Freedom 21 bimini?
Posted by flametop62 (towers@…>)
I’m considering buying an early 80’s Freedom 21. Is there enough room
under the boom for a bimini? The boat has a shoal keel and a mast
tabernacle. Anything I should be paying attention to as far as
potential problems? Thanks.
Posted by amcclung@…> (amcclung@…>)
I think it depends on the bimini. I’ve got a F-21 myself. I don’t have a bimini,
but plan to put one one. There’s a company in Florida who manufacturers biminis.
They need measurements of the boat. I’ll send you their name if you want.
Allen
Date: 2005/03/30 Wed PM 10:40:15 GMT
Subject: [freedomyachts2003] Freedom 21 bimini?
Posted by Bob Tuttle (2rats@…>)
— In freedomyachts2003@yahoogroups.com, “flametop62” <towers@e…>
I had a F21 and a bimini. I did reinforce the leading edge when at
times the end of boom would connect with it. Some durable vinyl or
similar material. If I can locate a picture, I will either send it or
put it on my FTP site along with a great picture of Candy Barr in her
prime.
Those are great boats and I miss mine. Too long in the tooth now.
Be carefull that it is flexible if you go under the boom.
You can raise the boom and keep the boom up so it is level using the
lazyjacks but that will interfere with sailtrim at times.
Also the is enough power in the sail in a blow to wreck anything in
its way.
Bimini & Dodger
JSI in St Petersburg built my Bimini and Dodger.
Andre " Scaramanga " F25amcclung@… wrote:
I think it depends on the bimini. I’ve got a F-21 myself. I don’t have a bimini, but plan to put one one. There’s a company in Florida who manufacturers biminis. They need measurements of the boat. I’ll send you their name if you want.Allen> > From: “flametop62” <towers@…>> Date: 2005/03/30 Wed PM 10:40:15 GMT> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Freedom 21 bimini?> > I’m considering buying an early 80’s Freedom 21. Is there enough room under the boom for a bimini? The boat has a shoal keel and a mast tabernacle. Anything I should be paying attention to as far as potential problems? Thanks.Post your free ad now! Yahoo! Canada Personals
