camber spar on F32
Posted by rnld_brr (rwhb@…>)
Does anyone know what the true dimensions of this are supposed to be.
I’ve contacted the guru Dave Bierig who made it and he sent me the
dimensions for the sail pocket. I think our spar is very very bent,
the sail won’t flip over when tacking easily and the jib looks very
curved and sags when furled. However even his pocket dimensions are
marked “approximate” and “rule of thumb”! Has anyone tried to
straighten theirs and if so how? The maximum offset seems to be about
7-8% of the length - can anyone confirm that for me?
Ron Barr
F32 Liberte Newport RI
Bouncing around in 40k gusts!
Posted by Brian (sailordude@…>)
Ron
My F32 and F36 had the same problem. I put slack in the forstay so that at sholder hight, it could be easily moved about a foot. On on the 36, when I had a new sail made, I found the batten was not arched properly. I replaced the batten and the problem was resolved. When you look at the batten outside of the sail it has a very exagerated foil shape. Since it is held more vertically when the jib is tightly sheeted as a result of the little lever at the back end of the batten. But when you sheet out and even go wing on wing, there will be a lot of curve in the jib. I wish I could put similar camber in my sails as I sheet out.
Brian
Sent: Tuesday, October 28, 2008 5:02 PM
Subject: [FreedomOwnersGroup] camber spar on F32
Does anyone know what the true dimensions of this are supposed to be.I’ve contacted the guru Dave Bierig who made it and he sent me thedimensions for the sail pocket. I think our spar is very very bent,the sail won’t flip over when tacking easily and the jib looks verycurved and sags when furled. However even his pocket dimensions aremarked “approximate” and “rule of thumb”! Has anyone tried tostraighten theirs and if so how? The maximum offset seems to be about7-8% of the length - can anyone confirm that for me?ThanksRon BarrF32 Liberte Newport RIBouncing around in 40k gusts!
Posted by ron barr (rwhb@…>)
Yes but I refuse to believe that ours is OK. The center
offset is supposed to be about 1/12 the length of 8ft. Ours is so curved that
it is about 7’6” and the offset is almost 22 inches instead of what
about 8”??
Ron
Hoyt F32
Newport RI
Hi Ron,
I just measured my camber spar (brought it home to re-paint).
The length measured in the straight line from end to end
(not following the curve) is about 7’ 4" and the offset at the
highest point is about 14". Your length seems correct, but the
offset is funky.
My jib works fine and looks ok. I don’t know what else to
suggest. I’m surprised the Biereg doesn’t have better information.
Good luck,
TW, '84 F32 #20
Pemaquid, ME
At 02:32 PM 10/29/2008, you wrote:
Yes but I refuse to believe that ours is OK. The center offset is
it is about 7’6" and the offset is almost 22 inches instead of what
about 8"??
Ron
Hoyt F32
Newport RI
Checked by AVG - http://www.avg.com
Version: 8.0.175 / Virus Database: 270.8.4/1752 - Release Date:
10/28/2008 10:04 AM
Posted by Scott Forgey (jsforgey@…>)
I am going to have to measure mine and let you know.
I had Dave make me a new one. He sent it with a bill and
note that he made it “more sturdy” and increased the diameter of
the pipe. It looks great but when I put it on and use it under sail the
end of it hit the mast. YIKES! What’s that clunking!
I think the length is adjustable but I will measure it and
hopefully adjust it tomorrow.
We are going to sail by the Ft. Lauderdale “boat”
show…$2B of boats…mostly huge…but a few interesting sail
boats.
Scott
Girlfriend F-32 (Hoyt)
Scott Forgey
21362 Summertrace Circle
Boca Raton, FL 33428
561.445.5179
skype: sforgey1
“Nothing is ever wrong in the universe, there is only
what’s missing!”
W. Erhard
Behalf Of Brian
Sent: Tuesday, October 28, 2008 10:41 PM
Subject: Re: [FreedomOwnersGroup] camber spar on F32
Ron
My
Brian
2008 5:02 PM
camber spar on F32
to
Ron Barr
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.4/1751 - Release Date: 10/27/2008
10:44 PM
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.5/1758 - Release Date: 10/31/2008 8:22 AM
Hi Scott,
When mine hits the mast, I can correct
it by tightening the jib halyard until it
clears. You might want to give that a try.
