Posted by esx123 (scott_shuler@…>)
Anyone have one? Stock? Special order? Specs?Laissez les bons temps rouler
Blab-away for as little as 1¢/min. Make PC-to-Phone Calls using Yahoo! Messenger with Voice.
Posted by chris montgomery (freedom.sailingguy@…>)
Scott–I’ve been researching the idea of a bimini for a couple of
months now. The problems with the stock off the shelf units are: 1.
they come stock with aluminum frames and are a bit fragile (imagine a
guest boarding and grabbing the frame for balance)2. They are made to
fit a range and adjustments and slides compromise unit strength.
The problem with a custom bimini is that they are quite expensive
(estimates range from $700-$1000) This compares to about $500 for the
off the shelf offerings with the stainless upgrade. Custom is
definately the best choice if you can afford it. I’ve been looking
at the Mantis, a portable unit made by Pro-techt. The reviews that
I’ve seen are pretty good except that in winds over 20 knots one
needs to fold the unit up. The mantis costs about $250 in sunbrella
fabric and with the mounting hardware. I’m about 90 percent sure
that I’m going to give this gadget a try. If I do, I’ll post a
message on this site giving a review. You can check the unit for
yourself on line at Pro-techt.com. Let me know if you have any other
info about biminis.–Thanks–Chris
I have a custom bimini(came with the boat) it’s nice when docked. I can’t see trying to sail with it up. You can’t see anything. As far as the wind with it up it could make docking difficult.chris montgomery <freedom.sailingguy@…> wrote: —Scott–I’ve been researching the idea of a bimini for a couple of months now. The problems with the stock off the shelf units are: 1. they come stock with aluminum frames and are a bit fragile (imagine a guest boarding and grabbing the frame for balance)2. They are made to fit a range and adjustments and slides compromise unit strength.The problem with a custom bimini is that they are quite expensive (estimates range from $700-$1000) This compares to about $500 for the off the shelf offerings with the stainless upgrade. Custom is
definately the best choice if you can afford it. I’ve been looking at the Mantis, a portable unit made by Pro-techt. The reviews that I’ve seen are pretty good except that in winds over 20 knots one needs to fold the unit up. The mantis costs about $250 in sunbrella fabric and with the mounting hardware. I’m about 90 percent sure that I’m going to give this gadget a try. If I do, I’ll post a message on this site giving a review. You can check the unit for yourself on line at Pro-techt.com. Let me know if you have any other info about biminis.–Thanks–ChrisIn freedom21@yahoogroups.com, esx123 <scott_shuler@…> wrote:>> Anyone have one? Stock? Special order? Specs?> > > Laissez les bons temps rouler> > ---------------------------------> Blab-away for as little as 1¢/min.
Make PC-to-Phone Calls using Yahoo! Messenger with Voice.> __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Agree. Bimini/sun shade is impractical underway (big Tilley or
Ultimate hat is good…) At dock I have rigged a sun shade made from
a cast-off blue solumbra square (it was a bimini designed to zip to
a dodger and tie off to a backstay) about the same size as the
cockpit. It took a bit to figure out how to use it on the 21. Here’s
what I did:
I cut a hole in the center of the material and passed the main
halyard thru it to the end of the boom. I have an old telescoping
reaching pole that I pass through the loop around the boom of reef1
and clip to the aft lower padeye (mainsheet attachment point) on the
boom. Then I raise the main halyard (and hence boom/extension pole
to a comfortable height. The pole holds out the aft end of the
material, where a pole sewn into a pocket has lines running almost
directly down to the 2 aft cleats. The forward end of the material
has a pole lashed on (remember, this end is above the boom) and
lines at either end run down into the cam cleats for the staysail.
Very strong and adjustable. I will take some photos and post
sometime. Oh, and the nice thing is the whole thing (material with 2
attached poles plus free reaching pole) rolls up compactly and
stores right above our oars on the port side stuck back behind
the “fuel locker.”
Sean Mulligan
— In freedom21@yahoogroups.com, bill weber <billpeggyweber@…>
(imagine a
to
looking
that
sunbrella
other
In freedom21@yahoogroups.com, esx123 <scott_shuler@> wrote:Anyone have one? Stock? Special order? Specs?
Yahoo! Messenger with Voice.SPONSORED LINKS
Freedom Sailing Boating Sailboat Boating
magazine Boating safety
YAHOO! GROUPS LINKS
Visit your group "freedom21" on the web. To unsubscribe from this group, send an email to:freedom21-unsubscribe@yahoogroups.com
Service.
Do You Yahoo!?
Do You Yahoo!?
