These pumps are generally in rural (farm) areas, and places where
heavy equipment is regularly towed around on trailers. We have a big
pine-lumbering business in the area (and a stinking paper-making
plant, too) which require a lot of off-road logging contraptions. Herm
At 02:54 PM 11/23/2008, you wrote:
Ok,
Two points reiterated. Most tanks have baffles that have to be
taken into consideration when polishing fuel or cleaning them. And
the red dye used for “off-road” diesel is also present in diesel
sold in marinas for the same reason that it does not have road tax
applied to it, although in most states sales tax still applies.One additional point. If you are about to take that cover plate off
your tank, do yourself a favor and index it. Most of the time the
screw holes are not evenly spaced so there will be but one way to
re-install it. You can index it yourself easily with a line drawn
across it with a sharpie pen or two arrows etc…Now I need to find a cheap fuel dock or an off-road pump in the
Annapolis area before the prices go back up!George
— On Sun, 11/23/08, Herman and Gail Schiller
<hschiller2@…> wrote:
Subject: RE: [FreedomOwnersGroup] Re: Diesel Engine
Date: Sunday, November 23, 2008, 2:45 PMHey, my fuel is red; I buy it at an “off-road” pump about 6 miles
away from my home. Your fuel might have been bought at such a pump. HermAt 10:01 AM 11/23/2008, you wrote:
Most Freedoms have an access port in the top of the fuel tank. This
should be removed and the debris agitated as the fuel is being
polished. Polishing is not a quick process and takes time, that is
why it is expensive when having it professionally done. I will be
polishing the 30+ gallons in my F32 myself using a borrowed
polishing system which is basically a Racor 500FG filter assy, an
RCI technology fuel purifier and a fuel pump, I expect to run this
system at least 4 to 6 hours. After polishing I will use a ‘cetane’
booster to improve the combustability of the fuel.The fuel in my tank was thought to be at least 3 years old when I
bought the boat in June, it almost looked like dyed ‘off-road’
fuel. I had considered just disposing of the fuel and cleaning the
tank by hand, the disposal of the old diesel would be a bit of a
problem though.
mailto:FreedomOwnersGroup%40yahoogroups.comFreedomOwnersGroup@
yahoogroups. com
[mailto:FreedomOwnersGroup@ yahoogroups. com] On Behalf Of DAVID HEAD
Sent: Sunday, November 23, 2008 9:24 AM
To:
yahoogroups. com
Subject: Re: [FreedomOwnersGroup ] Re: Diesel EngineLast year my boat suffered a near terminal dose of bad fuel. Tried
all the so called remedies but in the end the only solution was to
fully drain the fuel into approx 25 litres containers and allow the
fuel to settle. The sediment eventually does drop to the bottom. The
fuel tank was only capable of being cleaned by cutting a lid into
the top and very carefully removing the considerable amount of algae
that had accumulated. Thereafter the clear fuel was decanted into
the fuel tank but leaving approx 2 - 4 litres in the container that
was then again allowed to settle. I only lost about 10 litres out of
225 litres. New in line filters were fitted as well in time the
engine fule filter. No problems after this seasons use. Beware
claims for fuel polishing as the problem will almost certainly be
residual crud in the bottom of the tank that no fuel polishing
will ever cure.David H
<mailto:amarsib@aol. com>mailto:amarsib%40aol.comamarsib@aol.
com" <mailto:amarsib%40aol.comamarsib@aol. com>
To:
yahoogroups. com
Sent: Sunday, 23 November, 2008 2:14:03 PM
Subject: Re: [FreedomOwnersGroup ] Re: Diesel EngineI have used a fuel “polishing” filter system made by algae-x, it
worked well once I was able to get to the lowest level of the tank-
that is where all the water and crud was.Sent via BlackBerry by AT&T
Date: Sun, 23 Nov 2008 13:23:52 -0000
To: <FreedomOwnersGroup @ yahoogroups. com>
Subject: [FreedomOwnersGroup ] Re: Diesel Engine–Yes, and i was taught how to bleed the engine…and that is when we
found the crud.Wondering if others have had the flush out and cleaning of the fuel
with good results?Lola F30 1987
