Fuel Tretment/Black Smoke
It is best to replace the gasket. Old gaskets cause problems.On Sun, Aug 3, 2008 at 1:27 PM, <amarsib@…> wrote:
I removed the exhaust elbow and manifold today and found the openings 1/2 blocked. A mechanic mentioned this may contribute to the loss of power and black smoke. Will try again next wknd after I install the new parts.
Any one know the best way to safley remove a gasket stuck to the engine? Anthony Marsibilio F 36/38 T 2From: “Bob Weeks” <rweeks6508@…>
Date: Fri, 25 Jul 2008 18:21:22 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: RE: [FreedomOwnersGroup] Fuel Tretment/Black Smoke
Be careful because I can load my engine at the dock and get a different result when you are out there in the wind, current, etc.
Bob
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of amarsib@…
Sent: Friday, July 25, 2008 6:05 PMTo: FreedomOwnersGroup@yahoogroups.com
Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke
Thankyou Herm and everyone who helped. Although the boat yard coated the prop and shaft with zinc , lots of barnacles etc. was on the prop and shaft. Cleaned it all up (tough to hold your breath and clean at the same time) Loaded the engine while at the dock all seems ok !
Date: Thu, 24 Jul 2008 14:12:19 -0700 (PDT)To: <FreedomOwnersGroup@yahoogroups.com>
Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Did you ever figure out what caused the lack of power and black smoke? I am having the same issue. I had my injectors rebuilt and the fuel polished and it didn’t help. I’m now down significant power-almost like I’ve lost an entire cylender, but haven’t cleaned the bottom in three years, could it really be a dirty prop!!!
Melissa
s/v Acedia F38 “Pollution is a silent form of violence” -Ralph Nader
“Plastics, like diamonds, are forever!” -The Earth Resource Foundation (for more information on the adverse effects of plastics on human health and the environment, please visit–http://www.earthresource.org/campaigns/capp/capp-overview.html)
~ Please consider the environment prior to printing documents and offset carbon footprint,
give electronics a break by shutting them down and unplugging when not in use ~
----- Original Message ----
From: “amarsib@…” <amarsib@…> To: FreedomOwnersGroup@yahoogroups.com
Sent: Sunday, July 13, 2008 4:09:11 PM Subject: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Has anyone had fuel problems?
Same time last season and now, I am having loss of power when in gear and black smoke. I purchased a algae-x fuel polisher and additive last season but ended up pumping all the fuel out and cleaning the tank thru the 3 access ports.
All was fine after that. But now the problem is back. Any suggestions? I did add algae-x fuel treatment at the end of last season and do keep my tank topped off. Anthony Marsibilio Freedom 36/38
Three Mile Harbor NY
No virus found in this incoming message.Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.5.5/1571 - Release Date: 7/24/2008 5:42 PM
Posted by amarsib@… (amarsib@…)
I plan to replace the gasket once I find a good method to remove the existing with out scoring the face behind it.From: “Jay Glen” <svfantasy@…>Date: Sun, 3 Aug 2008 14:43:25 -0700To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke It is best to replace the gasket. Old gaskets cause problems.On Sun, Aug 3, 2008 at 1:27 PM, <amarsib@aol.com> wrote: I removed the exhaust elbow and manifold today and found the openings 1/2 blocked. A mechanic mentioned this may contribute to the loss of power and black smoke. Will try again next wknd after I install the new parts. Any one know the best way to safley remove a gasket stuck to the engine? Anthony Marsibilio F 36/38 T 2From: “Bob Weeks” <rweeks6508@verizon.net>Date: Fri, 25 Jul 2008 18:21:22 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: RE: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Be careful because I can load my engine at the dock and get a different result when you are out there in the wind, current, etc. Bob From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of amarsib@aol.comSent: Friday, July 25, 2008 6:05 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Thankyou Herm and everyone who helped. Although the boat yard coated the prop and shaft with zinc , lots of barnacles etc. was on the prop and shaft. Cleaned it all up (tough to hold your breath and clean at the same time) Loaded the engine while at the dock all seems ok ! From: Melissa <kalicinm@yahoo.com>Date: Thu, 24 Jul 2008 14:12:19 -0700 (PDT)To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Did you ever figure out what caused the lack of power and black