Have you had the masts out or been able to
examine if there is any wear where the bolts go into the mast?
Alan
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome Weinraub
Sent: Saturday, February 25, 2006
9:31 AM
To:
Re: Check your mast steps!
The mast steps and the mast collars at the partners on the
F33 are aluminum,and are virtually identical. I replaced both mast collars
with SS made by Garhauer. I was thinking of the same for the steps,but making
the upright portion taller by 2 inches. Presentl,in addition to the thru
bolts,I use polyurethane wedges driven in hard. Works well. No motion,and
no sounds coming from the step.BTW-the Stainless collars are very nice- the
original collars had lost some ears,and one had cracked. The price was very
attractiveFrom: Alan Kusinitz
25, 2006 6:15 AM
Subject: RE:
[freedomyachts2003] Re: Check your mast steps!
Thank you. This was very clear. The
stainless steel ring and turnbuckle was something I was thinking about but
thought putting the ring at the deck would keep it from lifting. But with the
turnbuckle I guess the downward tension makes it even more secure.
There was a memo on my boat from Freedom
that suggested using epoxy sticks in the space around the mast. It didn’t
say anything about non-stick but clearly one would need to use Vaseline or
something to allow the masts to be removed.
My experience leads me to believe the
arrangement in your boat helped avoid damage in the severe weather you mentioned.
Thanks again. This was quite helpful.
Alan
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Skip Turpin
3:20 AM
To:
Alan,
I own the 1982, F33, Hull #63!
Some previous owner apparently was concerned about
the mast pulling
out of the step ring also. With all I have
been able to gather over
the years this just does not seem to happen with
this boat. Never
the less, someone was worried about it, to the
point of spending a
fare amount of cash to purchase his or her piece
of mind. Here is
what they did!
They had a two piece stainless steel collar made
out of 1/4" x 2"
stock. The two halves were then lined with
rubber and bolted
together at each end with 3/8 bolts. The
collar was positioned about
18" above the step ring with the the collar
bolt positioned over one
of the gussets with the hole drilled through
it. A “D” shackle was
installed through that hole in the step ring
gusset. He then
attached a huge stainless steel turn buckle with
hooks at each end
between the bolt clamping the ring halves together
and the “D”
shackle that was attached to the step ring.
By tightening the turn buckle you pull the mast
down hard onto the
step. I have had my boat in 30’ seas and 50
knot winds and the mast
never budged or did any popping. I did have
my main boom vang part
(not a pretty sight. You would not believe
what the boom did when
turned lose in those conditions! Yiks!) The main
mast did turn a bit,
but did not lift! In fact as the mast tried
to turn, the turnbuckle
got even tighter.
I will have to fix the bolt holes in both the mast
and the step
ring. I like your idea of building up the
interior of the mast at
the hole locations.
I can also tell you that the base of each mast had
about four beads
of a hard white guzzer between the ID of the step
ring and the OD of
the mast. I am sure the mast had been
sprayed with some kind of non
stick spray prior to the application of this
guzzer. Both masts were
very easy to release from the step rings once the
deck rings were
removed and the partners driven out the top.
I am sorry, but the name of that stuff escapes me
at the moment but
it has been posted on this board. It was
white, hard and looked like
some kind of two part filler. You could see
where someone had used
their fingertips to stuff the filler down between
the mast and the
step ring. With the masts out, it was no big
deal to remove the
patches of that filler. I am sure someone
will come forward with the
name of the goop!
I am pretty sure that this filler is what really
keeps the masts from
moving around in the step ring and causing the
banging and noise that
some folks complain about!
Hope this is helpful info for other owners.
As I will not be re-
stepping my mast till I put her back in the water,
I can not get any
pictures of this lash up. If this was clear
as mud, I will try to
answer any questions if they come up!
Skip
— In freedomyachts2003@yahoogroups.com,
“Alan Kusinitz”
<akusinitz@…> wrote:
I have an F33 Hull #51 1982. I think
there are significant issues
with the
method of securing the mast to the step.
Behalf Of Tom Vesey
Sent: Friday, February 24, 2006 12:13 PM
To: freedomyachts2003@yahoogroups.com;
Freedom-44@yahoogroups.com
Subject: [freedomyachts2003] Check your mast
steps!
Here’s a sad story to remind us to enjoy out
life on the water,
but
to check our mast steps too.
One of the neat things about Freedoms is you
don’t have to worry
about your turnbuckles coming undone and
stuff like that. But
here’s
a scary incident that should remind us to
keep an eye on our mast
steps, and make sure that our masts are
firmly fastened to the
boat.
