Freedom 40/40 Rigging List
This file contains the rigging specs for the 40/40.
4040_Rigging_List.pdf (47.6 KB)
Geoff, this rigging list should come in handy. I see that it’s the original list for your boat, as delivered, right? Can you tell me anthing about the configuration, at the time? What was the mast height, and were the halyards led to the cockpit? I just ordered a spare main halyard sized at 152’ (Endura 7/16 braid), even though I just reduced the mast to 61.5" AWL, whereas your list only calls for 132’
Yes, this is the original list that was loose in my manual. This is hull 25, circa 1997, with a 62’ mast. All lines run to the cockpit. I’d add 10+’ to the jib halyard as I tend to chafe through it and keep shortening it.
Thank you Geoff!
