Can the person who bought the Freedom32 mainsail on Ebay please contact me. I need information about the seller that I hope you may have. It turned out that that sail was being built for me, which I paid in full for, but was never delivered and I’m having to sue the company that I ordered it from for my money back. It has become ugly-the sailmaker I ordered it from is unbelieveably nasty. If you could email me seperately from the group site that would be great Sward "Dream On"rick_simonds <rick_simonds@…> wrote: — In FreedomOwnersGroup@yahoogroups.com, “katorpus” <jrb@…> wrote:>> Rick> > There’s definitely a problem SOMEWHERE…> …> …> Hope this helps > > Thanks for that data, katorpus. I DOES help.It has its own thru hull now but the ideas behind moving the thru hull is to make it handier, sturdier, larger, shorter, simpler, more “shut off-able”, and, hopefully, to end up with more capacity and efficient. By process of elimination, the cooling water system very well could be my problem. “Short cycle” is certainly not the problem, the unit runs constantly. The air leakage from the bilge, if any, would be immeasurably tiny.I’m getting, at most, a 15 degree drop in temperature between the grilles and the
return. Flagship said that is considered acceptable. A friend measured the rate of the cooling water flow and its change in temperature. I don’t know the calculation but he declared it to be about 10,000 BTU.Knowledge-wise, I’m completely out of my element with A/C. I don’t know doodle, I just want my Yankee ass to be cool. Thanks for your info, it helps a lot. Yours, combined with others, says "it almost HAS to be the cooling water.“Thanks again,Rick"Life is a Reach, then you Jibe” SWARD
