.capel> > To: freedomyachts2003@yahoogroups.com> > Sent: Wednesday, September 13, 2006 10:31 AM> > Subject: [freedomyachts2003] Re: Beautiful weekend on Boston> Harbor> >> >> > Norm,> > If I understand you, your CB winch is forward of the mizzen??> so> you> > have to crouch on deck to manhandle it? Not an easy task, with> this> > funky T-ford steering wheel! Perhaps if you mount a handhold on> the> > wheel, like they have on tractors, that would help a bit> swirling> > the wheel around.> >> > I replaced the pennant on my F33/35 a few years ago with 5 mm> > Dyneema line in stead of the line+wire combination. It made the> > board a lot easier to lift.> >> > A few years before that, I put in some extra blocks to increase> the> > purchase on the CB. I had to do 80 turns to fully lift the 450> kg> > of the CB. Still a bear, but good for the biceps. It also> convinced> > me to finally quit smoking.> >> > Michel> >> > — In freedomyachts2003@yahoogroups.com, Norm Friberg> > <nfriberg@> wrote:> > >> > > Lance,> > >> > > It’s an old bronze winch mounted horizontally. I think you> would> > call it reversable. Clockwise is always up, counterclockwise is> > always down, and there is a ratcheting brake mechanism. Since> the> > winch is only a few inches forward of the mizzen mast, a normal> > winch handle won’t fit. There is a circular handle that> actually> > looks like the steering wheel off an old car, but isn’t. Only> about> > 25 turns gets the board from full up to full down. A longer> lever> > arm (winch handle) would be nice but there is little room. The> > original pendant (pennant?) had a wire section spliced into the> > winch end and was attached to the winch drum by a set screw. As> I> > didn’t have a spliced-wire option at the time, my new pennant> is> > held onto the drum by friction- ie. it’s wrapped around itself.> I> > added five feet of line to make sure it wouldn’t slip.> > >> > > The new pennant (pendant?) hasn’t made lifting the board any> > easier, which leads me to wonder about the condition of the> > centerboard hinge. I have not yet figured out how to access> this> > for checking. During my amateur diving under the boat, the> block> > that the pennant (I give up) runs through seemed to be in good> shape> > and turned easliy.> > >> > > Reading Garry Hoyt’s book about how sailing should be easier> leads> > me to wonder what he was smoking when he came up with this> > arrangement. Nevertheless, it’s only a minor inconvenience. I> love> > my boat anyway.> > >> > > Best regards,> > > Norm Friberg> > >> > > ----- Original Message -----> > > From: lance_ryley> > > To: freedomyachts2003@yahoogroups.com> > > Sent: Wednesday, September 13, 2006 7:58 AM> > > Subject: [freedomyachts2003] Re: Beautiful weekend on Boston> > Harbor> > >> > >> > > Norm,> > > has it gotten easier to raise the centerboard since you> replaced> > the> > > pennant? Also, what kind of lifting arrangement do you have?> > Bright> > > Star has a reversible winch (I think it was a halyard winch> from> > an> > > Atlantic at one time) and I’ve never had a problem lifting> the> > > board, even when under sail.> > >> > > Just curious to hear what may be happening with yours…> > >> > > Lance> > >> > > — In freedomyachts2003@yahoogroups.com, Norm Friberg> > > <nfriberg@> wrote:> > > >> > > > This discussion is very interesting, guys. First, let me> say> > that> > > I had a delightful day holding my breath underwater in an> oily> > > marina replacing the center board pendant on my F40CK a few> > weeks> > > ago. What fun! At least the section of the hull that my body> > > rubbed against is now clean.> > > >> > > > Regarding the use of the centerboard (is it one word or> two?)> > I> > > have found in the first few months of sailing her that the> board> > > does affect heeling angle and maneuvering ability; she heels> > less> > > and turns more readily with the board down. However, having> said> > > that, don’t try motoring into the marina at low tide with the> > board> > > still down. My poor little diesel was cranking its> 28-year-old> > > heart out, but the brakes were ON. And what a bear cranking> that> > > board back up!> > > >> > > > I have also been relieved, and even favorably impressed, at> > the> > > pointing ability of the boat, after hearing, on this news> board> > and> > > elsewhere, that Freedom Cat-Ketches don’t sail to windward.> My> > > experience on Long Island Sound this past summer is that,> given> > at> > > least 10 knots of wind, she will tack in about 100 degrees,> that> > is,> > > 50 degrees to either side of the wind. While not exactly> > Americas> > > Cup standards, perfectly adequate for my needs. She sure> takes> > her> > > time coming about, however. A real “gentleman’s tack” as my> > friend> > > put it.> > > >> > > > Regards to all,> > > > Norm Friberg> > > > SV Freyja> > > >> > >> >>
Back to F33/35 centreboards: does anyone know how to get at the pivot at the
forward
end, please? There are some bolts through the casing side, but above the pivot
point, and
they are obviously not the pivot itself. Do they hold the bearings for the pivot
in place?
Can the board be lowered out of the casing? I get some thumping from the casing
when
the boat is in a rough beam sea, especially on starboard tack, but this is
probably due to
damage to the chock which locates the aft edge of the board when it is fully
down. That
can be replaced, but it would help my peace of mind to inspect the bearing as
well.
All advice gratefully received, (and any action my responsibility).
I am told our C/B is lead in GRP, but so far haven’t made deep enough cracks in
it to
check: we try not to hit any rocks with anything more than minimum steerage way
on! It
certainly seems to weight the half ton quoted, but we cheat and use a Lewmar
electric
winch when we are tired. The pennant is just 10mm (3/8") pre-stretched
polyester, last
replaced 5 years ago. I’ll try Spectra next time.
Gerald Freshwater,
Castaway
Lerwick
Jay
freedomyachts2003@yahoogroups.com, svfantasy@ wrote:
Lance/Norm,
Barient
I have
two
fairly
significantly.
I’ve not
obvious the
iron with
Jay
“Fantasy” F40 CK
San Francisco Bay
Harbor
your
freedomyachts2003@: Wednesday, September 13,
on
Boston Harbor
Norm,
arrangement,
40
CK.
next
to
nylon
short-handled
they
pictures along.
Lance
Bright Star
<nfriberg@> wrote:
Michel,
into
I
forward
nealing
uncomfortable.
out
how
Norm
Harbor
Norm,
so
you
with
this
on
swirling
the wheel around.
increase
450
kg
convinced
<nfriberg@> wrote:
Lance,
would
is
normal
actually
about
lever
The
As
I
is
itself.
I
any
this
block
good
shape
and turned easliy.
easier
leads
love
my boat anyway.
Best regards,
Norm Friberg
Boston
Harbor
Norm,
replaced
have?
Bright
from
an
Lance
say
that
oily
weeks
body
two?)
I
board
heels
less
board
28-year-old
that
board back up!
at
board
My
given
at
that
is,
Americas
takes
her
friend
put it.
Regards to all,
Norm Friberg
SV Freyja
