Hey there just looking for some advice on switching out the camber spar to a continuous line furling system. Has anyone done this? Pros and cons please
Thanks for your input
Cheers
Jason
Cheers
Jason
May I ask why you want to do this? You seem to want to do away with one of the wonderful aspects of a Freedom. Running wing-on-wing is absolutely great.
[quote=GeoffSchultz post_id=55920 time=1704664580 user_id=53]
[/quote]
I agree with Geoff, I have no opinion on the conversion proposed, but properly set up wing on wing is magic and simple magic at that.
I have a difficult time getting the headsail down and up as the camber bracket on the stay gets stuck all the time. I have to go up and physically pull it down.
Hi Jason, I had a similar challenge and installed a down haul line that is affixed to the head of the jib and runs freely along the forestay through a block at the tack and then back to the cockpit. I just release the jib halyard and pull in the down haul line and the jib falls nicely onto the camber spar. Works like a charm with little effort.
We have experience with Freedoms with camber spar jib and non camber spar jib. Our 1990 45cc is set up with non camber spar self tacking headsail on Seldon furler and our 1990 Freedom 32 (Mull) is set up with original camber spar jib.
Freedom 45 with self tacking non camber spar jib:
Freedom 32 (Mull) camber spar jib:
Like everything, there are compromises! Tom
