Factory CF tabernacle mast
Posted by Richard (cookieseaman@…>)
I’m considering a shoal draft version with factory tabernacle mast and have a
few
questions. Does the tabernacle joint form a solid fit once it’s stepped? Are
there any
known structural failure risks with this mast? Is the CF mast treated to resist
UV damage
to the resin? I notice that the black CF masts often appear dull as if heavily
weathered, and
some have been painted. Does such weathering lead to mast failure? Given the
cost of
replacement, should a prospective buyer be concerned about a > 20 yr. old mast
failing under normal use? Finally, any advice on assessing the condition of
these masts?
Many thanks for any information you might have. Richard
Posted by mitya fonin (mitbok1@…>)
I have a shoal draft, and the tabernacle caused me some grief last summer. From what I gather boat was sailed in New York harbor and was hitting some ocean swell and waves. I was out in the waves often as well. From all that rocking tabernacle wore off. The mast was noticeably moving back and forth and by the beginning of last years sailing season situation did not seem safe. I have tried to use shims to stiffen the set up but to no avail. Basically the aluminum pipe insert and tube both worn out developing a lot of play. In the middle of the summer I have fused permanently both parts of the mast with fiberglass and epoxy. making it a solid mast again. There seems no other way for me to fix it since tolerances were
different in upper and bottom parts of the tabernacle. I am not the first one to do this fix either. So, if you going to sail in some rocky waters beware of this problem. Also check for play when buying. As far as UV damage, cracks, etc. its all cosmetic. Outer cote of epoxy is not structural. Corbon fiber is hiden safe under it. I painted mine wite last summer. Mostly for looks but this will probably take some sun heat off.
----- Original Message ----From: Richard <cookieseaman@…>To: freedom21@yahoogroups.comSent: Friday, January 26, 2007 10:11:38 PMSubject: [freedom21] Factory CF tabernacle mast
I’m considering a shoal draft version with factory tabernacle mast and have a few questions. Does the tabernacle joint form a solid fit once it’s stepped? Are there any known structural failure risks with this mast? Is the CF mast treated to resist UV damage to the resin? I notice that the black CF masts often appear dull as if heavily weathered, and some have been painted. Does such weathering lead to mast failure? Given the cost of replacement, should a prospective buyer be concerned about a > 20 yr. old mast failing under normal use? Finally, any advice on assessing the condition of these masts? Many thanks for any information you might have. Richard
TV dinner still cooling?Check out “Tonight’s Picks” on Yahoo! TV.
Posted by Doug Chace (ch47_av8r@…>)
How did the paint hold up with the inherent flexing of the mast?
What kind of paint did you use and would you recommend it to others?
(my wife is pleased that we have a mast, but doesn’t want it to be
black/faded).
Doug
other way for me to fix it since tolerances were different in upper
and have a few
Given the cost of
yr. old mast
Now that’s room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
Thanks for sharing your experience with the tabernacle mast. Your comments were
very
helpful in addressing my questions. I’ll definately look out for the wear and
looseness of
the mast when examining a shoal draft F-21. Have to wonder how they get worn
like that.
Is it just a matter of the design and time, thrashing about in rough seas or did
previous owner not shim the mast properly at the deck fitting. I’ve haven’t
seen one of
these, only the photo on this site of the aluminum post with hinged fitting on
top sticking
out of the deck. Apparently, the mast slips over this post and slides downward
until it’s in
position, but how far? If the length is short, it seems as no supprise that wear
could be a
problem. From your description it seems that there is an aluminum sleeve within
the lower
part of mast that forms a sliding fit over the tabernacle post, and the mast
apparently sits
on top of a short CF section which rests in the mast step. Do I have this
correct so far? Do
the tabernacle post and lower CF segment act as a single piece? If I understand
correctly
you joined the two carbon fiber segments with fiberglass cloth and epoxy,
leaving the
aluminum tabernacle post within the mast? It seems that your repair solves the
loose mast
problem, but it might eventually kill the quick and easy trailer sailing deal I
have in mind.
Regards, Richard
From what I
waves. I
The mast
season
to no avail.
play. In the
fiberglass and
since
tolerances were different in upper and bottom parts of the tabernacle. I am not
the first
of this
all
cosmetic. Outer
painted mine wite
few
there any
resist UV damage
weathered,
cost of
these masts?
________________________________________________________________________________\
Posted by Patrick Weaver (patrick@…>)
Richard,
On Max’s “other” site, there is a description and diagram about
retrofitting a tabernacle to a solid mast.
http://www.freedom21.info/f21tabernacle.pdf
It may answer some of your questions about
how it all works.
