hehehe
For all budget and/or cost-conscious sailors out there!
I’m installing solar panes on the coach roof. This means I have to redirect the lines coming for the main mast; 6 of them (as a minimum).
Looked at different options, but when I calculated the budget for each I nearly had a heart attack!! In blocks alone to accommodate 12 mm lines (need 3 blocks per line X 6 lines), it was almost GBP 1000!!
So… came up with the design below. All components sourced on eBay. I’ll provide the links below.
#1 shacke, 316 SS, 8 mm dia pin - GBP 1.90 per unit
#2 ball bearings; 22 od X 8 id X 7mm wide - SS 316 with ceramic balls - GBP 2.29 per unit - Used for many things, but mostly for roller skaters…
#2 SS 316 washers, 8mm ID - GBP 6.20 for a bag of 100 = 6.2 pence per unit
#1 SS (I don’t know the grade) 10 mm cable tie - which I had already, so not tallying…
… oh… and my labour… a couple of hours of creative design, 3 hours overall of material procurement on the computer (with leadtimes ranging from 48 hours to 2 weeks), and 8.5 mins of assembly per unit. Total cost per unit: GBP 4.25. Built 20 to have two extra/spare, so total cost of blocks reduced from just below GBP 1000, to 85 quid…
Now, as to fitness for purpose:
Pros:
- small(ish)… certainly compared to the 12 mm block commercially available.
- can accommodate lines up to 14 mm dia
- Negligible friction/resistance
- Cero maintenance - if salt cristals get inside the bearings, wash with freshwater
- Operational ratings - Ball bearings rated to 90 kg by manufacturer - more than enough for my purposes
- in case of breakage/malfunction, 16 mins to disassemble. replace, and reassemble, plus one allen key - only tool required
- they don’t look too bad either
Cons:
- can’t think of one, really…
Eat your heart out Harken!!!
Rafa
