Posted by valkyrie_1996 (akuehne@…>)
I was poking around behind the fuse panel of my 1996 Freedom 35 and
discovered that she was pre-wired at the factory for fans. I’m the
second owner and I have no idea where the other end of the fan wiring
is stowed. I’d like to add fans and I would like to use the existing
wire if possible. Anyone know where the optional factory installed
fans were typically located? Thanks.
Art Kuehne
Posted by Mark Lynch (lzranch@…>)
Art;I’ll send you some interior picture of our F35 back channel. It was build for charter use in the BVIs and came with the fans installed. Mark On Dec 5, 2006, at 9:29 PM, valkyrie_1996 wrote:I was poking around behind the fuse panel of my 1996 Freedom 35 and discovered that she was pre-wired at the factory for fans. I’m the second owner and I have no idea where the other end of the fan wiring is stowed. I’d like to add fans and I would like to use the existing wire if possible. Anyone know where the optional factory installed fans were typically located? Thanks.Art Kuehne
