【Freedom F40】Need Help with Leaking Center Board Trunk
Hi everyone, I’m the owner of a 1998 Freedom F40 and I’m currently dealing with a frustrating issue—there’s a leak in the center board trunk that I can’t seem to pinpoint. It’s been getting worse lately, and I’m worried it’ll cause more damage if I don’t fix it soon, so I’m hoping to get some advice from fellow F40 owners or experts here.
Here are the details I’ve noted so far:
  1. The leak is most noticeable after sailing in rough water—when I get back to the dock, there’s about 2-3 inches of water collected in the bilge near the center board area. It’s not a steady drip when the boat is stationary, only when we’re under way.
  2. I’ve already tried a few things to fix it: I cleaned out the center board trunk to remove any debris that might be blocking the drain, and I applied a marine-grade sealant around the top edge of the trunk where it meets the hull. But the leak still hasn’t stopped.
  3. I also checked the center board itself for cracks or damage—from what I can see, the board looks solid, and the hinge mechanism seems to be in good shape too.
I’ve gone through the Freedom F40 owner’s manual and the troubleshooting section doesn’t have specific tips for this kind of leak. Has anyone with a Freedom F40 dealt with a similar issue? I’d really appreciate any advice on where else to check for the source of the leak, or which marine sealants have worked best for fixing trunk leaks on these boats.
Also, if you know of a trusted technician or workshop in the Charleston, SC area that specializes in Freedom yachts, I’d love their contact info—I’m open to having a pro take a look if I can’t sort this out myself. Thanks so much for your help!
I’m a little confused about the term “Freedom 40 Centerboard Trunk”.
I have a 1990 Freedom 40 sloop, and it only came with the option for either a deep (6 foot) or Shallow (5.17 wing) keel. I’m unaware that there is any centerboard option available.
Can you clarify this for me and perhaps others?
Kenbobb,
Freedom had a few different 40’ designs. One was a centerboard
Hope this gets to you. I have a freedom 44 centerboard ketch. I too had a leak on the centerboard trunk. It was caused by winching the centerboard too tightly up in the trunk. There is a stainless steel tang on the rear of the board where the pendent attaches with a shackle. When pulled tight the tang/ shackle pushed through the top of the trunk. You might look on the top of the trunk where the tang comes into contact with it. If you lift the board with an electric winch it can easily allow the tang to penetrate the trunk. Over the years it will punch through as mine did. Most easily fixed from the top of the trunk as opposed to the inside.
Good luck.
