Bypass valve question
Brian:
Thanks for your explanation. It’s what I almost designed for my F33,
except the cylinder is not connected to a quadrant (we don’t have
one) but in parallel to the steel rod that connects steering column
and rudder arm.
What I still like to know: how do you operate your bypass valve is
you disengage your autopilot? I suppose it’s electrically operated,
and perhaps automatically operated by your autopilot? Or do you have
a pump with integrated bypass valve?
Cheers,
mike
— In freedomyachts2003@yahoogroups.com, “Brian Guptil”
<sailordude@b…> wrote:
Mike:
I have a stock cable,pulley,quadrant system with the quadrant
mounted in a recess in the cockpit floor, exposed to weather and sea
from backwash up the cockpit drains. The cylinder attaches to the
(stock) quadrant and has a by-pass (normally open) valve across the
lines form the pump. The pump and by-pass valve are below decks.
The added drag on the steering is not as bad as I had expected and if
needed, I can disconnect the cylinder from the quadrant though that
has not been necessary. There are lots of cylinders out there,
stainless, bronze and other. Often they are exposed to rather harsh
environment of dirt, mud and otherwise.
So I end up with combined standard cable and a mostly independent
hydraulic, sharing only the quadrant on the way to the rudder. So
far the cylinder is weathering just fine. I do rinse the cylinder
with fresh water when available.
I can take a photo and send it directly to you if you wish.
Brian Guptil http://www.brigup.com
206-818-3203 sailordude@b…
1735 112th Ave. N.E.
Bellevue, WA. 98004-3706
Sent: Friday, August 27, 2004 9:14 AM
Subject: [freedomyachts2003] Re: F-33 has an outboard rudder post
Brian,
Question to you:
How do you combine mechanical steering and a hydraulic autopilot?
Or
do you have hydraulic steering on you F44? In that case it’s easy
to
combine the two (steering and autopilot on one hydraulic cylinder.
I unsuccesfully tried to figure out a system to combine
rack/pinion/rod steering with a hydraulic autopilot actuator
cylinder, but could not find a solution for a quick release of
hydraulic cylinder or a waterproof, easily operated bypass valve
close to the cylinder(out in the open, therefore). I don’t want
to
have to push oil in the autopilot actuator cylinder up and down
while
hand steering.
Now i’m happy with my voyager windvane steering combined with an
old
AH4000.
mike
I am not familiar with the F33, but on my F44, I installed
Autohelm
7001+ 400G with hydraulic cylinder attached to the quadrant,
which is
exposed to weather and will see sea water at higher speeds and
following seas. In 6 months, no problems and it seems to handle
steering problem well. Of course, there is a learning curve and
tuning issues but the auto learn feature really helps. The
documentation could be a little better with a little better
explanation of how different adjustments work.
If you want further stuff and a photo of the cylinder, let me
know
at the below address.
Sent: Wednesday, August 25, 2004 9:48 AM
post
Tom, Ketch 22 has an inboard rudder post and quadrant, UNlike
F33
where all rudder parts are above decks, and largely open to
sea
water. An inboard pilot as the AH6000 cannot be mounted
there.
The
parts are not corrosion proof or water tight - unfortunately.
— In freedomyachts2003@yahoogroups.com, Ketch 22
<ketch_22@e…>
Not sure about the F33, but I have an Autohelm 6000 on
Ketch
22, an
F39. Just sailed from California to Hawaii and back over a 2
month
period. The Autohelm was on very close to 24 hours a day, in
all
different kinds of conditions, including 35 knot winds and 16
foot
seas. It worked fine under all conditions.
Tom
Ketch 22
-----Original Message-----
Sent: Aug 24, 2004 1:31 AM
Subject: [freedomyachts2003] Re: F-33 Autopilot
I agree, all these claims about torque are maybe true, but
not
on a
> real sea with wave action against our barndoor rudder.
