Has anyone used a boom brake of any kind to slow and control the
boom when jibing? Charlie
Well…I’m Dutchman myself, and I just reel in the sheet as far as
I can before and during the gibe. After the boom comes across, I
just let go of the sheet. The friction in the sheet blocks is enough
of a brake, you just have to make sure that the sheet is reeled in
quite a bit.
michel
— In freedomyachts2003@yahoogroups.com, “Charlie L.”
Thank You Michel. I have been using “your” Dutchman method for many
years (decades) on many types of boats, and have experienced some
dangerous and nearly catastrophic situations when jibing (sometimes
intentionally–sometimes unintentionally), especially when racing
ALONE on my F21, and now my F25, downwind in high winds and
following seas; and/or rounding marks with other boats on both sides
of me, as I hold the tiller in one hand (or between my knees) and
jibe the main and tack the jib. I read about the “Dutchman Boom
Brake” in Practical Sailor, which highly recommends it for safety
and control reasons, and wondered if any sailors in this group have
used it, and with what results. This is my second posting of this
question, and you are the first sailor to reply. So, thank you for
your response, and I hope others will follow. Charlie
— In freedomyachts2003@yahoogroups.com, “Michel Capel”
as
enough
quite a bit.michel
<clivaday@y…> wrote:Has anyone used a boom brake of any kind to slow and control the
Posted by akusinitz (akusinitz@…>)
I have an F-33 not the wishbone wraparound rig. The main is at the
bow making rigging of a brake or preventer a bit tricky.
I have had some unintentional jibes due to land effects that I
wasn’t paying enough attention to. These were in areas where there
was constant jibing or tacking due to narrow areas plagued by
shifting winds so I did some research on what’s available.
In addition to the dutchman which seems the most popular a few
others seemed to have some advantages over the dutchman. I haven’t
used any of them but here’s the info:
http://www.boomlock.com
http://www.svhotwire.com/boombrake.html
The first one looked very interesting with one control line. There
are two models and one is quite pricey. I have their manual but I
believe the info is on the website.
On my old sloop I would sometimes use 2 vangs one on each rail and
control lines to the cockpit. I’m still considering this might be
the best approach as then there’s no big piece of hardware hanging
under the boom to hit your head on. I use shock cord and similar
stuff just as a cushion for the preventer from the rail.
In tight quarters or with shifty winds the brakes would sure make it
easier.
Alan
many
(sometimes
sides
have
your response, and I hope others will follow. Charlie— In freedomyachts2003@yahoogroups.com, “Michel Capel”
<mike_c_f35ck@y…> wrote:Well…I’m Dutchman myself, and I just reel in the sheet as
far
as
I
enough
in
quite a bit.michel
Thank you Alan! I had heard of the Dutchman and Heinson designs, but
not the two you referred me to. Very interesting and informative.
Now, if we can hear from someone who has actually used a boom brake
on a Freedom-or any other boat??? Or maybe even invented their own?
Charlie
— In freedomyachts2003@yahoogroups.com, “akusinitz”
http://www.svhotwire.com/boombrake.htmlThe first one looked very interesting with one control line. There
believe the info is on the website.On my old sloop I would sometimes use 2 vangs one on each rail and
stuff just as a cushion for the preventer from the rail.In tight quarters or with shifty winds the brakes would sure make
it
easier.
Alan— In freedomyachts2003@yahoogroups.com, “Charlie L.”
<clivaday@y…> wrote:Thank You Michel. I have been using “your” Dutchman method for
many
some
(sometimes
racing
sides
safety
have
this
for
far
as
across,
I
enough
reeled
in
quite a bit.michel
“Charlie L.” <clivaday@…> wrote:
Thank You Michel. I have been using “your” Dutchman method for many years (decades) on many types of boats, and have experienced some dangerous and nearly catastrophic situations when jibing (sometimes intentionally–sometimes unintentionally), especially when racing ALONE on my F21, and now my F25, downwind in high winds and following seas; and/or rounding marks with other boats on both sides of me, as I hold the tiller in one hand (or between my knees) and jibe the main and tack the jib. I read about the “Dutchman Boom Brake” in Practical Sailor, which highly recommends it for safety and control reasons, and wondered if any sailors in this group have used it, and with what results. This is my second posting of this question, and you are the first sailor to reply. So, thank you for your response, and I hope others will follow.
Charlie— In freedomyachts2003@yahoogroups.com, “Michel Capel” <mike_c_f35ck@y…> wrote:> > Well…I’m Dutchman myself, and I just reel in the sheet as far as > I can before and during the gibe. After the boom comes across, I > just let go of the sheet. The friction in the sheet blocks is enough > of a brake, you just have to make sure that the sheet is reeled in > quite a bit.> > michel> > > — In freedomyachts2003@yahoogroups.com, “Charlie L.” > <clivaday@y…> wrote:> > > > Has anyone used a boom brake of any kind to slow and control the > > boom when jibing? CharlieThe Walder boom brake is excellent. Andre F25Post your free ad now! Yahoo! Canada Personals
