F45 Storm Sails
Posted by goldbdan (goldbdan@…>)
Anyone know a loft that has made them? Or whether they are useful at
all, considering the freestanding rig? I have a hard time seeing how a
storm jib would work well, but obviously I could be wrong (and probably
am).
DG
Posted by rbrink239 (rbrink239@…>)
— In FreedomOwnersGroup@yahoogroups.com, “goldbdan” <goldbdan@…>
a
probably
am).
DG
I have a storm jib on my Freedom 40/40 sloop riggged boat but have
never pulled it out of the bag to see what it looks like.
Richard
Hi DG,
if your 45 is the standard rig with the camberspar, I’m not sure if a
storm jib would be much use to you. Even with the standard jib down,
it’d be difficult to get the storm jib on above it.
The 45 is a little odd regarding storm sails in my opinion. First,
there is the aforementioned limitation on getting the standard jib down
or off (which isn’t trivial with the camberspar). Also, the boom is so
high that trying to put a trysail on the track would be very difficult
to get on, especially if you waited until you really needed one. This
is because to reach above the main, you have to climb the 4 steps on
the front of the mast, and I can’t imagine doing that in a seaway.
The good thing is that the 45 is essentially a catboat with a jib,
primarily main driven, and not easily overpowered. We’ve been caught
out in 30+ with full main and been able to maintain control (although
it was certainly more manageable once the first reef in.
Our 45 has two reef points, and by ‘design’ they are both supposed to
be single-line reefing. I don’t know if the main we have has deeper
reefs than the originally designed main, but I do know that the single-
line reefing works great on the first reef and is absolutely not
possible on the second reef. This spring, we’ll be switching the second
reef to two lines (which also means adding another rope clutch). If I
were going to go offshore in a serious way, I’d probably add a third
reef (and two more rope clutches to handle it) or just have a main
built with two very deep reefs.)
One possibility for a storm jib would be to have a small jib with a
wire luff that you could rig on the second halyard and tack to the
deck. Drop the camberspar to the deck and lash it down securely and
you’d have a good platform for the storm jib. The other, most expensive
option (which I consider when I forget that money is, in fact, an
object) would be to replace the camberspar jib with a roller-furler.
Replace the camberspar with a hoyt jib-boom, and then you have some
options in terms of how much sail area to have deployed.
Lance
F45 “Glory”
a
probably
am).
DG
Hey Lance,
Sounds like your main has a foot with bolt rope through the
slot and is not loose footed. I had my main “taylored” to be loose
footed and the single line reefing works with both reef points.
Hope your winter is going well in beantown. Did you get
your moisture problem fixed?
Best,
TW
Anoush Koon, Pemaquid…
At 08:33 PM 3/9/2008, you wrote:
Hi DG,
Lance
F45 “Glory”
— In
a
probably
am).
DG
Checked by AVG.
Version: 7.5.518 / Virus Database: 269.21.7/1323 - Release Date:
3/10/2008 11:07 AM
Checked by AVG.
Version: 7.5.518 / Virus Database: 269.21.7/1323 - Release Date: 3/10/2008 11:07
AM
Hey there Lance. Hope you’re doing well. We have a roller furling
jib on F45. I’m toying with the ATN Gale Sail (hanks on “around” a
furled sail). It’s just that because there’s never any tension on
the headstay on these boats, it seems to me that the sole benefit of
a storm jib is that it’s small and made of heavy fabric. Frankly, my
roller furling jib meets that criteria already (which is not so hot
on light wind days, but I guess that’s what the asymetrical is for).
Likewise, we have an in-boom furling mainsail (yeah, we’re lazy), so
we can reef down infinitely from the cockpit. The main benefit of
the trysail would be heavy material and that it’s off the boom. That
actually might make more sense than a storm jib, but you identified
the key issue; absent also installing a separate track, actually
using a trysail will not be so easy, though it would be easier on
ours than yours because we can just roll up the main and the track
then is wide open (no need to remove mainsail slides from a track to
make way for the trysail).
Anyway, I’m curious if anyone’s actually used storm sails on this
boat, even just to practice. I can’t seem to find anyone who has.
DG
— In FreedomOwnersGroup@yahoogroups.com, “lance_ryley”
<lance_ryley@…> wrote:
Hi DG,
a
down,
down
so
difficult
This
on
caught
(although
to
single-
second
I
third
expensive
furler.
Lance
F45 “Glory”
— In FreedomOwnersGroup@yahoogroups.com, “goldbdan” <goldbdan@>
useful at
how
a
probably
am).
DG
DG
Hi DG,
a
down,
down
so
difficult
This
on
caught
(although
to
single-
second
I
third
expensive
furler.
Lance
F45 “Glory”
useful at
how
a
probably
am).
DG
Actually, we do have a loose footed main. The problem is in how the
single line reefing was ‘engineered.’
Not sure how yours is set up, but on Glory, they used a two-block
shuttle in the boom. One line goes from the end of the boom through one
side of the shuttle, back through a sheave in the boom, up to the reef
point, and back down and tied around the boom. The other end of the
line goes from the rope clutch, into the forward end of the boom,
through the other side of the shuttle, back out the forward end of the
boom, up to the reefing cringle on the main, and back down to a dead-
end on the mast.
This system works fine for the first reef, but it doesn’t work for the
second reef. The reason is that the boom simply isn’t long enough to
allow the clew reef point to be brought down tight enough. There are
two solutions I can think of. The first is to go to a true ‘single’
line that goes from the end of the boom all the way to the rope clutch
with no internal blocks, which would mean a fair amount of line. The
other choice would be to break the reefing into two lines, one
controlling the tack and the other controlling the clew.
In either case, I’m adding lightweight blocks to the clew to help ease
the reefing/raising of the sail.
Lance
— In FreedomOwnersGroup@yahoogroups.com, Thomas Wales <twales@…>
Hey Lance,
Best,
TW
In that case, if I were going to go off-shore, I might consider
simply making sure I had sails made of heavy-duty cloth and go with
the ‘infinite reefing.’ one question - do you have running backs for
the asym? If you don’t, you may consider them. Glory has them on the
recommendation of Paul Dennis when the North gennaker was installed.
It’d give you the rig tension you’d need for a Gale Sail.
do you have a jib-boom with the roller furling jib, or is it ‘free-
standing?’
Lance
of
my
so
That
to
DG