After
> > continuous trouble with my then new Simrad WP30 with 80 Nm torque >
> > (Autohelms and all the others have only 50 Nm)I mounted my ancient >
> > autohelm 4000 again which is still good for light winds and > motoring,
> > and invested in a Voyager windvane. Costs a few $ and you
have
a
> contraption on your transom, but it really works in strong
winds
is a beautiful piece of engineering.
Regards,
mike
UK F33 #033 Tumlare
— In freedomyachts2003@yahoogroups.com, Frank Minelli
<myslo@y…>
Thomas,
After much fooling around with drive belts and such,
which I
found
to be woefully inadequate for the Freddom 33, I installed
an
electerically driven hyraulic system.
I had started out with a Autohelm 3000, which was
advertised
as
being good up to 18000 lbs displacement.
All these claims are just so much hype. Go with the
strongest
surest system you can find. (I put mine together from
various
suppliers such as Graingers)
Thomas Carlton <Finesse@s…> wrote:
I would appreciate thoughts on a choice for a new
autopilot
for a
F-
33.
Thanks.
Thomas
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
<a
href="http://groups.yahoo.com/group/freedomyachts2003/">http://groups.
Your use of Yahoo! Groups is subject to the Yahoo!
Terms
of
> Service.
Yahoo!
Groups
Sponsor
<table border=0 cellpadding=0
cellspacing=0>
<font face=arial size=-
2>ADVERTISEMENT
<a
href="http://us.ard.yahoo.com/SIG=1298o60j3/M=298184.5285298.6392945.3
001176/D=groups/S=1705065792:HM/EXP=1093422730/A=2319498/R=0/SIG=11thf
ntfp/*http://www.netflix.com/Default?
mqso=60185352&partid=5285298"
alt=“”><img
src="http://us.a1.yimg.com/us.yimg.com/a/ne/netflix/81804_0704_b_30025
0a.gif" alt=“click here” width=“300” height=“250”
border=“0”>
<img alt="" width=1 height=1
src="http://us.adserver.yahoo.com/l?
M=298184.5285298.6392945.3001176/D=groups/S=:HM/A=2319498/rand=9390672
16">
Yahoo! Groups Links
  • To visit your group on the web, go to:
    <a
  • To unsubscribe from this group, send an email to:
    <a
  • href=“mailto:freedomyachts2003-unsubscribe@yahoogroups.com?
    subject=Unsubscribe”>freedomyachts2003-
  • Your use of Yahoo! Groups is subject to the <a
  • href="http://docs.yahoo.com/info/terms/">Yahoo! Terms of
    Service.
              ADVERTISEMENT
    Yahoo! Groups Links
    a.. To visit your group on the web, go to:
    b.. To unsubscribe from this group, send an email to:
    c.. Your use of Yahoo! Groups is subject to the Yahoo!
    Terms of
    Service.
              ADVERTISEMENT
    Yahoo! Groups Links
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
    Service.
    One of my AutoPilots units outputs is “solenoid”. This output is “on” whenever the drive unit is “engaged”. The by-pass valve is connected to this output. The valve is a separate item since in a pure hydraulic system, it is not needed. In the design process I looked at manual valves and mechanically dis-connecting the cylinder, but the valve worked out to be the best compromise though it does draw power when the auto pilot is driving.
