f-25 head room
Posted by bobdilk (bob.dilk@…>)
What is the approx head room in the main cabin of an F-25?
thanks
Bob
Posted by Barbara Campbell (barbaranadinecampbell@…>)
Its right around 5 ft.bobdilk <bob.dilk@…> wrote:
What is the approx head room in the main cabin of an F-25?thanksBob
Posted by Simon Dubberley (simon@…>)
Bob,
The answer is not enough. It’s O.K. if you are under 4ft-6" tall but is anyone!
Simon
Sent: Friday, October 07, 2005 12:18 AM
Subject: Re: [freedomyachts2003] f-25 head room
Its right around 5 ft.bobdilk <bob.dilk@…> wrote: What is the approx head room in the main cabin of an F-25?thanksBob
Posted by ed lawrence (hrscrk@…>)
Thanks for responding to my inquiry regarding the Freedom 25, about which I am writing a review for Good Old Boat Magazine.
I’m particularly interested in information about the manner in which you use your boat; areas in which you sail; typical conditions; the livability of the vessel; quality of the construction; performance; and any changes or improvements you’ve made or would suggest; and, last, problems.
To that end, you will find below a laundry list of questions, some of which will not be relevant to a free standing rig.
how long have you owned your boat?hull #?
how many days per year do you use it?
______
what type of sailing: ocean, bay, lake, coastal cruising?_________
location (e.g. San Francisco, Chesapeake, Europe, etc) ?__________
typical wind conditions_________
weather conditions?______
what’s the worst condition in which you sailed, and how did she fare?____________
Performance:
how would you describe the boat’s performance, relative to other boats of the same size_______________________
upwind speed__ what is the most efficient point of sail on a beat to weather? maximum speed you’ve achieved
reaching speed and performance (90 degrees)
______ maximum speed______________________
downwind speed and performance(120 – 140 degrees)_ maximum speed __
comments:
are you satisfied with overall performance?:
___________
seaworthiness (ability to handle wind and seas)______________________
stability (resistance to heeling)­­­­­­­­­­­­­­­­­­­­­­­­­­­­___
How soon do you have to reef the main or shorten headsail?
comments:___ _______
balance (degree of weather helm)__ __
if she has weather helm, how do you balance her?
comments:____ ____
How often do you use the spinnaker? Do you feel the pole/sheets arrangement is easily workable, or a handicap?
speed under power__ __
Maneuverability. Is she easy to back up?_______ Will she turn in a boat length?
comments:_____ ______________
Construction
strength of hull, deck, rudder, etc.
Any problems with delamination?________________
leaks at hull - deck joint, ports, chainplates? How did you solve the problem?
­­­­­­­­­­­­­­­­­­­­­­­­____________________
has the bottom blistered?How extensively? Type
of repair made?Cost?
quality of mast, boom
Has the mast been replaced?
comments
standing rigging: wire vs. rod, quality; has it been replaced?
comments:
__ _____
cosmetics, wood joinery, finish trim, gelcoat, etc. Do doors and drawers close properly; do wood edges fit cleanly?
comments______ ____________
Livability
size of berths; how many can you sleep comfortably?
comment:_____________________________________
sitting comfort in main salon; how many can you feed comfortably?
size of galley/ layout, equipment__________________________
size of head/layout, equipment________________________________
cockpit size, comfort _________________________________
general comments regarding livability_________________________________
Mechanical
engine size and type?suitability for this size boat?__
typical motoring speed____________________
What factor had the most to do with your choice of this boat?______________
What was the approximate purchase price?Current value?
What suggestions or comments that might be of help to someone considering purchasing this boat?
May we call you to discuss this in further detail?_
your name__
Tel #____
Thanks again for your assistance!
copyright ed lawrence, horsecreek productions, inc., 1999
Sent: Thursday, October 06, 2005 5:18 PM
