cat-ketch 28-rigging
Posted by Dennis Gunn (dutchharborconanicut@…>)
Just started rigging our cat ketch that we bought over the winter and I have questions already.There are two lines on the mizzen that I haven’t figured out yet. They are just like the upper part of the lazyjacks(vinyl or rubber coated cable) that simply end in an eye, about seven feet off the deck. The difference from the lazyjacks is that these lines come from the top of the mast and don’t have the block at the end. Also,there is another line with each mast set up just as the halyards are. I’m guessing that these were added as topping lifts ,although there were none showing in the original rigging sketches that came with the boat. The previous owner is living in england, so any help would be
appreciated. Dennis Gunn
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us.
They might be running backstays (or at least the top portion of same)
to support the mast when using a large mizzen staysail. Herm
<http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel\
_invite.asp?a=7>Join
Posted by Tom Keegan (tom.bayshore@…>)
My 39’ cat ketch has the same set-up. We use them as running backstays when we fly the “spinnaker” which is mmmmmmm once a year for the downhill delta run from San Francisco Bay. Tom Killin’ TimeHerman and Gail Schiller <hschiller2@…> wrote: They might be running backstays (or at least the top portion of same) to support the mast when using a large mizzen staysail. HermAt 01:33 PM 6/9/2007, Dennis Gunn wrote:> Just started rigging
our cat ketch that we bought over > the winter and I have questions already.There are two lines on the > mizzen that I haven’t figured out yet. They are just like the upper > part of the lazyjacks(vinyl or rubber coated cable) that simply end > in an eye, about seven feet off the deck. The difference from the > lazyjacks is that these lines come from the top of the mast and > don’t have the block at the end. Also,there is another line with > each mast set up just as the halyards are. I’m guessing that these > were added as topping lifts ,although there were none showing in > the original rigging sketches that came with the boat. The previous > owner is living in england, so any help would be > appreciated. Dennis Gunn>>>Fussy? Opinionated? Impossible to please? Perfect. ><http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7>Join >Yahoo!'s user panel and lay it on us.>
Thanks to Herman and Gail, and Tom for your input. That’s two votes so far for running backstays. Thanks again Dennis GunnTom Keegan <tom.bayshore@…> wrote: My 39’ cat ketch has the same set-up. We use them as running backstays when we fly the “spinnaker” which is mmmmmmm once a year for the downhill delta run from San Francisco Bay. Tom Killin’ TimeHerman and Gail Schiller <hschiller2@suddenlink.net> wrote: They might be running backstays (or at least the top portion of same) to support the mast when using a large mizzen
staysail. HermAt 01:33 PM 6/9/2007, Dennis Gunn wrote:> Just started rigging our cat ketch that we bought over > the winter and I have questions already.There are two lines on the > mizzen that I haven’t figured out yet. They are just like the upper > part of the lazyjacks(vinyl or rubber coated cable) that simply end > in an eye, about seven feet off the deck. The difference from the > lazyjacks is that these lines come from the top of the mast and > don’t have the block at the end. Also,there is another line with > each mast set up just as the halyards are. I’m guessing that these > were added as topping lifts ,although there were none showing in > the original rigging sketches that came with the boat. The previous > owner is living in england, so any help would be > appreciated. Dennis Gunn>>>Fussy? Opinionated? Impossible to please? Perfect.
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search.
One more fun thing for fun with ketches. Use your main and mizzen hayard to put a young and brave sailor in a bosun chair, lift them above the main boom and you have a great swing!!! Tom Killin’ TimeDennis Gunn <dutchharborconanicut@…> wrote: Thanks to Herman and Gail, and Tom for your input. That’s two votes so far for running backstays. Thanks again Dennis GunnTom Keegan <tom.bayshore@sbcglobal.net> wrote: My 39’ cat ketch has the
same set-up. We use them as running backstays when we fly the “spinnaker” which is mmmmmmm once a year for the downhill delta run from San Francisco Bay. Tom Killin’ TimeHerman and Gail Schiller <hschiller2@suddenlink.net> wrote: They might be running backstays (or at least the top portion of same) to support the mast when using a large mizzen staysail. HermAt 01:33 PM 6/9/2007, Dennis Gunn wrote:> Just started rigging our cat ketch that we bought over > the winter and I have questions already.There are two lines on the > mizzen that I haven’t figured out yet. They are just like the upper > part of the lazyjacks(vinyl or rubber coated cable) that simply end > in an eye, about seven feet off the deck. The difference from
the > lazyjacks is that these lines come from the top of the mast and > don’t have the block at the end. Also,there is another line with > each mast set up just as the halyards are. I’m guessing that these > were added as topping lifts ,although there were none showing in > the original rigging sketches that came with the boat. The previous > owner is living in england, so any help would be > appreciated. Dennis Gunn>>>Fussy? Opinionated? Impossible to please? Perfect. ><http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7>Join >Yahoo!'s user panel and lay it on us.> Luggage? GPS? Comic books? Check out fitting gifts for grads at Yahoo! Search.
Dennis,
The plasticated stainless wires are indeed your running backstays.