Good luck.
TW F32 Anoush Koon
Pemaquid ME
bill and note that he made it “more sturdy” and
increased the diameter of the pipe. It looks
the end of it hit the mast. YIKES! What’s that clunking!
measure it and hopefully adjust it tomorrow.
“boat” show…$2B of boats…mostly huge…but a few interesting sail boats.
Scott
Scott Forgey
561.445.5179
skype: sforgey1
“Nothing is ever wrong in the universe, there is only what’s missing!”
                 W. Erhard
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Brian
Ron
Brian
To:
<mailto:FreedomOwnersGroup@yahoogroups.com>FreedomOwnersGroup@yahoogroups.com
Ron Barr
Checked by AVG.
  • Release Date: 10/27/2008 10:44 PM
Checked by AVG.
  • Release Date: 10/31/2008 8:22 AM
Version: 8.0.175 / Virus Database: 270.8.5/1758
Thanks for the tip.
The other camberspar never hit. I will check that out and
see if that makes a difference. I never pull the jib halyard more than
hand tight, as tensioning the jib halyard sounded like a bad Idea.
Am I mistaken?
It looked like the aft end was adjustable. Taking the damn
thing out of the pocket to do that is not on my list of great things to do on a
Saturday.
Scott Forgey
561.445.5179
skype: sforgey1
what’s missing!”
W. Erhard
Behalf Of Thomas Wales
Sent: Friday, October 31, 2008 3:57 PM
Subject: RE: [FreedomOwnersGroup] camber spar on F32
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Scott
Scott Forgey
561.445.5179
skype: sforgey1
missing!”
W. Erhard
On Behalf Of Brian
Ron
Brian
To:
tried to
Ron Barr
Checked by AVG.
Checked by AVG.
Checked by AVG.
AM
Checked by AVG.
You can adjust the length at the aft end
of the spar. Unfortunately the prior owner did not know that and used a saw
instead so now the spar is too short for the new sail I had made per specs.
You can drill out the pop rivets and move the ends in and out is what I did but
I am still short by an inch or so.
Bob
Behalf Of Scott Forgey
4:27 PM
To:
camber spar on F32
Thanks for the tip.
Am I mistaken?
Saturday.
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Thomas Wales
3:57 PM
camber spar on F32
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Lauderdale
Scott
Scott Forgey
561.445.5179
skype: sforgey1
missing!”
W. Erhard
On Behalf Of Brian
Ron
Brian
To:
tried to
Ron Barr
Checked by AVG.
Checked by AVG.
No virus
Checked by AVG.
AM
No virus
Checked by AVG.
AM
Bob,
I had to get a new one because it just froze up and would not
flip. I drilled the rivets. I soaked it in a number of concoctions,
did everything but it was fused solid! I would have used some dynamite if
I could’ve got my hands on some.
Four hundred dollars later I have a new one. I think that
Dave sent me a diagram with dimensions. I will check and upload it to the
web site.
Dave is really great in a grumpy old man sort of way.
Cheers,
Scott Forgey
561.445.5179
skype: sforgey1
what’s missing!”
W. Erhard
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Bob Weeks
Sent: Friday, October 31, 2008 6:04 PM
You can
adjust the length at the aft end of the spar. Unfortunately the prior
owner did not know that and used a saw instead so now the spar is too short for
the new sail I had made per specs. You can drill out the pop rivets and
move the ends in and out is what I did but I am still short by an inch or
so.
Bob
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Scott Forgey
Sent: Friday, October 31, 2008 4:27 PM
Thanks for the tip.
will check that out and see if that makes a difference. I never pull the
jib halyard more than hand tight, as tensioning the jib halyard sounded like a bad
Idea.
Am I mistaken?
adjustable. Taking the damn thing out of the pocket to do that is not on
my list of great things to do on a Saturday.
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Scott
Scott Forgey
561.445.5179
skype: sforgey1
missing!”
W. Erhard
On Behalf Of Brian
Ron
Brian
To:
tried to
Ron Barr
Checked by AVG.