Patrick
-----Original Message-----
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Richard
Sent: Sunday, January 28, 2007
8:34 PM
Subject: [freedom21] Re: Factory
CF tabernacle mast
experience with the tabernacle mast. Your comments were very
looseness of
like that.
did the
seen one of
top sticking
until it’s in
wear could be a
the lower
apparently sits
correct so far? Do
correctly
leaving the
loose mast
have in mind.
Regards, Richard
From what I
waves. I
The mast
season
but to no avail.
play. In the
fiberglass and
since
the first
of this
all
cosmetic. Outer
painted mine wite
have a few
Are there any
resist UV damage
heavily weathered,
the cost of
old mast
of these masts?
Posted by wilfred2736 (wilf.bishop@…>)
Hi Richard,
Just want to assure you that stepping & unstepping the mast is really
no big thing. Although it would indeed be somewhat slower than
just “plugging-in” your tabernacle mounted mast the use of an “A”
frame system for handling a one-piece mast is simplicity itself.
Particualrly so with you guys in the USA having ultra-light carbon
fibre masts instead of the haevy aluminum maste we have over here in
the UK. Take a look at my step-by-step photos & write-up on our
website and you will see how easy it is.
Best wishes,
Wilf Bishop
F21 DAYDREAM
comments were very
the wear and looseness of
get worn like that.
rough seas or did the
I’ve haven’t seen one of
fitting on top sticking
slides downward until it’s in
supprise that wear could be a
sleeve within the lower
the mast apparently sits
have this correct so far? Do
I understand correctly
epoxy, leaving the
repair solves the loose mast
sailing deal I have in mind.
Regards, Richard
me to fix it since
cosmetic. Outer
heat off.
mast and have a few
yr. old mast
Richard, you got the constriction of the tabernacle correct. It’s a male/female type of connection. The solid mast was cut in two, than tabernacle inserted in the bottom part and an aluminum sleeve in the upper. Believe it was a tight fit when new but both parts got warned out. At the bottom part I had about 3/16" of play.
I do not trail the boat so convenience of easy stepping of the mast did not concern me. Only time it was useful is when my wind vane broke. Me and two of my friends took the mast down without using the lines as in Hoyt’s instructions. My impression after the process was that it is not something I would like to do alone. I put some tape on the tabernacle before putting the mast back to reduce the play. It did not help a bit but when taking the mast off year after it made it rather difficult to lift. Right now I belong to a yacht club that has a hoist so for now any difficulties removing the mast are solved.
Steping/unsteping a full length mast is not a big deal…… If you do it once a season !!!
I don’t see you going through the process of it with an A frame than hammering in rubber shim on a Saturday afternoon at some lakes parking lot just to get half a day of sail out of it.
Tabernacle will work just fine if you don’t hit waves for a prolong period of time.
As far as fixing my mast, I completely removed the tabernacle assembly from the bottom part, wrapped it with fiberglass and wetted it out with epoxy than reinserted it back. Next step was doing the same for the male part of tabernacle and jointing both parts of the mast. I positioned the mast vertically on the club grounds afterwards and purred some epoxy down one of the holes that were drilled for the wires. In theory epoxy should have flowed down in to any void spaces between the parts. Mast seems solid for now.
Another owner had fitted a thick aluminum tube on the outside of the mast and fixed it permanently with 5200 adhesive. Probably a more solid fix than mine but creates whole other problem of shimming an sealing the mast at the deck.
