Posted by debbiekossoff (dkossoff@…>)
I have a Freedom 45 center cockpit built in 1989. The coil inside the water
heater burned out
and we took it out of the unit. It is a double coil, roughly 12 inches long. The
coils are
mounted on a square plate, that were held in place with a plate, not a screw on
style you see
more of in use now.
The heater has no visible manufacturers name on it, and I can’t seem to find a
replacement at
plumbing supply stores.
Anyone have this situation before? What heaters did Freedom install around that
time?
Posted by amarsib@… (amarsib@…)
I replaced that heating element on my freedom 36/38 2 years ago. I purchased it
from Davis and Warshaw in new york city and was able to fit it nicely to the
tank. Its more or less a standard heating element for domestic hot water
heaters.
-----Original Message-----
Date: Wed, 23 Apr 2008 19:44:33
To:FreedomOwnersGroup@yahoogroups.com
Subject: [FreedomOwnersGroup] Freedom 45 water heater
heater burned out
The coils are
style you see
more of in use now.
replacement at
time?
Posted by Debbie Kossoff (dkossoff@…>)
If this is what I need, you are a godsend. I’m googling right now!!!Thanks for your response!!!DebbieOn Apr 23, 2008, at 4:10 PM, amarsib@… wrote: I replaced that heating element on my freedom 36/38 2 years ago. I purchased it from Davis and Warshaw in new york city and was able to fit it nicely to the tank. Its more or less a standard heating element for domestic hot water heaters. -----Original Message-----From: “debbiekossoff” <dkossoff@…>Date: Wed, 23 Apr 2008 19:44:33 To:FreedomOwnersGroup@yahoogroups.comSubject: [FreedomOwnersGroup] Freedom 45 water heaterI have a Freedom 45 center cockpit built in 1989. The coil inside the water heater burned out and we took it out of the unit. It is a double coil, roughly 12 inches long. The coils are mounted on a square plate, that were held in place with a plate, not a screw on style you see more of in use now. The heater has no visible manufacturers name on it, and I can’t seem to find a replacement at plumbing supply stores. Anyone have this situation before? What heaters did Freedom install around that time?------------------------------------Yahoo! Groups Links<> To visit your group on the web, go to: http://groups.yahoo.com/group/FreedomOwnersGroup/<> Your email settings: Individual Email | Traditional<> To change settings online go to: http://groups.yahoo.com/group/FreedomOwnersGroup/join (Yahoo! ID required)<> To change settings via email: mailto:FreedomOwnersGroup-digest@yahoogroups.com mailto:FreedomOwnersGroup-fullfeatured@yahoogroups.com<> To unsubscribe from this group, send an email to: FreedomOwnersGroup-unsubscribe@yahoogroups.com<> Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/ Debbie KossoffGRAPHIC GROUP STUDIOdkossoff@…95 Highland RoadGlen Cove, NY 11542P: 516-671-8419F: 516-759-3881C: 516-330-8611
My 1981 Freedom 40 CK originally had a Sens Dure (sp) installed. They are out of Florida.On Wed, Apr 23, 2008 at 1:15 PM, Debbie Kossoff <dkossoff@…> wrote:
Debbie Kossoff
C: 516-330-8611