    Brian Guptil http://www.brigup.com206-818-3203 sailordude@…1735 112th Ave. N.E.Bellevue, WA. 98004-3706
    Sent: Tuesday, August 31, 2004 10:08 AM
    Subject: [freedomyachts2003] Bypass valve question
    Brian:Thanks for your explanation. It’s what I almost designed for my F33, except the cylinder is not connected to a quadrant (we don’t have one) but in parallel to the steel rod that connects steering column and rudder arm. What I still like to know: how do you operate your bypass valve is you disengage your autopilot? I suppose it’s electrically operated, and perhaps automatically operated by your autopilot? Or do you have a pump with integrated bypass valve?Cheers,mike— In freedomyachts2003@yahoogroups.com, “Brian Guptil” <sailordude@b…> wrote:> Mike:> I have a stock cable,pulley,quadrant system with the quadrant mounted in a recess in the cockpit floor, exposed to weather and sea from backwash up the cockpit drains. The cylinder attaches to the (stock) quadrant and has a by-pass (normally open) valve across the lines form the pump. The pump and by-pass valve are below decks. The added drag on the steering is not as bad as I had expected and if needed, I can disconnect the cylinder from the quadrant though that has not been necessary. There are lots of cylinders out there, stainless, bronze and other. Often they are exposed to rather harsh environment of dirt, mud and otherwise. > > So I end up with combined standard cable and a mostly independent hydraulic, sharing only the quadrant on the way to the rudder. So far the cylinder is weathering just fine. I do rinse the cylinder with fresh water when available.> > I can take a photo and send it directly to you if you wish.> > Brian Guptil http://www.brigup.com> 206-818-3203 sailordude@b…> 1735 112th Ave. N.E.> Bellevue, WA. 98004-3706> > ----- Original Message ----- > From: mike_c_f35ck > To: freedomyachts2003@yahoogroups.com > Sent: Friday, August 27, 2004 9:14 AM> Subject: [freedomyachts2003] Re: F-33 has an outboard rudder post> > > Brian,> > Question to you: > > How do you combine mechanical steering and a hydraulic autopilot? Or > do you have hydraulic steering on you F44? In that case it’s easy to > combine the two (steering and autopilot on one hydraulic cylinder.> > I unsuccesfully tried to figure out a system to combine > rack/pinion/rod steering with a hydraulic autopilot actuator > cylinder, but could not find a solution for a quick release of the > hydraulic cylinder or a waterproof, easily operated bypass valve > close to the cylinder(out in the open, therefore). I don’t want to > have to push oil in the autopilot actuator cylinder up and down while > hand steering.> > Now i’m happy with my voyager windvane steering combined with an old > AH4000.> > mike> > > — In freedomyachts2003@yahoogroups.com, “Brian Guptil” > <sailordude@b…> wrote:> > I am not familiar with the F33, but on my F44, I installed Autohelm > 7001+ 400G with hydraulic cylinder attached to the quadrant, which is > exposed to weather and will see sea water at higher speeds and > following seas. In 6 months, no problems and it seems to handle the > steering problem well. Of course, there is a learning curve and > tuning issues but the auto learn feature really helps. The > documentation could be a little better with a little better > explanation of how different adjustments work.> > > > If you want further stuff and a photo of the cylinder, let me know > at the below address.> > > > Brian Guptil http://www.brigup.com> > 206-818-3203 sailordude@b…> > 1735 112th Ave. N.E.> > Bellevue, WA. 98004-3706> > > > ----- Original Message ----- > > From: mike_c_f35ck > > To: freedomyachts2003@yahoogroups.com > > Sent: Wednesday, August 25, 2004 9:48 AM> > Subject: [freedomyachts2003] Re: F-33 has an outboard rudder post> > > > > > Tom, Ketch 22 has an inboard rudder post and quadrant, UNlike the > F33 > > where all rudder parts are above decks, and largely open to sea > > water. An inboard pilot as the AH6000 cannot be mounted there. > The > > parts are not corrosion proof or water tight - unfortunately.