----- Original Message ----From: Richard <cookieseaman@…>To: freedom21@yahoogroups.comSent: Sunday, January 28, 2007 8:33:57 PMSubject: [freedom21] Re: Factory CF tabernacle mast
Thanks for sharing your experience with the tabernacle mast. Your comments were very helpful in addressing my questions. I’ll definately look out for the wear and looseness of the mast when examining a shoal draft F-21. Have to wonder how they get worn like that. Is it just a matter of the design and time, thrashing about in rough seas or did the previous owner not shim the mast properly at the deck fitting. I’ve haven’t seen one of these, only the photo on this site of the aluminum post with hinged fitting on top sticking out of the deck. Apparently, the mast slips over this post and slides downward until it’s in position, but how far? If the length is short, it seems as no supprise that wear could be a problem. From your description it seems that there is an aluminum sleeve within the lower part of mast that forms a sliding fit over the tabernacle post, and the mast apparently sits on top of a short CF section which rests in the
mast step. Do I have this correct so far? Do the tabernacle post and lower CF segment act as a single piece? If I understand correctly you joined the two carbon fiber segments with fiberglass cloth and epoxy, leaving the aluminum tabernacle post within the mast? It seems that your repair solves the loose mast problem, but it might eventually kill the quick and easy trailer sailing deal I have in mind. Regards, Richardfreedom21@yahoogrou ps.com, mitya fonin <mitbok1@… > wrote:>> I have a shoal draft, and the tabernacle caused me some grief last summer. From what I gather boat was sailed in New York harbor and was hitting some ocean swell and waves. I was out in the waves often as well. From all that rocking tabernacle wore off. The mast was noticeably moving back and forth and by the beginning of last years sailing season
situation did not seem safe. I have tried to use shims to stiffen the set up but to no avail. Basically the aluminum pipe insert and tube both worn out developing a lot of play. In the middle of the summer I have fused permanently both parts of the mast with fiberglass and epoxy. making it a solid mast again. There seems no other way for me to fix it since tolerances were different in upper and bottom parts of the tabernacle. I am not the first one to do this fix either. So, if you going to sail in some rocky waters beware of this problem. Also check for play when buying. As far as UV damage, cracks, etc. its all cosmetic. Outer> cote of epoxy is not structural. Corbon fiber is hiden safe under it. I painted mine wite last summer. Mostly for looks but this will probably take some sun heat off.> > > ----- Original Message ----> From: Richard <cookieseaman@ …>> To: freedom21@yahoogrou ps.com> Sent: Friday, January 26, 2007 10:11:38 PM> Subject: [freedom21] Factory CF tabernacle mast> > I’m considering a shoal draft version with factory tabernacle mast and have a few > questions. Does the tabernacle joint form a solid fit once it’s stepped? Are there any > known structural failure risks with this mast? Is the CF mast treated to resist UV damage > to the resin? I notice that the black CF masts often appear dull as if heavily weathered, and > some have been painted. Does such weathering lead to mast failure? Given the cost of > replacement, should a prospective buyer be concerned about a > 20 yr. old mast > failing under normal use? Finally, any advice on assessing the condition of these masts? > Many thanks for any information you might have. Richard> > >
____________ _________ _________ _________ _________ _________ _> Now that’s room service! Choose from over 150,000 hotels> in 45,000 destinations on Yahoo! Travel to find your fit.> http://farechase. yahoo.com/ promo-generic- 14795097>
Food fight? Enjoy some healthy debatein the Yahoo! Answers Food Drink Q&A.
Many thanks to everyone for their input on solutions to deal with a loose
tabernacle mast.
3/16" play at the bottom translates to quite alot of movement at the mast head.
I suppose
that once things start to get loose the wear progresses quickly. Mitya, it seems
like you
should have a solid repair. Thanks to everyone for your efforts and experience
shared. I
think I generally understand the the design, repairs and alternatives to
stepping the mast
should it need the ultimate solidified repair.
Can I assume the retrofit .pdf illustration in “modifications” is the same as
the factory
version. If so, the socket (length of the sliding fit) created by the aluminum
tabernacle
assembly is pretty short - From the drawing it looks like its only about 9
inches for the
entire slip fit so it’s not suprising that it wears easily with maybe 26 feet of
mast working
against it.
There is one thing that’s not clear to me; where is the joint between the upper
and lower
mast sections? How far above or below the deck level? I think I like the tubing
on the
outside of the mast idea, especially if the mast joint was sufficently below the
deck, but
from your description it sounds like it’s pretty close to the deck. What if
Instead of fixing
the heavy aluminum tube with 5200, the tube was split on one side along its
length and
then clamped around the mast to center the two mast sections and take the play
out of the
joint. That way the stress would be off the tabernacle when installed and this
split tube
sleeve could be loosened and slid down allowing the tabernacle hinge to be used
normally.
Might that work, save the complications of shimming and sealing at the deck? I
guess I
really want to be able to support the mast and find a way to step and lower it
easily by
using the tabernacle hinge, should these fittings become loose.
I realize I’m making an off hand assessment about something I haven’t seen, so I
guess I
just need to make the trip to check out my intended and see what these things
actually
look like. Again thanks for all the input on the CF mast.
Regards, Richard
male/female type of
bottom part and
parts got
concern me.
took the
on the
bit but when
belong to a yacht
season !!!
in
day of sail
out of it.
time.
reinserted it
both parts
purred
epoxy should
now.
fixed it
whole
were very
looseness of
like
that.
did the
seen one of
top
sticking
until it’s
in
wear could be a
within the
lower
apparently
sits
correct so far?
Do
leaving the
loose
mast
I have in
mind.
Regards, Richard
From what
I
waves.
I
The mast
sailing season
but to no
avail.
play. In
fiberglass
since
not the first
beware of this
its all
cosmetic. Outer
painted mine wite
a few
there any
resist UV
damage
heavily weathered,
cost of
mast
these
masts?
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
