freedom 32 keel
Posted by wwilson20.1945 (wwilson20@…>)
1.) Is the deep draft(5’6")keel on the F32 encapsulated within the FG
hull or is it external and bolted on? Question is … can it be
shortened and bulbed to create a shoal draft of 4’6"? What is the
shoal depth on the F32-4"11"?
2.) Is the hull solid glass to the rail or cored above the waterline?
3.) Has anyone done this modification before?
The keel is bolt-on. The hull is cored with end-grain balsa. Consider
using a “Scheel Keel” if you reduce the keel’s
depth. Herm
  1. I spoke directly with Garry Hoyt about doing just that on my ‘84
    F32. It can be done. You’d need to have the boat hauled and while
    in a sling, cut off the desired amount of keel. Meanwhile, you’ll
    need to scribe the curve of the keel, create a mold for the added
    lead needed to make up for the ballast you’ll be losing, and find a
    lead smelter who can fabricate a set of wings which would need to be
    bolted on and faired. While not impossible, it’s quite an
    undertaking and not cheap. In Garry Hoyt’s opinion, it would alter
    the performance of the boat. I decided to sail for a season with the
    existing 6’ keel and am glad that I didn’t make the change.
  2. The hull is cored to the keel
Contact me off line if you’d like more information.
Good luck
TW
Pemaquid, ME
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.16.8/1154 - Release Date:
11/27/2007 11:40 AM
Version: 7.5.503 / Virus Database: 269.16.8/1154 - Release Date: 11/27/2007
11:40 AM
Posted by Al Lorman (ajl@…>)
Good
Old Boat magazine had an article about someone who cut off the bottom of the
keel on his C&C and had two small wings cast by Mars and then bolted and
epoxied them onto the existing stub. Worked for him.
Al
Lorman
F30
Ab Initio
Behalf Of Thomas Wales
Sent: Tuesday, November 27, 2007 10:25 AM
Subject: Re: [FreedomOwnersGroup] freedom 32 keel
    just that on my ‘84
Good luck
TW
Pemaquid, ME
11/27/2007 11:40 AM
11:40 AM
