Freedom 25 Spinnaker Launch Tube Placement
In every F25 picture I have seen the spinnaker launch tube and stored pole are located on the Port side of the boat. Is there any reason not to reverse that? Because of the way my birth is set up it would be more out of the way for me if I could mount them on the starboard side.
My 32’s tube has been on either side, right now it is to starboard, and can go on either side without the slightest difference. The pole should probably be stored on the opposite side from the tube but only because it’s slightly easier to retract the pole without snagging the bag, otherwise same side or opposite side really doesn’t matter either.
