Posted by goldbdan (goldbdan@…>)
Our rudder on our F45 has a fair amount of play. She is on the hard
at the moment, and you can grab the rudder and move it about 5 or 10
degrees. Could explain some problems we had last summer.
Anyway, anyone else have this experience and do you know of the
cause and cure? I guess I’m most interested in F45 experiences, but
this surely could occur at on any model.
DG
Posted by Kevin Ogden (kcogden@…>)
Most likely needs new packing in the stern gland. I had similar problem after boat laid up in yard for 3 years (and packing presumably dried out), and not knowing better, assumed it just needed greasing. Did that and all seemed well, but then launched off across Atlantic, and spent next 4 weeks pumping like **** during storms, or tightening up the gland nuts till there was little leakage, but VERY stiff steering. Seem to remember 90 pumps or so on the manual bilge pump every 30 minutes when the weather was rocking and rolling.
Sent: Sunday, December 12, 2004 8:21 PM
Subject: [freedomyachts2003] F45 Rudder Play
Our rudder on our F45 has a fair amount of play. She is on the hard at the moment, and you can grab the rudder and move it about 5 or 10 degrees. Could explain some problems we had last summer.Anyway, anyone else have this experience and do you know of the cause and cure? I guess I’m most interested in F45 experiences, but this surely could occur at on any model.Thanks,DG
Posted by alan kossoff (alan112350@…>)
She is on the hard
summer.
you know of the
DG
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an
email to:
c.. Your use of Yahoo! Groups is subject to the
Yahoo! Terms of Service.
Me, too. We have had water coming up through the
rudder post…twice now…in about 6 years. We had
the yard put in packing…but I guess it’s time again.
It’s one thing to see water down below…if it’s fresh
water…it’s a problem…if it"s salt water is a
PROBLEM. It seems to happen most when we are in heavy
weather…or under full power and the stern is down in
the water.
Do You Yahoo!?
http://mail.yahoo.com
Posted by pelfrey_jerry (jerry.pelfrey@…>)
Kevin,
I am the new owner of a Freedom 38 and just went through a survey
which stated that there was play in the rudder. I contacted Freedom
yachts and they referred me to Warren River Boatworks, Paul Dennis
(?), owner. He use to work for Freedom. Paul explained that Freedom
built in some play in the rudder. Approx. 1 to 2 inches at the
bottom of the rudder blade. He explained that if the bearing was to
tight it could cause the rudder to seize under load. Paul’s phone
number is: 401-245-6949.
— In freedomyachts2003@yahoogroups.com, “Kevin Ogden”
hard
10
but
DG
ADVERTISEMENT
Yahoo! Groups Links
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Thanks, but the excess play was actually causing binding at high heel/loading. IE coming across Bay of Biscay in 45 kts winds, when piched up the rudder would bind in gusts. Had to replace complete stainless rudder post sleeve at bottom hinge point, which was out of round apparently from factory. Maybe this was designed in, don’t know, but replacing this has fixed the leakage & binding problems, and the rudder doesn’t bind anymore, even in severe loading conditions.
Kevin O
Sent: Thursday, December 16, 2004 5:14 AM
Subject: [freedomyachts2003] Re: F45 Rudder Play
Kevin,I am the new owner of a Freedom 38 and just went through a survey which stated that there was play in the rudder. I contacted Freedom yachts and they referred me to Warren River Boatworks, Paul Dennis (?), owner. He use to work for Freedom. Paul explained that Freedom built in some play in the rudder. Approx. 1 to 2 inches at the bottom of the rudder blade. He explained that if the bearing was to tight it could cause the rudder to seize under load. Paul’s phone number is: 401-245-6949. — In freedomyachts2003@yahoogroups.com, “Kevin Ogden” <kcogden@e…> wrote:> Most likely needs new packing in the stern gland. I had similar problem after boat laid up in yard for 3 years (and packing presumably dried out), and not knowing better, assumed it just needed greasing. Did that and all seemed well, but then launched off across Atlantic, and spent next 4 weeks pumping like **** during storms, or tightening up the gland nuts till there was little leakage, but VERY stiff steering. Seem to remember 90 pumps or so on the manual bilge pump every 30 minutes when the weather was rocking and rolling.> ----- Original Message ----- > From: goldbdan > To: freedomyachts2003@yahoogroups.com > Sent: Sunday, December 12, 2004 8:21 PM> Subject: [freedomyachts2003] F45 Rudder Play> > > > Our rudder on our F45 has a fair amount of play. She is on the hard > at the moment, and you can grab the rudder and move it about 5 or 10 > degrees. Could explain some problems we had last summer.> > Anyway, anyone else have this experience and do you know of the > cause and cure? I guess I’m most interested in F45 experiences, but > this surely could occur at on any model.> > Thanks,> > DG> > > > > Yahoo! Groups Sponsor > ADVERTISEMENT> > > > > > ------------------------------------------------------------------------------> Yahoo! Groups Links> > a… To visit your group on the web, go to:> http://groups.yahoo.com/group/freedomyachts2003/> > b… To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
