Posted by johncparent (johncparent@…>)
Finally getting around to replacing shaft - Anyone have a spare shaft
they can measure for me? Mark Edwards found old paperwork stating 56"
LOA with 1/4" key and standard taper, but I shouldn’t trust it.
Looking for confirmation.
Also, anyone know the Cutlass Bearing dimensions? M.E. only gave me
bronze with 1" I.D. I need O.D. and length. Thanks again to Mark!
Posted by paulsebra (paulsebra@…>)
Good Day,
The safest wat to replace the shaft is to take out the old one and give
it to the machine shop … along with the flange to the transmission.
This way the fitting burden is on the shop … if you give them
measurements, the burden is on you.
If you go the measurement route … be sure to measure the distance
from the end of the shaft to the center of the dimples for the se
screws in the flange … also the angles between the keyway and the set
screw dimples(usually 90 degrees, but you never know)
good luck
Paul