> > > > — In freedomyachts2003@yahoogroups.com, Ketch 22 > <ketch_22@e…> > > wrote:> > > Not sure about the F33, but I have an Autohelm 6000 on Ketch > 22, an > > F39. Just sailed from California to Hawaii and back over a 2 > month > > period. The Autohelm was on very close to 24 hours a day, in all > > different kinds of conditions, including 35 knot winds and 16 > foot > > seas. It worked fine under all conditions. > > > > > > Tom> > > Ketch 22> > > > > > > > > > > > -----Original Message-----> > > From: mike_c_f35ck <mike_c_f35ck@y…>> > > Sent: Aug 24, 2004 1:31 AM> > > To: freedomyachts2003@yahoogroups.com> > > Subject: [freedomyachts2003] Re: F-33 Autopilot> > > > > > > > > > > > > > > > > > I agree, all these claims about torque are maybe true, but not > on a > >
    > > > real sea with wave action against our barndoor rudder. After >
    > > > continuous trouble with my then new Simrad WP30 with 80 Nm > torque > >
    > > > (Autohelms and all the others have only 50 Nm)I mounted my > ancient > >
    > > > autohelm 4000 again which is still good for light winds and > > motoring,
    > > > and invested in a Voyager windvane. Costs a few $ and you have > a > >
    > > > contraption on your transom, but it really works in strong > winds > > and
    > > > Regards,
    > > > mike
    > > > UK F33 #033 Tumlare
    > > > — In freedomyachts2003@yahoogroups.com, Frank Minelli > > <myslo@y…>
    > > > wrote:
    > > > > Thomas,
    > > > > After much fooling around with drive belts and such, which I > > found
    > > > to be woefully inadequate for the Freddom 33, I installed an >
    > > > > I had started out with a Autohelm 3000, which was advertised > as > >
    > > > > All these claims are just so much hype. Go with the > strongest > >
    > > > surest system you can find. (I put mine together from various >
    > > > > I would appreciate thoughts on a choice for a new autopilot > for a > > F-
    > > > 33.
    > > > > Thanks.
    > > > > Thomas
    > > > > Yahoo! Groups Links
    > > > > > > href=“http://groups.yahoo.com/group/freedomyachts2003/">http://groups.> > yahoo.com/group/freedomyachts2003/
    > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms > of > >
    > > > Service.
    Yahoo! Groups > > Sponsor
    > cellspacing=0>
    > 2>ADVERTISEMENT
    > > href=“http://us.ard.yahoo.com/SIG=1298o60j3/M=298184.5285298.6392945.3> > > 001176/D=groups/S=1705065792:HM/EXP=1093422730/A=2319498/R=0/SIG=11thf> > ntfp/*http://www.netflix.com/Default?> mqso=60185352&partid=5285298” > > alt=”"> > > src=“http://us.a1.yimg.com/us.yimg.com/a/ne/netflix/81804_0704_b_30025> > 0a.gif” alt=“click here” width=“300” height=“250” > > border=“0”>
    > src=“http://us.adserver.yahoo.com/l?> > > M=298184.5285298.6392945.3001176/D=groups/S=:HM/A=2319498/rand=9390672> > 16”>
    > > > Yahoo! Groups Links
    > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT> > > > > > > > > > > > --------------------------------------------------------------------> ----------> > Yahoo! Groups Links> > > > a… To visit your group on the web, go to:> > http://groups.yahoo.com/group/freedomyachts2003/> > > > b… To unsubscribe from this group, send an email to:> > freedomyachts2003-unsubscribe@yahoogroups.com> > > > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service.> > > Yahoo! Groups Sponsor > ADVERTISEMENT> > > > > > ------------------------------------------------------------------------------> Yahoo! Groups Links> > a… To visit your group on the web, go to:> http://groups.yahoo.com/group/freedomyachts2003/> > b… To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
    …so if you put your autopilot in standby, the bypass valve opens
    automatically?
    mike
    Brian:
    F33,
    column
    and rudder arm.
    is
    operated,
    have
    Cheers,
    mike
    Mike:
    sea
    decks.
    and if
    that
    harsh
    independent
    So
    cylinder
    post
    Brian,
    Question to you:
    autopilot?
    Or
    easy
    to
    cylinder.
    of
    valve
    want
    to
    down
    while
    hand steering.
    an
    old
    AH4000.
    mike
    Autohelm
    which is
    handle
    me
    know
    rudder
    post
    UNlike
    F33
    to
    sea
    there.
    The
    unfortunately.