Checked by AVG.
Checked by AVG.
AM
Checked by AVG.
AM
Checked by AVG.
AM
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.5/1759 - Release Date: 10/31/2008 4:10 PM
Hitting the mast is certainly not the issue since the spar
has excessive camber thereby shortening it. The sail and battens are new this
year. Measuring the offset at the center it is approximately 23”, whereas
1/12 the length of approximately 8ft = 8”!!!
I guess my question is how the heck to straighten i? Beirig
talks about putting it under the stairs and levering it – my wife does
not approve needless to say!
Also the camber must not be a consistent one throughout the
length since the luff must be more full. Anybody bent these things back?
Ron
Hoyt F32
Newport RI
Rather then using aluminum for the spar
has anyone heard of anyone making it from carbon fiber? It would be light,
strong, and it would seem to be more movable in lighter air.
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Scott Forgey
Sent: Saturday, November 01, 2008
10:56 AM
To:
camber spar on F32
Bob,
web site.
Cheers,
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
6:04 PM
camber spar on F32
You can adjust the length at the aft end of the spar.
Unfortunately the prior owner did not know that and used a saw instead so now
the spar is too short for the new sail I had made per specs. You can
drill out the pop rivets and move the ends in and out is what I did but I am
Bob
4:27 PM
camber spar on F32
Thanks for the tip.
Am I mistaken?
Saturday.
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
3:57 PM
camber spar on F32
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Lauderdale
Scott
Scott Forgey
561.445.5179
skype: sforgey1
missing!”
W. Erhard
On Behalf Of Brian
Ron
Brian
To:
tried to
Ron Barr
Checked by AVG.
Checked by AVG.
No virus
Checked by AVG.
AM
No virus
Checked by AVG.
AM
No virus
Checked by AVG.
AM
No virus
Checked by AVG.
PM
And about triple the cost. The technical
advantages all come at a price in the sailboat business. Herm
At 05:41 PM 11/2/2008, you wrote:
Rather then using aluminum for the spar has
fiber? It would be light, strong, and it would
Bob
Sent: Saturday, November 01, 2008 10:56 AM
Bob,
and would not flip. I drilled the rivets. I
soaked it in a number of concoctions, did
used some dynamite if I could’ve got my hands on some.
think that Dave sent me a diagram with
dimensions. I will check and upload it to the web site.
Cheers,
Scott Forgey
561.445.5179
skype: sforgey1
                 W. Erhard
move the ends in and out is what I did but I am still short by an inch or so.
Bob
Thanks for the tip.
never pull the jib halyard more than hand tight,
Am I mistaken?
pocket to do that is not on my list of great things to do on a Saturday.
Scott Forgey
561.445.5179
skype: sforgey1
                 W. Erhard
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Scott
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
To:
Ron
Brian
To:
<mailto:FreedomOwnersGroup@yahoogroups.com><mai
lto:FreedomOwnersGroup%40yahoogroups.com>FreedomOwnersGroup@yahoogroups.com
Ron Barr
Checked by AVG.
Checked by AVG.
Checked by AVG - http://www.avg.comhttp://www.avg.com
Checked by AVG.
Checked by AVG.
Checked by AVG.
Checked by AVG.
  • Release Date: 10/31/2008 4:10 PM
Come’ on Scott…
Think of us poor folks up here in the
frozen north. I’d like nothing better to do on a
Saturday than mess with my camber spar. Is there
anything bad to do in Boca in the winter?..
TW
At 03:27 PM 10/31/2008, you wrote:
Thanks for the tip.
Am I mistaken?
Scott Forgey
561.445.5179
skype: sforgey1
                 W. Erhard
Hi Scott,
Good luck.
TW F32 Anoush Koon
Pemaquid ME
Scott
Scott Forgey
561.445.5179
skype: sforgey1
W. Erhard
To:
Ron
Brian
To:
Ron Barr
Checked by AVG.
Checked by AVG.
Checked by AVG.
Checked by AVG.
Version: 8.0.175 / Virus Database: 270.8.5/1763
  • Release Date: 11/2/2008 7:08 PM
