Freedom 28 Forestay/Jibstay
Posted by hxschiller (schiller@…>)
How tight is this forestay set up on Freedom 28 cat-sloop? I’m in the
process of “assembling” a newly bought boat and find that the jibstay
is still slack after the turnbuckle is fully closed.
It is not supposed to be tight. On the F30, which is essentially the same, the instructions are to tighten only enough to remove sag. On these Freedoms, the forestay is only there to hold the jib; it has no role in holding up the mast. Thus, no need for it to be tight.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of hxschillerSent: Sunday, October 30, 2005 8:10 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Freedom 28 Forestay/JibstayHow tight is this forestay set up on Freedom 28 cat-sloop? I’m in the process of “assembling” a newly bought boat and find that the jibstay is still slack after the turnbuckle is fully closed.
Posted by Payne, Doug (doug.payne@…>)
Should be quite loose, it is not designed to provide any support to the mast, just support the luff of the jib. Also if it is too tight, the end of the camberspar bangs into the mast when you talk.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
This electronic message is intended for the person or entity to which it is addressed and may contain confidential and/or privileged information. Any review, dissemination, copying, printing, or other use of this electronic message by persons or entities other than the addressee is prohibited. If you received this electronic message in error, please contact the sender immediately and delete the electronic message from any and all computers.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of hxschillerSent: Sunday, October 30, 2005 6:10 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Freedom 28 Forestay/Jibstay
