F32 mast step
Hi all, first time posting, have been using information from forum for some time and very much appreciate this information source. I own a 84 F32 here in Australia, as far as I know the only one here. I’m sold on the whole Freedom rig and enjoy cruising full time on my boat. I recently heard a clunking noise at the mast and found that the bolts that hold the top hat to the the mast step had worked loose. Ive tightened them and have seemed to have solved problem. I noticed the bolt holes in the mast step were slightly elongated Im assuming there not meant to be? is this correct? also the next question is does anyone know what the mast step is built of? Glassed ply or fully glass?
Thanks in advance Dale.
