Posted by Dwight (descalera1@…>)
Stick by your calculations Fargo, you correct.
A small pressure over a large area is an example of why hydraulics can be so
powerful.
We are talking pressure here not
weight. The weight of the column of water exerts a pressure per unit area.
For a solid material the shape remains constant, the unit area will remain
constant and the pressure applied to the floor will be the weight divided by
the surface area. If water acted like this, you would be crushed if you
stuck your head 1 foot below the surface of the ocean. 64# per cubic foot
times how many square miles of ocean divided by the surface area of your head,
ouch! Instead you feel the 64# evenly distributed over the entire surface
of your head. You will feel this same pressure regardless of how large the
ocean or small (3/4” dia hose) the body of water is. The deeper you
go the greater the pressure. This is why it is the height of the vent
hose that is important to calculating the pressure. If you open the
faucet and drain the vent hose, approximately 3 fluid oz per foot of hose
length, then this pressure will be released.
This is a drawback to hydraulics.
You can generate great force but sometimes it’s hard to harness it.
Dwight Escalera
Wakefield, RI
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of katorpus
Sent: Friday, June 13, 2008 11:02
PM
To:
Subject: [FreedomOwnersGroup] Re:
F30 water tank issue
Uh…Fargo…not
to be picky here, but you kinda blew the math on
that one…
Assuming static equilibrium (no flow)…
A column of water 33 feet high and 1" in cross section (a very
generously sized vent hose) weighs 14.7 lbs. Divide that by 11 for a
3 foot high vent loop, and you get 1.34 lbs total of water weight
contained in the vent loop.
The weight of that water is distributed (evenly) over every square
inch (or foot) of the sides, bottom, and top of the tank, adding an
infinitesimal amount of pressure to that which is being exerted on
the tank walls, bottom, and top when the tank is just “level full”.
You DIVIDE the weight of the water over however many square inches of
tank area it’s pushing against…It doesn’t add 1.34 pounds to EVERY
square inch of the tank.
Note that atmospheric pressure (14.7 psi at sea level) is disregarded
here, since the same pressure exerted against the top of the water
column by the atmosphere is being exerted against the walls and top
of the tank from the outside of the tank.
It’s just like you standing on your feet. If you weigh 200 lbs and
your foot has an area of 30 square inches, then you are exerting a
pressure of 6.67 psi when standing still on one foot and HALF that
when standing still on two feet. That’s why snowshoes work.
— In FreedomOwnersGroup@yahoogroups.com,
Fargo Rousseau
<fargo_r@…> wrote:
I have been following this thread over the last week but was a bit
distracted. I cannot remember if you have told us where your
vent loop is located. My F30 (#12) vented the water tank
directly into the bilge from somewhere near the top of the tank, with
no elevated portion…as I remember. If we filled the tank slowly
enough, it just filled up the bilge and we never saw water back up
the filler line to the deck level.
I think some F30s had an elevated loop. If the vent
line is elevated a few feet from the top of the tank(let us take 3
feet as an example), then the pressure pushing up on the top of the
tank would be just under 200 pounds per square foot, or more than
1500 pounds pushing up over the whole top of the tank (feet of head
of water divided by 2.3 equals pressure in PSI).
Could this be it???
Fargo
Ex F30 #12
— On Fri, 6/13/08, seychellois_lib mcunningham@… wrote:
Subject: [FreedomOwnersGroup] Re: F30 water tank issue
Date: Friday, June 13, 2008, 10:24 AM
Thanks for the responses. I don’t think I have the
right answer yet.
The tank is definitely coming under pressure as I fill albeit low
pressure I’m sure. it is clearly not static water load because the
top
of the tank is ballooning and I can press down upon the top and feel
strong resistance - similar to a pressurized balloon. I actually
stood
on the tank in an attempt to force water out of the vented loop
overfill with no success. The obvious answer seems o be the vented
loop is plugged or kinked but I seem to be able to blow air through
it. I have filled the tank (poly by the way) many many times in the
past and only began to notice this “pressurization” since I
replaced
the water pump. I am obviously missing something simple, wish I knew
what it was!!
