Freedom 30 Specs
Posted by Bill Jones (mail@…>)
I broke out my Freedom 30 manual to lookup the jibsheet lenght and
noticed a few specs that are different than I was told about the
boat. My boat has a tank tender and the card that explains what
readings on the gauge coorespond to what tank levels have the
following tank capacities: water 35, fuel 15 and waste 12. The
manual saws water 50, fuel and waste 20. My boat is a 1987 vintage.
Did Freedom change the amounts after the manual was printed or is my
tank tender card wrong?
Also I was told the draft is 5’2" and the mast height 48’. The manual
has 4’6" and 44’. Which is right?
Thanks for the help!!!
Bill
L’ana Kai
Rockport, TX
My manual has the same specs as yours for the tanks and I have no data to prove or disprove those numbers.
As to draft, Freedom made what they called a shoal (4’6") draft and a deep (5’6") draft. When I was shopping for my F30, I measured the draft of three shoal keel boats on the hard, and each came to about 5’. Others have reported the same thing.
As to mast height, the 44’ listed in the manual is incorrect. On October 26, 1987, Mark Edwards, then of Freedom customer service sent out a notice stating that the correct mast height above water is 47’6" (antennas not included), not 44’ as listed in the manual. (I wonder how they discovered this? A warrantee claim, perhaps?)
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Bill JonesSent: Monday, October 31, 2005 9:35 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Freedom 30 SpecsI broke out my Freedom 30 manual to lookup the jibsheet lenght and noticed a few specs that are different than I was told about the boat. My boat has a tank tender and the card that explains what readings on the gauge coorespond to what tank levels have the following tank capacities: water 35, fuel 15 and waste 12. The manual saws water 50, fuel and waste 20. My boat is a 1987 vintage. Did Freedom change the amounts after the manual was printed or is my tank tender card wrong? Also I was told the draft is 5’2" and the mast height 48’. The manual has 4’6" and 44’. Which is right?Thanks for the help!!!BillL’ana KaiRockport, TX
Posted by TJ (fairways31@…>)
i always thought i had fifty gal of water. the other seem right draft is about 4’‘7"Bill Jones <mail@…> wrote:
Yahoo! FareChase - Search multiple travel sites in one click.
Posted by Weeks MD, Andrew (aweeks@…>)
Many F-30s had their alum fuel tank
replaced. Mine was. The new one is 17 gal., not 20. There is a mechanical gauge
that needs to be calibrated (the tank is V shaped). Full=17 gal; ¾ =10; 1/2 =-4
gal and ¼ is almost dry!.. It was a good piece of preventative maintenance to
drain the tank and clean out all the gunk before adding measured amounts of
fuel and noting the gauge reading…Andy Weeks Windfall
[mailto:fairways31@…]
Sent: Tuesday, November 01, 2005
10:45 AM
To:
Freedom 30 Specs
seem right draft is about 4’'7"
Bill Jones
<mail@…> wrote:
I
told about the
that explains what
levels have the
and waste 12. The
Bill
L’ana Kai
Rockport, TX
Yahoo!
Printed specs don’t always mean much. Tanks can be changed. During
production runs alternate vendors are occasionally utilized. Your
manual is for a shoal draft F-30. If you don’t have a shoal draft
model then the draft measurement is incorrect.
Best thing to do it measure for yourself. Tank capacity can be
determined by measuring. Ditto for mast height.
— In freedomyachts2003@yahoogroups.com, “Bill Jones” <mail@t…>
vintage.
my
manual
Bill
L’ana Kai
Rockport, TX
