Mike:
I actually hear it, and then confirm the change on the tach. On my Freedom, I can’t see the darn tach unless I bend down to look at it. (Project number 394756, Series D, is to relocate the instrument panel so you can actually see it while at the helm.)
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Mike BergeronSent: Sunday, June 11, 2006 7:57 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Diesel question
I had the same problem with mine a couple years ago. It turned out to be a loose tachometer wire on the engine. Do you actually hear the engine speed changing, or is it just on the tach?
Mike
Sent: Saturday, June 10, 2006 10:18 PM
Subject: RE: [freedomyachts2003] Diesel question
I have three fuel filters, the original Fram, with a 30 micron, a Racor with a 2 micron, and the Tanmar, also 2. I change them regularly but I’ll be darned if I can tell whether or not they’re actually clogged. They usually look pretty clean to me.
Just from curiosity, if a filter is clogged, why would it pass 3000 rpm worth of fuel at some times and less fuel at others?
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Larry StrouseSent: Saturday, June 10, 2006 9:50 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] Diesel question
Check your fuel filter, both the inline yanmar and the Rayco if so fitted.
Capt. Larry E. Strouse72 Forest Green DriveMandeville, LA 70448985 674 1672 Home504 835 8505 Office504 382 6078 Cell
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com]On Behalf Of ajlormanSent: Saturday, June 10, 2006 4:38 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Diesel question
My otherwise quite reliable Yanmar 2GM20F began to behave a bit oddlyon my recent cruise. Sometimes, not always, I would set the rpm for2800 and after holding that for a while it would slow down to 2500. Sometimes it would rev up again on its own; sometimes not. Once thispattern started, it seemed to continue, though the periods of up anddown varied in lenght. The rpms during this behavior generally rangedbetweem 2500 and 3000. I assume, perhaps incorrectly, that if it werea fuel problem, it would go down and stay down, or even die. Any suggestions before I call in a pro?Many thanks.Al LormanF30 Ab Initio
IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisor
IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
