Posted by darthunix_com (dasreboot@…>)
found a freedom 21 for sail with a cracked mast. Does anyone know of a
source for a new mast, or more preferable, a used serviceable mast.
Posted by Joe Conron (jconron@…>)
Is there any reason that the mast cannot be repaired?
If the break is fairly low it should be possible.
I would think that one could cut the mast at the crack and fashion an
internal sleeve to connect the two pieces: epoxy the insert and inner
surfaces of mast and slide together. Then glass the area at joint.
This is similar to what is done with the hinged mast found on the shoal
draft model.
If the break is way up high, that may be a problem since the mast is
supposed to bend at the top to shed load. It might be hard to make a
properly flexible repair up high.
Regards,
Joe Conron
-----Original Message-----
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On
Behalf Of darthunix_com
Sent: Wednesday, March 22, 2006 4:08 PM
To: freedom21@yahoogroups.com
Subject: [freedom21] freedom mastfound a freedom 21 for sail with a cracked mast. Does anyone know of a
source for a new mast, or more preferable, a used serviceable mast.Yahoo! Groups Links
The break is up at the halyard blocks. Also the middle o the mast has
alot of surface checking.
surfaces of mast and slide together. Then glass the area at joint.This is similar to what is done with the hinged mast found on the shoal
draft model.If the break is way up high, that may be a problem since the mast is
properly flexible repair up high.Regards,
Joe Conron
