I presently store my 9’ inflatable upside down on the foredeck. I
would like to install a davit system on the stern, however, those of
you familiar with the F-40 CK know we have a boomkin with the
asscoiated bob-stays (?). In my mind I have three options;
Leave things as they are and continue wrestling the dinghy on and
off the foredeck. -
Remove the bob-stays (rigging that holds the boomkin down) and
install some stainless steel brackets against the transom and boomkin
to take the vertical and side stresses imposed by the mizzen sheet.
Indoing so, I could raise the dinghy up to the bottom of the boomkin.
But that may not be high enough when the seas are up and the boat is
heeling. -
The most radical idea is to remove the factory boomkin (stays and
all) have a new stainless steel combination davit-boomkin,custom made.
The aft end of this davit/boomkin would be elevated approx 2 - 3 feet
above the position of the existing boomkin. Similar to an arch
arangement, with the mizzen sheet attached at this new elevation. The
construction would have to be substantial enough to take the loads
Obviously, I’m concerned about destroying the astetics (sp) of this
beautiful design, so I do not want to get too extreme.
But, due to back problems I cannot continue lifting the dinghy over
the side of the boat. Having a dinghy suspended by davits has always
been my choice on past boats I’ve owned. And, I am aware of the
potential problems hanging one in bad weather. I just thought I give
you all a give me a reality check!!
Jay
