The white plastic inside the spinnaker gun mount of my just-acquired F25 was broken up and it was really tough to get the pole to slide through. I removed the mount, knocked out what was left of the 1/8" thick plastic and epoxied some similar-thickness, synthetic carpeting in it’s place. After a generous application of “Liquid Rollers” (a spray used to lubricate boat trailer bunks that I happened to have on my garage shelf
) to the “carpet bushing”, the pole now slides through easilly (without any rattles).
Now it’s time to put it all back together on the boat, rig it up and sail! :mrgreen:
How did that work for you?
I’m 3D printing a new sleeve.
What filament material are you using?
Oh interesting - 3D printed PETG could work well, though I’d be worried about the increased friction of the full tube. Though maybe it’s better since it distributes loads better? How will you secure it in the gun mount?
I personally used UHMW strips (https://www.mcmaster.com/catalog/7701T91). It was pretty easy to cut them to the length of the tube, drilled and countersunk 1/4" holes, and used nylon bolts to secure them (https://www.mcmaster.com/catalog/92929A222 and https://www.mcmaster.com/catalog/94922A325). Not the cheapest solution though once you factor in shipping. $18 for those nylon cap nuts is absurd, but I guess McMaster never claimed to be affordable.
3 years in though and it’s still working perfectly.
PLA+ . I finally have the boat in the water, and will be installing the spinnaker pole soon. It seems to stay in the metal tube just fine, but of course we’ll see.
There are several suggestions for gunmount lining repair in the ARCIVES of this site.
Here’s one: https://www.freedomyachts.org/viewtopic.php?f=63&t=9831&p=38715&hilit=GUNMOUNT+REPAIR#p38715
My PLA tube has shifted a small amount, maybe 1/2". The problem with it is that it isn’t very slippery, whereas the original nylon ought to slip much better. maybe I need to line it with some teflon tape?
That’s not a really big deal, as I can center the tube while still at dock, and then rotate it when we’re out on thee water.
