We are starting the process of converting our Freedom 40’ cat ketch from her original 1983 two ply wrap around sails to full batten, “roachy” sails set on a sail track mounted to the carbon fiber masts. We are working to generate a new sail plan, wishbone dimensions, reefing set-up, deck layout etc.
Can anyone with a similar set-up (sail tracks fastened to CF masts) describe or comment on the following;
a.) Type, dimension and manufacturer of the sail track used. We understand that a Metalmast extrusion with a wide flanged base may have been used by the factory but Metalmast is no more and those products are no longer available.
b.) The type and composition of the fasteners used (e.g. Monel rivets vs SS machine screws in a tapped hole, etc.)
c.) Was any supplemental fixation to the mast via epoxy, Plexus, 5200, Sikaflex etc., used?
d.) Were any precautions taken to reduce the possibility of corrosion between fasteners and CF masts?
e.) Does anyone have practical experience with the Antal HS22 sail track? for this application?
f.) Has anyone had any problems with their metal sail track/CF mast combination that we should be aware of before we start our project?
Finally does anyone know how CF mast builders (Hall, GMT Composites, etc.) or boat builders (Wyliecat) handle this particular problem?
Thank you in advance for any comments or suggestions you might have and for sharing the benefits of your collective wisdom and experiences.
Rick Wright
aka “Tatoosh”
Freedom 40, cat ketch #63
Currently on the hard at Onancock, VA