smoke? I am having the same issue. I had my injectors rebuilt and the fuel polished and it didn’t help. I’m now down significant power-almost like I’ve lost an entire cylender, but haven’t cleaned the bottom in three years, could it really be a dirty prop!!! Melissa s/v Acedia F38 “Pollution is a silent form of violence” -Ralph Nader “Plastics, like diamonds, are forever!” -The Earth Resource Foundation (for more information on the adverse effects of plastics on human health and the environment, please visit–http://www.earthresource.org/campaigns/capp/capp-overview.html) ~ Please consider the environment prior to printing documents and offset carbon footprint, give electronics a break by shutting them down and unplugging when not in use ~ ----- Original Message ---- From: “amarsib@aol.com” <amarsib@aol.com> To: FreedomOwnersGroup@yahoogroups.com Sent: Sunday, July 13, 2008 4:09:11 PM Subject: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Has anyone had fuel problems? Same time last season and now, I am having loss of power when in gear and black smoke. I purchased a algae-x fuel polisher and additive last season but ended up pumping all the fuel out and cleaning the tank thru the 3 access ports. All was fine after that. But now the problem is back. Any suggestions? I did add algae-x fuel treatment at the end of last season and do keep my tank topped off. Anthony Marsibilio Freedom 36/38 Three Mile Harbor NY No virus found in this incoming message.Checked by AVG - http://www.avg.com Version: 8.0.138 / Virus Database: 270.5.5/1571 - Release Date: 7/24/2008 5:42 PM – Jay Glen ki6jtks/v FantasyFreedom 40 Cat-KetchSan Francisco Bay Area
I’ve never done this and my memory could be wrong but I thought
a mechanic had mentioned using a heat gun.  I know he said to use one to free
up and remove the elbow.
Alan F-33 Hull #51 1982
Behalf Of amarsib@…
Sent: Sunday, August 03, 2008 5:54 PM
Anthony Marsibilio
F 36/38
T 2
<rweeks6508@…>
Bob
Melissa
s/v Acedia F38
“Pollution is a
environment, please visit–100 Environment Essay Topics That Will Inspire Your Eco-Conscious Mind)
<amarsib@…>
smoke.
Any suggestions?
topped off.
Anthony Marsibilio
Freedom 36/38
Jay Glen ki6jtk
s/v Fantasy
Attachment: (image/jpeg) image001.jpg [not stored]
Attachment: (image/jpeg) image002.jpg [not stored]
Good idea ! ThanksFrom: “Alan Kusinitz” <akusinitz@…>Date: Sun, 3 Aug 2008 18:45:00 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: RE: [FreedomOwnersGroup] Fuel Tretment/Black Smoke I’ve never done this and my memory could be wrong but I thought a mechanic had mentioned using a heat gun.  I know he said to use one to free up and remove the elbow. Alan F-33 Hull #51 1982 From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of amarsib@aol.comSent: Sunday, August 03, 2008 5:54 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke I plan to replace the gasket once I find a good method to remove the existing with out scoring the face behind it. From: “Jay Glen” <svfantasy@gmail.com>Date: Sun, 3 Aug 2008 14:43:25 -0700To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke It is best to replace the gasket. Old gaskets cause problems. On Sun, Aug 3, 2008 at 1:27 PM, <amarsib@aol.com> wrote: I removed the exhaust elbow and manifold today and found the openings 1/2 blocked. A mechanic mentioned this may contribute to the loss of power and black smoke. Will try again next wknd after I install the new parts. Any one know the best way to safley remove a gasket stuck to the engine? Anthony Marsibilio F 36/38 T 2 From: “Bob Weeks” <rweeks6508@verizon.net>Date: Fri, 25 Jul 2008 18:21:22 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: RE: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Be careful because I can load my engine at the dock and get a different result when you are out there in the wind, current, etc. Bob From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com]On Behalf Of amarsib@aol.comSent: Friday, July 25, 2008 6:05 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Thankyou Herm and everyone who helped. Although the boat yard coated the prop and shaft with zinc , lots of barnacles etc. was on the prop and shaft. Cleaned it all up (tough to hold your breath and clean at the same time) Loaded the engine while at the dock all seems ok ! From: Melissa <kalicinm@yahoo.com>Date: Thu, 24 Jul 2008 14:12:19 -0700 (PDT)To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Did you ever figure out what caused the lack of power and black smoke? I am having the same issue. I had my injectors rebuilt and the fuel polished and it didn’t help. I’m now down significant power-almost like I’ve