Recent Camberspar rigging posts have me thinking about Forestay tension.
Is there any agreement on the forestay tension?
Posts and opinions on this topic seem to run the gamut. Seems like it would not some slack to get the vanging effect and push forward.
Especially to avoid dreaded banging on mast when tacking or gybing in light air ?
Tight - no slack
Just Loose enough but not pulling mast forward
Even looser - forestay can be pulled to 6” inches each side
Super Loose - forestay can be pulled 8-10” inches each side.
I believe the correct answer is #2. I say “correct” because it’s what Paul Dennis told me to do, and when it comes to Freedoms, Paul Dennis is always correct. Specifically, his instructions were to add tension until just before the mast starts to deflect. It’s much easier with another person there, so they can watch the mast from a distance and call out the moment it starts to bend.
