G 10 Sail plan
Hi Freedom Lovers: Has anyone experience with the G 10 sail plan?
I am still considering replacing my F33 Cat Ketch wrap around sails.
Thanks John Jones-1982 hull#55-Lady Marion
Hmm… What’s a G10 sail plan?
— In freedomyachts2003@yahoogroups.com, “John Jones” <a1john@…>
Is this the system Gio Schouten had on his UK built F35 CK “Samiel”? He sent out
some
data and pictures which look very interesting, but seem to cause some
compression
loading on the mast. The advantage was full length battens giving a big roach on
the sails,
retaining the wishbones, and not needing a sailtrack to be nailed to the mast.
There was
some correspondence about it last year, I think, but there was a problem with
putting the
pictures into the files at that time.
I suspect Gio is the only person with any great experience of this sailplan,
although
apparently quite a few others have seen it from well astern!
Gerald Freshwater
— In freedomyachts2003@yahoogroups.com, “John Jones” <a1john@>
Found this on the web…
http://www.200myls.nl/verslag/versl-2002-schouten.htm
looks like conventional booms
— In freedomyachts2003@yahoogroups.com, “geraldfreshwater”
CK “Samiel”? He sent out some
some compression
a big roach on the sails,
to the mast. There was
problem with putting the
sailplan, although
Gerald Freshwater
plan?
sails.
That boat is a Freedom 40 or 44, I think, which is his current boat. I have
taken the liberty
of putting a picture in the “miscellaneous” album, of “Samiel” on a run. I’m
sure he’ll give
more info when he is next on the bulletin board, as he is a frequent and
knowledgable
contributor.
Gerald
— In freedomyachts2003@yahoogroups.com, “Dave_Benjamin” <dave_benjamin@…>
some compression
sailplan, although
Gerald Freshwater
plan?
sails.
The G10 sail plan is illustrated in the files section of this Freedom
Group and in the Freedom 44 group site.
John Jones
I have taken the liberty
run. I’m sure he’ll give
and knowledgable
contributor.
Gerald
<dave_benjamin@>
some compression
sailplan, although
Gerald Freshwater
plan?
sails.
Posted by roos8897 (rcroos@…>)
I am the new owner of “Samiel” for the last four years and very happy
with the new G10 sailplan, the rig stands beautiful and she sails quite
fast. the G10 plan has now been copied by another freedom owner in
holland and I am very curious of his experience handling the sails… if
you have specific questions please let me know . Rudy F35cb
John Jones
and knowledgable
contributor.
Gerald
<dave_benjamin@>
some compression
giving
nailed
this
sailplan, although
Gerald Freshwater
<a1john@>
plan?
around
sails.
That’s a pretty interesting rig. It wouldn’t work for Bright Star -
she’s got a radar on the mizzen and a deck/steaming light on the
main, but it’s pretty obvious what the advantages of a system like
that is. Very nice.
— In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@…>
happy
quite
sails… if
Freedom
John Jones
boat.
on a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
cause
some compression
giving
nailed
was a
of
this
sailplan, although
astern!
Gerald Freshwater
<a1john@>
sail
plan?
around
sails.
We had a Freedom race here in the NL’s last summer, and Samiel with
her G10 rig almost sailed away from the two F44’s in the party. This
G10 rig really goes like stink!
some compression
sailplan, although
Gerald Freshwater
plan?
sails.
Your posting is much appreciated. I have a question about how the
wishbone is “hung” from the mast and sail. On my U.S. F33, 1982,#55,
a rope “girdel” extends from the left front (port) of the wishbone,
back thru a gromet in the wrap-around sail, around the rear of the
mast and then foreward thru a gromet on the right side and then out to
tie on the right front of the wishbone. Sounds complicated but is
very simple and I think a better system than used sails I have seen
from the similar U.K. F35 rig. Hoisting the sail also lifts the
wishbone about two feet or so. I have no problems with this wishbone
system in use for the last 16 years. I can conceive of adapting the
G 10 rig to this type of system but what you are using may be better?
So, please, a description and clarification. I am reluctant to
drill any new holes in the masts unless desperate. Thanks, John Jones
John Jones
and knowledgable
contributor.
Gerald
<dave_benjamin@>
some compression
giving
nailed
this
sailplan, although
Gerald Freshwater
<a1john@>
plan?
around
sails.
John,if I understand the situation correctly , you have fixed to
wishbone at a specific height and by hoisting the sail the wishbone
is automatically hoisted aswel to reflect the correct angle of the
wishbone. The only thing that is different is the fact that by means
of a block(on the mast)connected at the point were the wishbone rope
is hoisted, I can either hoist or lower the wishbone directly from
the cockpit.I hope this makes some sense.
Rudy
1982,#55,
out to
wishbone
better?
