Freedom 21 Questions
Posted by rickpowers55 (rpowers55@…>)
Hi folks and greetings from Texas, I recently purchased a Freedom
21 and am doing some repairs before putting her back in the water.
Would like to ask your help on a few projects.
1 The track on the mast is loose at the bottom. Looks like it was
attatched by stainless steel screw. Was thinking of going back with
rivets…suggestions.
2 Mast collar and rotation of mast. The previous owner had the
mast fastened at the bottom of the boat with screws to stop mast
rotation. While it probably worked it is a pain in the a… when
taking the mast down. From what I have read the plastic, urethane,
whatever, collar is supposed to squeeze the mast with sufficient
pressure to prevent mast rotation. Info on another site showed
bolts with washers placed thru the deck to press the collar in the
hole and thus press in on the mast. Are other boats done like
that? Should I drill the holes and put the bolts in?
3 My boat came with no cap to go around the mast and act as a
weather protector for the collar and hole for the mast. Any ideas
on a replacement?
4 Was thinking of adding an additional halyard for a jib in
addition to the spin halyard that is already on the mast. Are there
any concerns with putting another hole in the mast with a sheeve to
add this halyard?? Worries with structural integrity of the mast?
Well I think that is it for now. As to the other projects…well
we are sanding her bottom and gettin it smooth for all the light air
we have in Texas as well as replacing the windows in her as well.
Appreciate all the help this site is to this lowly sailor and
appreciate any help yall can give me in working on this fine boat.
Rick
Posted by Charles Arasim (crarasim@…>)
Ahoy Rick,
I’ve had my 21 for a little over 2 years now and physically seen 2 others.
  1. Go with the original type rivets. they need to be flush so the mainsail
    cars don’t jamb,
  2. As to mast rotation, all 3 I’ve seen have a 1/4" hole just to the
    Starboard Aft side in the mast foot and a corresponding hole in the mast.
    When I got my hull it just had a rusty old bolt to insert in the hole, so I
    made a nice brass pin, with a 90* bend in it so I can get a good hold on it
    to pull it out (I dry sail and take my mast up and down all the time). At
    the deck I just have the 3 bolts with flat washers above and below the
    deck. I think the only thing they do is keep the mast from banging around
    the deck through hole.
  3. As to a weather boot (I’ve been thinking about that when the time comes)
    maybe a plumbing fitting (rubber reducer/coupling of proper diameter would
    work. You may have to look to a supplier for water works for one large
    enough. I’ve looked at these at places like Home Depot, but I haven’t seen
    one large enough. Give your city water department a call and see if you
    can get a company name that might have something about the right size (let
    me know what you can find and I’ll do the same). The other thing you could
    do is to cut one from a tire inner tube or look at the rubber they sell for
    pond liners. I can measure my original boot and give you the numbers if
    you like…
  4. I’ve been looking at this also. The problem is that the Jib tacks on
    the spinnaker pole sleeve in front of the spinnaker. I’ve been thinking of
    making a tempoary tack point (bridle) for the Jib aft of the snuffing bag
    and seeing how much that hurts my pointing ability, just haven’t tried it
    yet. As far as putting another hole in the mast goes, I thought I would
    avoid that if I could and use the existing holes and fashion a stainless
    bracket with a double sheave outside the mast, need to look at the the
    angles to figure how to do it. I think Dweyer Green did this, only I don’t
    know if/how he got around the tack problem. Can’t find that website at the
    moment, but if you put a call out on the group for it someone will have
    it…
Enjoy
Charlie Arasim
WindRush F21CatDK #104
Rio Rancho, NM
Posted by S Wesson (sailsoul@…>)
Riki, You just cant beat that little rubberish wedgie for holding the
mast tight and in it’s proper place. Hope we never lose ours. Are these
still available? Also makes de-commissioning much easier we would
think.
Sounds like the perfect place to use SPAR-TITE? Worked great on our
J-24s. Anyone used that for this application?
Whatever is right, is…
S Wesson
Attachment: (image/tiff) Pasted Graphic.tiff [not stored]
On Jul 11, 2005, at 21:48, Charles Arasim wrote:
Ahoy Rick,
others.
    mainsail
    cars don’t jamb,
    mast.
    hole, so I
    on it
    time). At
    around
    comes)
    would
    large
    haven’t seen
    you
    (let
    could
    sell for
    if
    you like…
    on
    thinking of
    bag
    tried it
    would
    stainless
    don’t
    at the
    have
    it…
Enjoy
Charlie Arasim
Rio Rancho, NM
YAHOO! GROUPS LINKS
â–ª Â Visit your group “freedomyachts2003” on the web.