Once that lets go, there isn’t much holding
the mast in place.
A couple of weeks ago Carina, a 1983 Tanton
43 (cat ketch with
carbon
masts, wishbone booms) ran into ferocious
weather on a trip from
Connecticut
to Bermuda. Why exactly they were doing
this trip in
February is unclear to me. The main mast –
right at the bow, as
on
Freedom cat ketches – came unstuck from its
step and started
gyrating around, smashing up the cabin below.
(Links to a
newspaper
story are at the bottom of this e-mail)
I spoke to a couple of crewmen who said they
were convinced it
would
drive itself through the bottom of the hull,
once it had finished
demolishing bulkheads and every piece of
furniture it could reach.
Fortunately, they said, it smashed into the
chain locker and got
tangled in the anchor chain, which slowed its
swinging. The mast
eventually snapped off above the deck. Of
course, various halyards
etc then got tangled up in the prop, and an
assortment of other
problems occurred.
One of which was the owner’s health, which
was very poor to start
with. He was rushed to hospital as soon
as the boat made it to
Bermuda,
fell into a coma, was flown back to the states by air
ambulance but died soon afterwards.
Richard Brignoli, the owner, had sailed the
boat to Bermuda pretty
much every year for a couple of decades.
Richard showed me around
his
boat a couple of years ago when I
started looking at cat
ketches.
It was a beautiful and solid looking boat. He
loved it, and urged
me
to go ahead and get a Freedom or a Tanton.
I spoke to a couple of his friends who said
they suspected he knew
his days were numbered, and probably wanted
to have one last sail
to
Bermuda on his
beloved cat ketch.
The two crew I spoke with said the main
mast on Carina appeared
to
sit upon a heavy piece of timber, the top of
which was covered in
fiberglass. But the wood underneath had
rotted away, they said,
without anybody noticing. The urged me to
check my mast steps,
which
of course I did and everything appeared to be
solid.
But I must admit I couldn’t really see
clearly – mostly judged by
feeling around – and don’t have a
clear idea of how they are
fastened or how they are meant to be
fastened. When I felt under
my
mizzen mast, I could feel what seem to be a
couple of large nuts,
as
though it was somehow bolted onto the step.
Sometime over the next few days I will go at
it more seriously with
a
mirror and flashlight.
Does anybody have a good idea of how these
masts should be
attached
to the boat? Or is this a case where no
two boats are alike.
I remember Brian Guptil of Cayenne complaining that his masts
appeared to have been epoxied into place and
were a nightmare to
remove.
Tom
Jackrabbit
F44 Bermuda
Here is a first-hand version of the events
(with a couple of
pictures), as told by one of the crew to a Nova Scotia newspaper.
http://www.herald.ns.ca/Front/486199.html
And some reporting from the Bermuda
newspapers:
http://www.theroyalgazette.com/apps/pbcs.dll/article?AID=/20060217/
NEWS/102170096&SearchID=73236645845584
http://www.theroyalgazette.com/apps/pbcs.dll/article?AID=/20060214/
NEWS/102140152&SearchID=73236645845584
SPONSORED LINKS
Sailing
<http://groups.yahoo.com/gads?
t=ms&k=Sailing+schools&w1=Sailing+schools&w2=S
ailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adve
nture&
w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw> schools
Sailing
t=ms&k=Sailing+instruction&w1=Sailing+schools&
w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+
advent
ure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg>
instruction
Sailing
t=ms&k=Sailing+lesson&w1=Sailing+schools&w2=Sa
iling+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adven
ture&w
6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg> lesson
Sailing
t=ms&k=Sailing+course&w1=Sailing+schools&w2=Sa
ture&w
6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg> course
Sailing
t=ms&k=Sailing+adventure&w1=Sailing+schools&w2
=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+ad
ventur
e&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A>
adventure
Sailing
t=ms&k=Sailing&w1=Sailing+schools&w2=Sailing+i
nstruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventure&w6
=Saili
ng&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg>
YAHOO! GROUPS LINKS
group "freedomyachts2003
http://groups.yahoo.com/group/freedomyachts2003
" on the web.
unsubscribe from this group, send an email to:
<mailto:freedomyachts2003-unsubscribe@yahoogroups.com?
subject=Unsubscribe>
Yahoo! Groups is subject to the Yahoo!
http://docs.yahoo.com/info/terms/
Terms of Service.