Jones
— In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@>
happy
sails quite
in
sails… if
Freedom
John Jones
current boat.
of “Samiel” on a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
— In
to cause
some compression
battens
giving
be
nailed
there was a
experience of
this
sailplan, although
astern!
Gerald Freshwater
<a1john@>
10 sail
plan?
wrap
around
sails.
Rudy, Thanks for reply. I can do that likewise and it also now
becomes clear how the reefing system will work. Sounds like a great
system and now all I have to do is locate a sail-maker willing to
venture into the “unknown”. If you have the actual dimensions of
your luff and foot (all eye to eye), batten lengths, and height of
first batten above the “tack” it would be very helpful. I can scale
the info from drawings and pics but am unclear about your UK built 35
luff as a starting point. John
Rudy
1982,#55,
out to
wishbone
better?
Jones
happy
sails quite
in
sails… if
Freedom
John Jones
current boat.
of “Samiel” on a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
— In
to cause
some compression
battens
giving
be
nailed
there was a
experience of
this
sailplan, although
astern!
Gerald Freshwater
<a1john@>
10 sail
plan?
wrap
around
sails.
john, unfortuanately i dont have those particulars and the sailmaker
that does have them went out of business a year ago.(Murphy’s law I
guess)
there is one alternative the friend that copied G10 sail this year
probably has these facts i will check with him .will let you know
soonest Rudy
[— In freedomyachts2003@yahoogroups.com, “John Jones”
great
scale
35
wishbone
means
rope
from
Rudy
1982,#55,
wishbone,
then
out to
but is
seen
wishbone
adapting
better?
to
John
Jones
very
happy
sails quite
owner
in
sails… if
this
Freedom
John Jones
— In
current boat.
of “Samiel” on a
is a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
— In
F35
seem
to cause
some compression
battens
giving
to
be
nailed
there was a
experience of
this
sailplan, although
astern!
Gerald Freshwater
— In
Jones”
<a1john@>
the G
10 sail
plan?
Ketch
wrap
around
sails.
Hi Freedom Lovers: Rudy has graciously provided some much needed
info and clarification and I can’t thank him enough. But, has anyone
here in the U.S. of A. tried this G10 system or can add first hand
knowledge or know where I can see the rig? I intend to proceed with
such a sailplan after most of our hurricane season is over. John Jones
guess)
soonest Rudy
great
scale
35
wishbone
means
rope
from
Rudy
1982,#55,
wishbone,
then
out to
but is
seen
wishbone
adapting
better?
to
John
Jones
very
happy
sails quite
owner
in
sails… if
this
Freedom
John Jones
— In
current boat.
of “Samiel” on a
is a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
— In
F35
seem
to cause
some compression
battens
giving
to
be
nailed
there was a
experience of
this
sailplan, although
astern!
Gerald Freshwater
— In
Jones”
<a1john@>
the G
10 sail
plan?
Ketch
wrap
around
sails.
John, I have posted some images to give you an impression, I will
try to obtain some detailed images Rudy
anyone
with
Jones
sailmaker
law I
guess)
year
know
soonest Rudy
now
a
great
to
dimensions of
height of
scale
built
35
fixed to
wishbone
of
by
means
wishbone
rope
directly
from
Rudy
<a1john@>
how
F33,
1982,#55,
wishbone,
rear of
then
out to
complicated
but is
have
seen
lifts
this
wishbone
adapting
be
better?
reluctant
to
John
Jones
<rcroos@>
very
happy
she
sails quite
freedom
owner
in
sails… if
F35cb
<a1john@>
of
this
Freedom
John Jones
— In
his
current boat.
of “Samiel” on a
he
is a
frequent
and knowledgable
contributor.
Gerald
— In
<dave_benjamin@>
schouten.htm
— In
built
F35
but
seem
to cause
some compression
length
battens
giving
sailtrack
to
be
nailed
but
there was a
experience of
this
sailplan, although
well
astern!
Gerald Freshwater
— In
— In
Jones”
<a1john@>
with
the G
10 sail
plan?
Ketch
wrap
around
sails.
