Freedom 40 cat ketch center cockpit for sale
contact STEPHEN KRING
Steve Kring Construction
and Horizon Realty of Anna Maria
P: (941) 778-0426
C: (941) 224-0293
Photos in pdf below!
Rigs- two 50’ Aluminum
Mast sandblasted and refinished with Awl Grips 6 step system
Al blocks replaced with Garhauer
Al halyards replaced
Tides track system installed
Seldon adjustable Goosenecks
Sails and Covers-two
Doyle Main and Mizzen
Two Doyle stack Pac’s
Engine and transmission
Beta 43 Diesel
Fuel Tank
100 gallon tank-(rebuilt)
Bronze fittings
Raycor Fuel filter/water separator
Groco Water strainer
Fuel hoses
Water hoses
Plumbing
Al new thru Bronze hulls 12
All n e w h o s e s
All new double hose clamps
Three Johnson Blige pumps
Three Water Witch float switches
Rule Bilge Alarm
Jabsco pressure water system
Whale hot and cold lines and fittings
Seaward water heater-12v and engine coil
Faucets
  1. Delta galley
  2. Delta rear head
  3. Scandiv faucet shower main cabin
    Two Toilets- Jabsco round
    Water Tanks
  4. 37 gallon (new) plastic
  5. 450 gallon (rebuilt) plastic
    Holding tanks
    Two plastic 22 gallon
    Electric
    A/C panel
    4- 110 outlets-main cabin
    1-110 outlet-rear cabin
    2-110 outlets-head
    1-100 Outlet-v birth
    110 water heater
    110 battery charger
    D/C panel
    V-birth
  6. 12v outlet
  7. 2- cabin bulkhead lights-led
    Main Cabin
  8. 2-cabin bulkhead lights-led
  9. 3–over head lights-led
  10. 1-red/white overhead light
  11. 2-12v outlets
  12. Electronics connections
  13. Refrigeration
  14. Pressure water
    Rear Cabin
  15. 1-bul;khead light
  16. 1- overhead light
  17. 1-red/white overhead light
  18. 1-12v outlet
    Engine room
  19. 3-overhead lights
    Exterior lights
  20. Mast head
    a. Anchor-led
    b. Steaming-led
    c. Spreader lights
  21. Navigation lights
    a. 2-bowl lights-led
    b. 1-stern light
    Freedom 40 C
    General Information
    LOD 40’
    LOA
    With Bow Sprit and Boomkin 45’-6"
    LOA adding in Mizzen Boom 47’-2"
    Mast Measurements
    Waterline to Mast Head
    Antenna
    48’-8 1/4"
    3’-0" Bird 1’-11" which is less than antenna
    Block Pulley to top of mast
    Deck Colar to Block Pulley
    Deck color to waterline
    5-1/4"
    45’-5*
    2’-10"
    Mast Height W/O antenna or bird 48’- 8-1/4°
    Mast Height with Antenna
    51’ 8-1/4"
    Engine
    Water Pump Beta 207-0923
    Water Pump Impeller 207-09042
    Engine oil Filter Beta 211-705 10/02
    Fuel Filter Engine Beta 211-6210
    Freedom 40 CC 9-27-25.pdf (2.7 MB)
Beautiful boat. Best of luck selling her
Steve’s boat today in Cortez Fl Awaiting new owner. Will it be you?
Note Sunbrella covers on brightwork
Sails loft cleaned and ready.
Custom t top Bimini ashore
Some more photos.
If you’re considering a center cockpit Freedom 40 cat ketch you should look at Steve’s.
(It has two a/c systems. One for main and one for aft cabin.