lost an entire cylender, but haven’t cleaned the bottom in three years, could it really be a dirty prop!!! Melissa s/v Acedia F38 “Pollution is a silent form of violence” -Ralph Nader “Plastics, like diamonds, are forever!” -The Earth Resource Foundation (for more information on the adverse effects of plastics on human health and the environment, please visit–http://www.earthresource.org/campaigns/capp/capp-overview.html) ~ Please consider the environment prior to printing documents and offset carbon footprint, give electronics a break by shutting them down and unplugging when not in use ~ ----- Original Message ---- From: “amarsib@aol.com” <amarsib@aol.com> To: FreedomOwnersGroup@yahoogroups.com Sent: Sunday, July 13, 2008 4:09:11 PM Subject: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Has anyone had fuel problems? Same time last season and now, I am having loss of power when in gear and black smoke. I purchased a algae-x fuel polisher and additive last season but ended up pumping all the fuel out and cleaning the tank thru the 3 access ports. All was fine after that. But now the problem is back. Any suggestions? I did add algae-x fuel treatment at the end of last season and do keep my tank topped off. Anthony Marsibilio Freedom 36/38 Three Mile Harbor NY No virus found in this incoming message.Checked by AVG - http://www.avg.com Version: 8.0.138 / Virus Database: 270.5.5/1571 - Release Date: 7/24/2008 5:42 PM – Jay Glen ki6jtk s/v Fantasy Freedom 40 Cat-Ketch San Francisco Bay Area
Posted by Barry Stellrecht (yak@…>)
I’ve never used one, but I’ve read about a really interesting concept: Plastic
razor blades. I believe the idea is that they are sharp enough to cut but not
hard enough to scratch stuff (like engine manifolds)…Let us know what
finally works.
Barry
s/v Flutterby, Freedom 33 cat ketch (becoming a junk rig)
I understand that they come in two grades, one more gentle that the
other. Herm
concept: Plastic razor blades. I believe the idea is that they are
sharp enough to cut but not hard enough to scratch stuff (like
engine manifolds)…Let us know what finally works.
Barry
Thanks I will try that. I ordered from loctite a spray product called chisel. Plan on doing this work on friday and hope this fixes the loss of power and black smoke. From: Barry Stellrecht <yak@…>Date: Tue, 05 Aug 2008 16:54:03 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke I’ve never used one, but I’ve read about a really interesting concept: Plastic razor blades. I believe the idea is that they are sharp enough to cut but not hard enough to scratch stuff (like engine manifolds)…Let us know what finally works. Barryamarsib@aol.com wrote: > I plan to replace the gasket once I find a good method to remove the > existing with out scoring the face behind it. > – s/v Flutterby, Freedom 33 cat ketch (becoming a junk rig)
Melissa, I finally resolved my lack of power and black smoke issue. I replaced the mixing elbow on my yanmar 3gm30f. Finally all is good. Anthony T 2 3 mile harbor nyFrom: Melissa <kalicinm@…>Date: Thu, 24 Jul 2008 14:12:19 -0700 (PDT)To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Fuel Tretment/Black Smoke Did you ever figure out what caused the lack of power and black smoke? I am having the same issue. I had my injectors rebuilt and the fuel polished and it didn’t help. I’m now down significant power-almost like I’ve lost an entire cylender, but haven’t cleaned the bottom in three years, could it really be a dirty prop!!! Melissas/v Acedia F38 “Pollution is a silent form of violence” -Ralph Nader “Plastics, like diamonds, are forever!” -The Earth Resource Foundation (for more information on the adverse effects of plastics on human health and the environment, please visit–http://www.earthresource.org/campaigns/capp/capp-overview.html) ~ Please consider the environment prior to printing documents and offset carbon footprint, give electronics a break by shutting them down and unplugging when not in use ~----- Original Message ----From: “amarsib@aol.com” <amarsib@aol.com>To: FreedomOwnersGroup@yahoogroups.comSent: Sunday, July 13, 2008 4:09:11 PMSubject: [FreedomOwnersGroup] Fuel Tretment/Black SmokeHas anyone had fuel problems? Same time last season and now, I am having loss of power when in gear and black smoke.I purchased a algae-x fuel polisher and additive last season but ended uppumping all the fuel out and cleaning the tank thru the 3 access ports.All was fine after that.But now the problem is back.Any suggestions?I did add algae-x fuel treatment at the end of last season and do keep my tank topped off.Anthony MarsibilioFreedom 36/38Three Mile Harbor NY
