I received new sails and having a little problem with jib.
If anyone has the wishbone boom jib, would you please post photos of both ends of the boom with sail installed?
thanks,
Woody
San Diego
thanks,
Woody
San Diego
What problems are you having?
I went away from the wrap-around sails and now have laced on sails. I have tried various configurations at both ends and currently have mine rigged somewhat like a nonsuch, with some variations.
My crew’s are fixed as are my tacks. The very front of my wishbone are attached to a 2-inch tubular webbing ring around the mast. This attachment is a 3:1 and allows me to manipulate the foot of the sail.
I did configure as original via an outhaul but had problems with the wishbone dipping to low once the topping lift was slacked. That wad my mistake in the measure of the new sails.
3 reefs in the main and 2 in the mizzen. Still working out some of the bugs in the systems. Lazy Jack’s are next
I think OP means the Camberspar, not a wishbone.
If you search the forum for “camberspar” you should find pictures, as well as scans from the manual that show how it’s set up. It’s a little tricky, but I’ve found it works great.
