Posted by reedjayt2004 (reedjayt@…>)
Has anyone replaced the bulb or the entire light fixture on the
forespar deck light on a freedom 35? This unit is attached to the
forward part of the mast about 1/3 of the way up the mast. The bulb
doesn’t seem to come out easily and the fixture is rivited to the mast.
I went up yesterday, but it was too windy to stay up very long. Any
advice would be helpful before I go up again to investigate.
Jay Reed
If it’s the same fixture as my Hoyt32, the bulbs have a tendency to corrode in the socket, and are sometimes very hard to get out. You can spray it with something like WD-40, or some type of “easy-out”, but if you do try to remove it with your fingers, use gloves, the bulbs will break. You may have to resort to using longnose pliers. That will break the bulb, and you can remove the remaining socket. Also before you put the new bulb in, wrap a dowel with 220 sandpaper and polish out the rust and corrosion, spray it with WD-40 (or something?), and away you go.
Luck…PWM reedjayt2004 <reedjayt@…> wrote:
Has anyone replaced the bulb or the entire light fixture on the forespar deck light on a freedom 35? This unit is attached to the forward part of the mast about 1/3 of the way up the mast. The bulb doesn’t seem to come out easily and the fixture is rivited to the mast.I went up yesterday, but it was too windy to stay up very long. Any advice would be helpful before I go up again to investigate.ThanksJay Reed__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Posted by George E. Herchenroether (g.herk@…>)
Spray with
BOSHIELD…and all the other connections on the boats.
E. Herchenroether
4
Bush St
Newport, RI 02840
401.847.2028
401.338.5329
mobile
One other thing, you might want to meter the socket while you’re up there, you wanta make sure that it is really a dead light, right?
Do You Yahoo!? Yahoo! Small Business - Try our new Resources site!
Sometimes you can get out a base of a broken bulb by jamming a wine cork in it ,and turning. Boeshield does work,but I’d try silicone caulking the fixture so it wont leak.
Sent: Tuesday, May 31, 2005 5:10 PM
Subject: Re: [freedomyachts2003] Deck light on Freedom 35
Is this Boeshield T9 that you’re referring to? Do they have a website? I’d like to get some spec’s on the product.
Thanks…PWM"George E. Herchenroether" <g.herk@…> wrote:
Spray with BOSHIELD…and all the other connections on the boats.
4 Bush St
Newport, RI 02840
401.847.2028
401.338.5329 mobile
Posted by linsey johnson (linseyjohnson6@…>)
Cheap way that works well, is a jar of vaseline, generously lube all your light sockets, shouldn’t have any problems after that.
Sent: Tuesday, May 31, 2005 6:54 PM
Subject: RE: [freedomyachts2003] Deck light on Freedom 35
4 Bush St
Newport, RI 02840
401.847.2028
401.338.5329 mobile
Do You Yahoo!?Yahoo! Small Business - Try our new Resources site!
I use a silicone grease to keep lightbulbs clean and well conducting.
— In freedomyachts2003@yahoogroups.com, Paul McFadden
Luck…PWM
bulb
mast.
Any
Jay Reed
Yahoo! Groups Links
To visit your group on the web, go to:
Service.
Do You Yahoo!?
Thats the stuff-in hardware stores
4 Bush St
Newport, RI 02840
401.847.2028
401.338.5329 mobile
