Posted by Mac Mendelsohn (sylvanm@…>)
Ed - I will graciously extend the offer to the group. The yard will still charge you, but it least the mooring will get taken.
BTW - We will be coming back Monday this weekend. Mac
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com]On Behalf Of Edward ReissSent: Friday, June 30, 2006 1:32 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Re: Cutty Hunk and a Freedom 35 Wing Keel
Mac, is that offer only to Lance or can other’s take advantage of your empty mooring?
Ed Reiss
On 6/29/06, Mac Mendelsohn <sylvanm@…> wrote:
Thanks Lance - Apsara is summers right in Quissett Harbor so we go to Cuttyhunk a lot. We get there early and have always grabbed a mooring. This is exactly the information I needed on the pilings. Quissett is a great lazy harbor.
BTW - Our mooring is just outside the inner harbor at Quissett right next to a real “junk.” We keep a small yellow inflatable on the mooring to mark it when we are away. If you ever need a mooring in Quissett and Apsara is gone, feel free to pick-up the one with the yelllow dingy.
Cheers, Mac
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com]On Behalf Of lance_ryleySent: Thursday, June 29, 2006 8:01 AMTo: freedomyachts2003@yahoogroups.com Subject: [freedomyachts2003] Re: Cutty Hunk and a Freedom 35 Wing Keel
Hi Mac,I was in Cuttyhunk almost exactly a year ago with Bright Star, which has a draft of 4.5 with the board up. Being 40’ long, you get warned by well-meaning people a LOT. We stayed on a piling (one of the outer ones) right next to a lovely couple on a Nonsuch 36. The trick with the pilings is the approach - a good portion of the water between the pilings and the mooring field has a ‘hump’ of muck that is pretty shallow. The approach into the pilings is probably best by following parallel to the docks, then cutting northish over to the pilings.There isn’t much room to anchor inside the harbor any more, but there’s still good holding ground outside the harbor, north of the breakwaters. Just look at your charts. As I recall there is one nasty boulder lurking just off the beach, but Shenandoah regularly anchors out there.Have fun!LanceBright Star— In freedomyachts2003@yahoogroups.com, “sitchmo” <sylvanm@…> wrote:>> I have been searching high and low for this information so I thought I> would ask this group. We are planning to go the Cutty Hunk for the 4th> of July weekend. We just bought a 1993 Freedom 35 wing keel which we> love and we are considering grabbing a pole just west of the mooring> field and north of the dock. I cannot find anywhere the charted depth > for the pole area and wanted to see if anybody has ventured forth> here. The 35 is advertised at drawing 4.5 feet, but I still have no> idea if there is enough water.> > Thanks - Mac>
– Ed Reiss781 771-2727
