corrosion of aluminum toe rail
I have several places where the bolts that attach the stanchions to the toe rail have corroded the aluminum. I do not want to replace the toe rail. Are there any fixes that would prolong the life of it? Has anyone removed the stanchions and rebolted them, perhaps with sealant to help insulate the SS from the aluminum? Can corroded aluminum be repaired?
Paul
Svbagatelle, Freedom 30 #58.
to prolong the life of anything ali , including toerails, any stainless must be isolated from the ali , and the anodising must be protected from damage or pitting starts. a piece of mylar sheet placed under fittings and zinc chromate paste such as duralac on bolts
also wichard do special d rings for toerails with a plastic insert alo lahings ad webbing strops can be used instead of shackles. alo if you can remove them and rub them back to bare metal you can have itims anodised again
hope thats some use,
phil
thanks Phil, that’s very helpful.
Paul
Same issue, additional question:
Is it advisable to also work on the hull/deck through bolts in the vicinity of this? I wonder if it would be good long-term measure to overdrill and epoxy fill this whole then replace the hull/deck/toe rail bolt.
  • any issues with removing a small section of hull/deck bolts? tightening torque specs?
  • is it possible to loosen a few adjacent hull deck bolts to wedge the toe rail up to clean the surfaces under toe rail and then re-bed with sikaflex or similar at the area of corrosion?
goal is to stop further corrosion and make these localized areas as resilient as possible but without removing entire toe rail or compromising hull deck joint.
thanks !
