Hey folks,
it looks like I am starting down the path of moving away from the roller furler that my boat came with and installing a camber spar set up. I am in the process of purchasing the actual spar (thanks to Al Jacobs). So now I need a sail. Anyone have a camber spar sail for a F40/40 that is in reasonable shape sitting in their garage?
Or how about a sail design for one, so when I go to get one made I have something to hand off to a sail maker? Or along those lines, do you think that there is any chance of modifying my self tacking roller furler sail to be a camber spar sail? Obviously adding hanks is the easy part, what else needs to happen? A pocket for the spar. But is the sail shape significantly different?
Hi Tony, on my F21, the self-tacking jib uses a metal wishbone attached to the clew and again at a right angles to the luff. It just clears the mast and is sheeted to the base of the mast so the sheet angle to the clew is extreme but it seems to work OK. The length of the frame is not adjustable and gives the jib maybe 5-10% camber, see old pic attached from previous owner. You can see leeward side of the wishbone frame.
OK now I have come accross a new stumbling block in this project. Shipping a 12 foot camberspar accross country seems to be problematic? Has any one done this before? Any thoughts? Already tried UPS/Fedex. They want a crate built around it. I can’t really make that happen from the opposite coast.
[quote=TonyB post_id=52930 time=1599239648 user_id=6157]
[/quote]
The best suited option would be to ship this shrink wrapped on to two pallets. They can pick it up and possibly tie the spar down to a pallet. I used R+L Carriers before and they were both, quality service and affordable for a trucking company that handles any type of freight: https://www.rlcarriers.com/
I once shipped a 13 ft spinnaker pole across the US From NC to San Francisco and had to use a motor carrier. UPS, FEDEX Etc wanted nothing to do with it.
You can try something like Uship. com. I’ve had good luck. But pay attention to the ratings of the carriers. Also, I think at this time of the year you have boats being shipped East to West, so some boat transporter may be an option.
Al wrapped it in two layers of bubble wrap and then a canvas tarp. He took it to both FEdEx and UPS Freight (not package. They won’t touch anything that long). Both told him it had to be crated. So looking for other solutions.
