Mine(#68) draws 4.5 ft,the mainmast is 45 total length. I’ve never questioned what configuration it was.
Sent: Tuesday, June 13, 2006 10:02 AM
Subject: RE: [freedomyachts2003] Freedom 33 - Was the Tall Rig an option or a revision?
I think a little over 5 feet as well.
The information contained in this e-mail and any attachments is intended only for the personal and confidential use of the recipient(s) named above and may be subject to attorney client privilege if so marked. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail, and delete the original message.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome WeinraubSent: Tuesday, June 13, 2006 9:56 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Freedom 33 - Was the Tall Rig an option or a revision?
What draft was the tall rig?
----- Originl Message -----
Sent: Tuesday, June 13, 2006 9:39 AM
It was an option after a certain point. However the tall rig was only available with the deeper keel. The shoal keel sailplan was the same as for the centerboard. That’s my understanding. The tall rig had about an extra 5 ft of height on the mainmast which according to the freedom sailpan gave it an extra 35 sq ft of mainsail in the non wishbone version of the sailplan.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of yottydottySent: Monday, June 12, 2006 11:03 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Freedom 33 - Was the Tall Rig an option or a revision?
Was there a cut-off based on hull numbers between the standard andtall rigs, or was it an option such that boats from a certain timeonwards could have either? (Of course owners could have changedafterwards)Or does it change with the rigs - e.g. centreboard short, fixed keeltall etc?I have searched through the forums but cant find any clues…
