Posted by monettepl (pmonette@…>)
I am wondering where I may get replacement hatch slides for my 1983
Freedom 21. I thought I had read somewhere, J22 slides will fit. Any
help would be much appreciated. Thanks.
Posted by crarasim@… (crarasim@…)
I’ve heard that the J22 slides will work also…E-Mail or call Freedom or J-Boats and they should be able to confirm…let us know too…mine are still in good shape but it would be good to know.
Charlie
Freedom 21 # 104
WindRush
Posted by clivaday (clivaday@…>)
— In freedomyachts2003@yahoogroups.com, “monettepl” <pmonette@v…>
Any
Dec 1, 2003 Here’s the email address.
http://www.waterlinesystems.com/ Good luck. Charlie
Posted by rbhb2 (rbholt@…>)
The Waterline J22 slides work fine. If the problem is only that the
aft end is cracked, you might be able to swap the slides end-for-end
(you still will need to remove the sea hood).
