I know this is a load question and depends
on many different things but does anyone know the original prop size on the F30?
I have a 2GM20F with a 2.61 transmission ratio.
Bob
_
Bob
_
My Mull 28 has an identical engine-transmission pair. It had a 14"
prop with approximately 20-degrees of blade angle. Unfortunately, the
markings (if there were any) on the prop have disappeared, and I
don’t know how to convert degrees of pitch to inches of pitch. I
would hazard a guess that Freedom folks would have been loath to
stock separate props for the two sizes of Mull designs.
BTW, I switched to a 15" 2-blade Maxprop I found at a nautical swap
sale. I installed it with 22 degrees of blade angle, which the PYI
folks tell me is 11" pitch. The result was noticeably better
acceleration, and upwind motoring capability.
Herm
At 07:08 AM 12/14/2007, you wrote:
I know this is a load question and depends on many different things
but does anyone know the original prop size on the F30? I have a
2GM20F with a 2.61 transmission ratio.,.,
Bob
_
On our F30 #12 with the same engine and trans ratio we had a 14 x 14 prop, narrow blade. Fine for easy days, not much for serious pushing. Went to a Kiwi 16 in. three blade. Happy with it. Wrote a complete review on the old Freedom Group.FargoHerman and Gail Schiller <hschiller2@…> wrote: My Mull 28 has an identical engine-transmission pair. It had a 14" prop with approximately 20-degrees of blade angle. Unfortunately, the markings (if there were any) on the prop have disappeared, and I don’t know how to convert degrees
of pitch to inches of pitch. I would hazard a guess that Freedom folks would have been loath to stock separate props for the two sizes of Mull designs. BTW, I switched to a 15" 2-blade Maxprop I found at a nautical swap sale. I installed it with 22 degrees of blade angle, which the PYI folks tell me is 11" pitch. The result was noticeably better acceleration, and upwind motoring capability. Herm At 07:08 AM 12/14/2007, you wrote: >I know this is a load question and depends on many different things >but does anyone know the original prop size on the F30? I have a >2GM20F with a 2.61 transmission ratio. > > > >,., > >Bob > >_ >