    <ketch_22@e…>
    Ketch
    22, an
    a 2
    month
    day, in
    all
    and 16
    foot
    Tom
    Ketch 22
    but
    not
    on a
    After
    Nm
    torque
    my
    ancient
    motoring,
    you
    have
    a
    strong
    winds
    Regards,
    mike
    UK F33 #033 Tumlare
    <myslo@y…>
    Thomas,
    which I
    found
    installed
    an
    advertised
    as
    strongest
    various
    autopilot
    for a
    F-
    33.
    Thanks.
    Thomas
    Yahoo! Groups Links
    <a
    to:
    Terms
    of
    Service.
    <font size="-1"
    color=#003399>Yahoo!
    Groups
    Sponsor
    <table border=0
    cellpadding=0
    cellspacing=0>
    <font face=arial
    size=-
    2>ADVERTISEMENT
    <a
    alt=“”><img
    border=“0”>
    16">
    Yahoo! Groups Links
      <a
  • to:
    <a
    Service.
              ADVERTISEMENT
    Yahoo! Groups Links
    Terms of
    Service.
              ADVERTISEMENT
    Yahoo! Groups Links
    Terms of
    Service.
              ADVERTISEMENT
    Yahoo! Groups Links
    Service.
    Mike
    Yes, the valve opens and the boat steers with the slight drag of the friction in the cylinder added to the system. It has not been a problem. The engage or dis-engage process takes about 1/2 second.
    Sent: Wednesday, September 01, 2004 1:23 PM
    Subject: [freedomyachts2003] Re: Bypass valve question
    …so if you put your autopilot in standby, the bypass valve opens automatically?mike — In freedomyachts2003@yahoogroups.com, “Brian Guptil” <sailordude@b…> wrote:> One of my AutoPilots units outputs is “solenoid”. This output is “on” whenever the drive unit is “engaged”. The by-pass valve is connected to this output. The valve is a separate item since in a pure hydraulic system, it is not needed. In the design process I looked at manual valves and mechanically dis-connecting the cylinder, but the valve worked out to be the best compromise though it does draw power when the auto pilot is driving.> > Brian Guptil http://www.brigup.com> 206-818-3203 sailordude@b…> 1735 112th Ave. N.E.> Bellevue, WA. 98004-3706> > ----- Original Message ----- > From: mike_c_f35ck > To: freedomyachts2003@yahoogroups.com > Sent: Tuesday, August 31, 2004 10:08 AM> Subject: [freedomyachts2003] Bypass valve question> > > Brian:> > Thanks for your explanation. It’s what I almost designed for my F33, > except the cylinder is not connected to a quadrant (we don’t have > one) but in parallel to the steel rod that connects steering column > and rudder arm. > > What I still like to know: how do you operate your bypass valve is > you disengage your autopilot? I suppose it’s electrically operated, > and perhaps automatically operated by your autopilot? Or do you have > a pump with integrated bypass valve?> > Cheers,> mike> > > — In freedomyachts2003@yahoogroups.com, “Brian Guptil” > <sailordude@b…> wrote:> > Mike:> > I have a stock cable,pulley,quadrant system with the quadrant > mounted in a recess in the cockpit floor, exposed to weather and sea > from backwash up the cockpit drains. The cylinder attaches to the > (stock) quadrant and has a by-pass (normally open) valve across the > lines form the pump. The pump and by-pass valve are below decks. > The added drag on the steering is not as bad as I had expected and if > needed, I can disconnect the cylinder from the quadrant though that > has not been necessary. There are lots of cylinders out there, > stainless, bronze and other. Often they are exposed to rather harsh > environment of dirt, mud and otherwise. > > > > So I end up with combined standard cable and a mostly independent > hydraulic, sharing only the quadrant on the way to the rudder. So > far the cylinder is weathering just fine. I do rinse the cylinder > with fresh water when available.> > > > I can take a photo and send it directly to you if you wish.> > > > Brian Guptil http://www.brigup.com> > 206-818-3203 sailordude@b…> > 1735 112th Ave. N.E.> > Bellevue, WA. 98004-3706
