F 30 alternator wiring and upgade questions
Posted by seychellois_lib (seychellois_lib@…>)
As my cruise durations have increased and the number of hours I spend
steaming has decreased I’ve found that my electrical system is no
longer meeting my requirements.
I have the standard self regulated 55 Amp alternator originally
delivered with the boat it charges a wet cell start batt and a wet
cell house of about 75 AH capacity. Using the 50% discharge rule I’ve
got about 32 AH to work with (at best) which just isn’t enough.
So, I started researching an upgrade and, as these things tend to do,
it just got bigger and bigger. I think I finally have a complete
system designed. it consists of:
2 banks (start and house)
1 ea AGM 110 AH start (could go smaller but want same form factor as
house and some extra amps for emergencies)
2 ea AGM 110 AH house
Xantrex charger with temp sensor for dockside charging - (not used at
all during cruises - I anchor out)
Balmar 7 series 80 AMP alternator + Balmar ARS5 regulator + batt and
alternator temp sensors
Xantrex echo charge (automatically switches off charging to start batt
when it’s reached full charge)
Xantrex link 10 house bank monitor
I have a few questions for a knowledgeable individual re this upgrade.
Some specific knowledge of the F30 would also be useful. I could
answer some of these myself if I had access to my boat but,
unfortunately it’s 1000 miles away.
  1. Can anyone confirm whether the standard Guest switch supplied with
    86 vintage F30s was designed to interrupt the alternator field current
    when inadvertently switched to the off position? Not sure about this
    given the OEM alternator is self regulating.
  2. Regarding alternator output (I know this sounds like a stupid
    question) How does the alternator output get back to the Guest switch
    once the engine has been started? I can not remember seeing a separate
    cable from the alternator to the switch (although I am sure it does
    get routed through the switch). Is there a “bus” cable between the
    start motor and the alternator at the engine which allows the use of
    the same cable to supply current via the battery switch to the start
    motor when starting and then provide alternator output current via the
    battery switch to batteries when the alternator begins to rotate just
    after starting? The reason I ask is that Jack Rabbit Marine where I
    plan to buy most of the gear) recommends routing the output of the
    alternator directly to the house bank and installing the “echo charge”
    unit between house and start so that the start battery, which rarely
    discharges more than a few amps, is not subjected to the full house
    bank charge cycle needed after a day or two on the hook when the house
    bank is down to 50% charge.
  3. Any comments on my upgrade plan?
Mike
F30 Jacqueline
We’ve taken a different approach on our current boat. The new LED
technology has greatly reduced current draw for lighting. Solar is
cheaper than it used to be. Instead of a conventional marine
refrigeration system I’m going with a very small self contained unit
that will use a fraction of the energy and cost less than even a
cheap AdlerBarber system. So we’re investing in reducing demand as
opposed to investing in maintaining a larger supply.
When we had our 39 we had a nice 440A bank and all the proper gear to
charge and monitor. It gave us 3 or 4 days between charging. We hope
to achieve the same thing with our planned setup.
My only suggestion for the ideas outlined below would be to use an
inverter/charger as opposed to just a charger. The cost difference
isn’t too much and you’ll appreciate having the AC if you ever need
to charge your Makita batteries while away from the dock.
— In freedomyachts2003@yahoogroups.com, “seychellois_lib”
spend
I’ve
do,
at
batt
upgrade.
    with
    current
    switch
    separate
    just
    charge”
    house
Mike
F30 Jacqueline
Posted by svbagatelle (svbagatelle@…>)
Mike,
interestingly enough, I have been planning a refit and upgrade of my
electrical system on much the same lines. I would love to compare
notes as to suppliers and prices, etc. You can email me for details.
I also want a larger house bank, as I plan to install Frigoboat
refigeration in the existing ice box. I am planning on a 2 G27 AGM
house bank, but I have been convinced that I could mix them with a
Optima starting battery using the EchoCharge or an Ample Power
combiner. I am thinking of a 100A alternator either from Ample or
Ferris, and the NextStep regulator or ARS5 , respectively. I think I
will go with temperature compensation, though one respected dealer
has recommended against it (because of sensor failures) unless the
battery compartment is small and not well insulated. I assume that
you like me will use the existing compartment, where 3 G27s just fit,
if you put the new AC charger on the bulkhead rather than at the
bottom.
As for battery monitor, I have not decided between the older Link
10 and the newer XBM, or a more sophisticated (and expensive) Ample
Power Energy Monitor. I am looking at the Truecharge 20 with
temperature sensor for shorepower charging.
I also plan to use solar panels (perhaps as many as 2 Kyocera 85
watt panels, if I can get them for a reasonable price) with solar
regular, and to replace my cabin lights with compact fluorescents and
LEDs. I have ordered one reading light from Taylor Brite to try it
out first before replacing the others. This should reduce consumption
by 1A per light. I am also rewiring and installing a new DC panel at
the first stage, then putting in the alternator, refrigeration,
battery monitor and charger when I haul out in Florida in June.
I have decided after long research not to install a windlass, since
in the Bahamas I anchor in shallow waters. Instead, I am going to
remove shackles and splice the line to the chain to make it easier to
haul the rode through the bow roller.
Good luck!
Paul
Mull 1987 30/32 “Bagatelle”
spend
I’ve
do,
at
batt
upgrade.
    with
    current
    switch
    separate
    just
    charge”
    house
Mike
F30 Jacqueline
Its taken me awhile but finally have the upgrade put together - not
installed yet - but all the bits and pieces are assembled for my
upcoming trip to do the install. here’s what I finally went with. BTW,
all equipment bought from Jackrabbit marine except for AGM’s which
were a terrific bargain at <invertersrus.com>. Low price and shipping
was free!!.
3 Lifeline 105 AH AGMs one will be used as starting batt but has ample
reserve to provide some emergency power to the house if ever necessary.
Balmar 7 series 80 amp alternator
ARS 5 regulator, batt and alternator temp sensors
Truecharge 20+ charger + batt temp sensor (plus 2ea. 25 amp surface
mount circuit breakers between charger and batteries - hidden
requirement in the installation instructions)
Xantrex XBM batt monitor + batt temp sensor, house bank only
Echo charge start batt charger - hooked up to house as source during
steaming.
Blue seas 8080 battery isolator switch to replace standard guest 1, 2,
both, off battery switch.
When I install I plan to run the alternator output directly to the
house bank (currently routed through the Guest switch) True charge
will keep the start topped up while at sea and charging from the
alternator.
The primary advantage of all this is the additional power available in
the house, my ability to monitor what I consume, and improved charge
performance which I need because I’m simply not steaming much these
days. The disadvantage is the added complexity, more things to go
wrong, etc. I do carefully watch what power I use, I have no
refrigeration or other big consumers, worst offender is my laptop
which I use for navigation on the go and movies on the hook.
I think I’m going to give the new LED sensibulbs a try in my most used
lights to cut them back as well but have not done this yet.
— In freedomyachts2003@yahoogroups.com, “svbagatelle”
<svbagatelle@…> wrote:
Mike,
bottom.
Good luck!
Paul
spend
I’ve
do,
at
batt
upgrade.
    with
    current
    switch
    separate
    just
    charge”
    house
Mike
F30 Jacqueline
