F40 carbon fibre mast
Posted by muckingabout (muckingabout@…>)
Does anyone know how to find a carbon mast for an F40? The dimensions
are 53 feet length, base diamter 10 inches, top diameter 4.5 inches.
Thanks of you can help, Ian.
Check with Hall Spares, the ones who made (most of) them.
John Ernst
F45
How about GMT - Goetz Marine Technologies ?
I think I’ve got the name right.
John Ernst
F45
Posted by svfantasy@… (svfantasy@…)
----- Original Message -----From: muckingabout To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] F40 carbon fibre mastDate: Mon, 30 Jan 2006 08:15:26 -0000Does anyone know how to find a carbon mast for an F40? The dimensionsare 53 feet length, base diamter 10 inches, top diameter 4.5 inches.Thanks of you can help, Ian.
If you GOOGLE “Carbon fiber masts”, you will find several manufacturers.
Posted by seatimsboat@… (seatimsboat@…)
check this out .
Further to recent posts, we have just completed an 18m/60’ unstayed mast for Visionarry, a 15m/50’ harryproa (www.harryproa.com).
Some details:
Righting moment: 17,820 tonne metres/58,800 ton feet
Mast length: 18m/60’,
Above deck: 16m/53’
Diameter at base: 300mm/12"
Diameter at tip: 100mm/4"
Safety factor: 2.5
Designed weight of bare tube: 119 kgs/262 lbs
Actual weight of bare tube: 117 kgs/257 lbs
Designed deflection with 153 kgs/337 lbs midway along mast: 178mm/7"
Actual deflection with 153 kgs midway along the mast: 175mm/6.9"
Designed tip deflection at capsize: 2.9m/9’8"
Actual deflection at capsize: yet to be established!
Cost of mast painted with top and bottom fittings: $AUS15,000/$US10,800/9,000 Euros
Additional cost for lightweight carbon rcb track bonded on: $2,800/$US2,000/1,680 Euros
regards,
rob
Rob,
Who built this mast for you. The cheapest I could find was well over $ 20,000 US.
Jay
Freedom 40 Hull # 60 “Fantasy”
San Francisco Bay
----- Original Message -----From: seatimsboat@…To: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] F40 carbon fibre mastDate: Tue, 31 Jan 2006 09:42:04 ESTcheck this out .Further to recent posts, we have just completed an 18m/60’ unstayed mast for Visionarry, a 15m/50’ harryproa (www.harryproa.com).Some details:Righting moment: 17,820 tonne metres/58,800 ton feetMast length: 18m/60’,Above deck: 16m/53’Diameter at base: 300mm/12"Diameter at tip: 100mm/4"Safety factor: 2.5Designed weight of bare tube: 119 kgs/262 lbsActual weight of bare tube: 117 kgs/257 lbsDesigned deflection with 153 kgs/337 lbs midway along mast: 178mm/7" Actual deflection with 153 kgs midway along the mast: 175mm/6.9"Designed tip deflection at capsize: 2.9m/9’8"Actual deflection at capsize: yet to be established!Cost of mast painted with top and bottom fittings: $AUS15,000/$US10,800/9,000 EurosAdditional cost for lightweight carbon rcb track bonded on: $2,800/$US2,000/1,680 Eurosregards,rob
Posted by freedom4d40 (jamesmcstay@…>)
— In freedomyachts2003@yahoogroups.com, “muckingabout”
are you speaking of a freedom 40,vintage 70’s or a freedom 40/40 vi
ntage mid 90’s ?
ntage mid 90’s ?
It just occurred to me that it might be worth talking to the folks at
Tartan Yachts. A few years ago they started producing their own carbon
fiber masts. I know for a fact that they do contract work and produce
masts for other boats. If the mast is for a late model 40 I’d talk to
Freedom or to Pedrick to get some design criteria.
— In freedomyachts2003@yahoogroups.com, “freedom4d40”
ntage mid 90’s ?