There has to be a tackle and cleat at the end of each one. When not
in use, put the snapshackle at the end of the tackle on the footrail
atwarthships of the mizzen mast. They will help as a handhold to get
on board.
Always use the windward backstay when you fly a staysail or you
might risk breaking your masttop. The Freedom masts are not designed
for top loads. Attach the snapshackle to the aftmost point available
on your foot rail and tension the backstay.
The two extra halyards on your masts are a spare halyard on the main
and a staysail/spare halyard on the mizzen.
Have a good time rigging out.
michel
— In freedomyachts2003@yahoogroups.com, Dennis Gunn
Those are running backstays, sort of. I’ll add my 2 cts to what
Michel has said.
First, I took mine off Bright Star. The rigger I consulted said that
they actually weren’t necessary on the Freedoms, as long as you
actually had your mizzen up. Since in 3 years I’ve never flown the
mizzen staysails or spinnaker, I decided to take them down since they
were simply making noise, banging the masts and adding windage.
Second, if you want to stay on the safe side and run them anyway
(there’s nothing wrong with extra safety, after all), rest assured
that they would ONLY be needed on the mizzen, since that is the spar
from which you fly your staysails. Also, I highly recommend that if
you intend to stay with them, replace the originals. they are vinyl
coated wire, which is prone to crevice corrosion, and if they are
anything like what was on Bright Star, they are undersized for the
task at hand anyway. If you want running backs, I’d consider going
with a high-tech line solution, with a true block and tackle purchase
at the deck end.
Like I said, just my 2cts, but if it’s important to you to have them,
I’d consider having a rigger engineer the proper size and strength
for your rig.
Lance
Soon to be a two-freedom owner.
Thanks Lance and Michel . that makes it 4 for 4 , the running backstays are batting a thousand. I really don’t have any experience with running backstays, and I’ll probably keep it that way. This being our first freedom,I thought part of the freedom idea was to eliminate shrouds and stays. So the possibility of these being running backstays never entered my mind.Thanks again,I feel a lot better now than I did when I left the boat a week ago. Now if we could only get her in the water. Dennislance_ryley <lance_ryley@…> wrote: Those are running backstays, sort of. I’ll add my 2 cts to what Michel has said.First, I took mine off Bright Star. The rigger I consulted said that they actually weren’t necessary on the Freedoms, as long as you actually had your mizzen up. Since in 3 years I’ve never flown the mizzen staysails or spinnaker, I decided to take them down since they were simply making noise, banging the masts and adding windage. Second, if you want to stay on the safe side and run them anyway (there’s nothing wrong with extra safety, after all), rest assured that they would ONLY be needed on the mizzen, since that is the spar from which you fly your staysails. Also, I highly recommend that if you intend to stay with them, replace the originals. they are vinyl coated wire, which is prone to crevice corrosion, and if they are anything like what was on Bright Star, they are undersized for the task at hand
anyway. If you want running backs, I’d consider going with a high-tech line solution, with a true block and tackle purchase at the deck end. Like I said, just my 2cts, but if it’s important to you to have them, I’d consider having a rigger engineer the proper size and strength for your rig.LanceSoon to be a two-freedom owner.— In freedomyachts2003@yahoogroups.com, Dennis Gunn <dutchharborconanicut@…> wrote:>> Just started rigging our cat ketch that we bought over the winter and I have questions already.There are two lines on the mizzen that I haven’t figured out yet. They are just like the upper part of the lazyjacks(vinyl or rubber coated cable) that simply end in an eye, about seven feet off the deck. The difference from the lazyjacks is that these lines come from the top of the mast and don’t have the
block at the end. Also,there is another line with each mast set up just as the halyards are. I’m guessing that these were added as topping lifts ,although there were none showing in the original rigging sketches that came with the boat. The previous owner is living in england, so any help would be appreciated. Dennis Gunn> > ---------------------------------> Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us.>
Dennis,
Good luck, and as Lance says, if you don’t ever use mizzen
staysails, you don’t need backstays. I replaced mine because they
were badly corroded; plasticated stainless steel is probably not the
best solution, but it was much cheaper than no stretch Dyneema
alternatives The plastic coated wires will last for the next 10 to
15 years, I guess. I’m going to buy a huge mizzen gennaker for my
F44, so I do want the backstays. The main and mizzen sail do not
give very large sideways bending loads on the upper mast section. A
mizzen halyard at the masthead with a huge staysail does.
Dennis
to what
Michel has said.
that
they
spar
if
vinyl
purchase
at the deck end.
them,
for your rig.
Lance
upper
end
don’t
mast
added
Posted by celij (junk@…>)
Lance - A two Freedom owner? Can not get enough of a good thing?
Michel has said.
at the deck end.
for your rig.
Lance
Noow, Lance and his wife need more space for their shoes and clothes
hangers.
Michel has said.
that
they
assured
spar
if
vinyl
going
purchase
at the deck end.
them,
strength
for your rig.
Lance
over
upper
end
don’t
mast
added
original
appreciated. Dennis
Gunn
Yahoo!'s
