Bob:
Best I recall, the Syntron seal is lubricated by water, not grease. Mine has no grease fitting. The black tube between the seal and the fiberglass tube (the shaft log) is all that is keeping your boat afloat. If it looks suspect, you might try wrapping something strong around it and fixing it with hose clamps as a temporary fix.
I don’t see how the water is draining to the engine sump. On my F30, the Syntron seal is well behind the engine sump and can drain through a small hole in the aft edge of the engine sump into the bilge.
Best of luck.
Al Lorman
F30 Ab Initio
-----Original Message-----From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of BobSent: Tuesday, July 10, 2007 2:29 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: [FreedomOwnersGroup] F30 Syntron Shaft Seal
I have a bigger then a small leak around Syntron shaft seal on my F30. There is a grease fitting which after reading the manual is says to grease once in a while. My question however is what happens if the black tube clamped to the Syntron and the fiberglass tube gives away? What is the damage control? Stuff rugs, etc down the tube to stop the water?? The Ft Myers boat, Nitro, which I bought is on its way back to the upper East Coast and is currently in Key West with some very friends and this is one of many little issues they are trying to deal with. All this water is draining to the sump under the engine which there is no outlet to the bilge. I assume there is no outlet so you are not pumping fuel overboard.Any comments will be welcomed!Bob