Â
â–ª Â To unsubscribe from this group, send an email to:
Â
â–ª Â Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Rick. Do not let the mast rotate, and do not rely on the wedge(s) at
deck level to prevent rotation. Use whatever device the previous
owner used at the bottom area of the mast to prevent rotation, or
improve the setup based upon info from other F21 owners. Use monel
rivets on the track if at all possible. The boat has no stays, so
tie a knot in the mainsheet at the appropriate spot, to prevent the
boom from going forward of the mast (and tearing out your gooseneck
and lower track rivets).I’ve forgotten whether or not the lazy jacks
attach to the mast above the jib/spinnaker halyard sheave. If they
attach above, you might try to use the strap and holes already there
to attach a new halyard block. Best not to drill new holes in the
carbon mast, although many do it. Good luck. Charlie
— In freedomyachts2003@yahoogroups.com, “rickpowers55”
water.
was
with
rivets…suggestions.
urethane,
on a replacement?
there
to
air
Rick
Freedom had a lot of the polyurethane wedge material available at
their yard sale. I doubt they sold it all, unless they sold
everything at the end as a lot…
— In freedomyachts2003@yahoogroups.com, S Wesson <sailsoul@v…>
these
think.
our
S Wesson
Ahoy Rick,
seen 2
others.
    mainsail
    cars don’t jamb,
    to the
    mast.
    hole, so I
    good hold
    on it
    time). At
    below the
    banging
    around
    time
    comes)
    diameter
    would
    one
    large
    haven’t seen
    see if
    you
    right size
    (let
    thing you
    could
    they
    sell for
    numbers
    if
    you like…
    Jib tacks
    on
    been
    thinking of
    snuffing
    bag
    haven’t
    tried it
    thought I
    would
    stainless
    the the
    only I
    don’t
    website
    at the
    will
    have
    it…
Enjoy
Charlie Arasim
Rio Rancho, NM
YAHOO! GROUPS LINKS
Â
Â
Terms of
Service.
I’ve used spartite on my F-33 and it works well.
Sent: Tuesday, July 12, 2005 4:16 PM
Subject: Re: [freedomyachts2003] Freedom 21 Questions
Riki, You just cant beat that little rubberish wedgie for holding the mast tight and in it’s proper place. Hope we never lose ours. Are these still available? Also makes de-commissioning much easier we would think. Sounds like the perfect place to use SPAR-TITE? Worked great on our J-24s. Anyone used that for this application?Whatever is right, is…S Wesson
Ahoy Rick,I’ve had my 21 for a little over 2 years now and physically seen 2 others.1. Go with the original type rivets. they need to be flush so the mainsailcars don’t jamb,2. As to mast rotation, all 3 I’ve seen have a 1/4" hole just to theStarboard Aft side in the mast foot and a corresponding hole in the mast.When I got my hull it just had a rusty old bolt to insert in the hole, so Imade a nice brass pin, with a 90* bend in it so I can get a good hold on itto pull it out (I dry sail and take my mast up and down all the time). Atthe deck I just have the 3 bolts with flat washers above and below thedeck. I think the only thing they do is keep the mast from banging aroundthe deck through hole.3. As to a weather boot (I’ve been thinking about that when the time comes)maybe a plumbing fitting (rubber reducer/coupling of proper diameter wouldwork. You may have to look to a supplier for water works for one largeenough. I’ve looked at these at places like Home Depot, but I haven’t seenone large enough. Give your city water department a call and see if youcan get a company name that might have something about the right size (letme know what you can find and I’ll do the same). The other thing you coulddo is to cut one from a tire inner tube or look at the rubber they sell forpond liners. I can measure my original boot and give you the numbers ifyou like…4. I’ve been looking at this also. The problem is that the Jib tacks onthe spinnaker pole sleeve in front of the spinnaker. I’ve been thinking ofmaking a tempoary tack point (bridle) for the Jib aft of the snuffing bagand seeing how much that hurts my pointing ability, just haven’t tried ityet. As far as putting another hole in the mast goes, I thought I wouldavoid that if I could and use the existing holes and fashion a stainlessbracket with a double sheave outside the mast, need to look at the theangles to figure how to do it. I think Dweyer Green did this, only I don’tknow if/how he got around the tack problem. Can’t find that website at themoment, but if you put a call out on the group for it someone will haveit…EnjoyCharlie ArasimWindRush F21CatDK #104Rio Rancho, NMYAHOO! GROUPS LINKS â–ª  Visit your group “freedomyachts2003” on the web. ▪  To unsubscribe from this group, send an email to: freedomyachts2003-unsubscribe@yahoogroups.com ▪  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