Posted by Jack George (chamela7@…>)
Hi John, Remember me, I have a printed 4pg.brosure on gio,s saill plan. I was going to have one made,but after more thought did somthing els. Iam using a soft wing on my mizzen, it has a three ft. gaff boom on top giving the sail the profile of a air plane wing. the sail wraps around the mast, and 2ft. back it has a zipper running the lingth of the sail. It sounds nuts but I have testing it and I got to tell you it workes!!! Iam still fooling around with the upper boom fitting. Ive got some photos of the wing mizzen under sail,and you can really see the differnce between the old main. Let me know if you want me to send you Gios sail plan Jack "chamela"John Jones <a1john@…> wrote: Hi Freedom Lovers: Rudy has graciously provided some much neededinfo and clarification and I can’t thank him enough. But, has
anyonehere in the U.S. of A. tried this G10 system or can add first handknowledge or know where I can see the rig? I intend to proceed withsuch a sailplan after most of our hurricane season is over. John Jones— In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@…> wrote:>> john, unfortuanately i dont have those particulars and the sailmaker > that does have them went out of business a year ago.(Murphy’s law I > guess)> there is one alternative the friend that copied G10 sail this year > probably has these facts i will check with him .will let you know > soonest Rudy> > [— In freedomyachts2003@yahoogroups.com, “John Jones” > <a1john@> wrote:> >> > Rudy, Thanks for reply. I can do that likewise and it also now> > becomes clear how the reefing system will work. Sounds like a
great> > system and now all I have to do is locate a sail-maker willing to> > venture into the “unknown”. If you have the actual dimensions of> > your luff and foot (all eye to eye), batten lengths, and height of> > first batten above the “tack” it would be very helpful. I can > scale> > the info from drawings and pics but am unclear about your UK built > 35> > luff as a starting point. John> > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@> > wrote:> > >> > > John,if I understand the situation correctly , you have fixed to > > > wishbone at a specific height and by hoisting the sail the > wishbone > > > is automatically hoisted aswel to reflect the correct angle of > the > > >
wishbone. The only thing that is different is the fact that by > means > > > of a block(on the mast)connected at the point were the wishbone > rope > > > is hoisted, I can either hoist or lower the wishbone directly > from > > > the cockpit.I hope this makes some sense.> > > Rudy > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “John Jones” <a1john@> > > > wrote:> > > >> > > > Your posting is much appreciated. I have a question about how > the> > > > wishbone is “hung” from the mast and sail. On my U.S. F33, > > > 1982,#55,> > > > a rope “girdel” extends from the left front (port) of the > wishbone,> > > > back thru a gromet in the wrap-around sail, around the rear of > the> > >
mast and then foreward thru a gromet on the right side and > then > > > out to> > > > tie on the right front of the wishbone. Sounds complicated > but is> > > > very simple and I think a better system than used sails I have > seen> > > > from the similar U.K. F35 rig. Hoisting the sail also lifts > the> > > > wishbone about two feet or so. I have no problems with this > > > wishbone> > > > system in use for the last 16 years. I can conceive of > adapting > > > the> > > > G 10 rig to this type of system but what you are using may be > > > better?> > > > So, please, a description and clarification. I am reluctant > to> > > > drill any new holes in the masts unless desperate. Thanks, > John
Jones> > > > > > > > > > > > > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@> > > > wrote:> > > > >> > > > > > > > > > I am the new owner of “Samiel” for the last four years and > very > > > happy> > > > > with the new G10 sailplan, the rig stands beautiful and she > > > sails quite> > > > > fast. the G10 plan has now been copied by another freedom > owner > > > in> > > > > holland and I am very curious of his experience handling the > > > sails… if> > > > > you have specific questions please let me know . Rudy F35cb> > > > > > > > > >
freedomyachts2003@yahoogroups.com, “John Jones” <a1john@> > wrote:> > > > > >> > > > > > The G10 sail plan is illustrated in the files section of > this > > > Freedom> > > > > > Group and in the Freedom 44 group site.> > > > > > John Jones> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > > — In > freedomyachts2003@yahoogroups.com, “geraldfreshwater”> > > > > > freshwater@ wrote:> > > > > > >> > > > > > > That boat is a Freedom 40 or 44, I think, which is his
current boat.> > > > > > I have taken the liberty> > > > > > > of putting a picture in the “miscellaneous” album, > > > of “Samiel” on a> > > > > > run. I’m sure he’ll give> > > > > > > more info when he is next on the bulletin board, as he > is a > > > frequent> > > > > > and knowledgable> > > > > > > contributor.> > > > > > >> > > > > > > Gerald> > > > > > >> > > > > > >> > > > > > > — In freedomyachts2003@yahoogroups.com, “Dave_Benjamin”> > > > > > <dave_benjamin@>> > > > > > > wrote:> > > > > > > >> > > > > > > > Found this on the web…>
http://www.200myls.nl/verslag/versl-2002-schouten.htm> > > > > > > >> > > > > > > > looks like conventional booms> > > > > > > >> > > > > > > > — In > > > freedomyachts2003@yahoogroups.com, “geraldfreshwater”> > > > > > > > <freshwater@> wrote:> > > > > > > > >> > > > > > > > > Is this the system Gio Schouten had on his UK built > F35> > > > > > > > CK “Samiel”? He sent out some> > > > > > > > > data and pictures which look very interesting, but > seem > > > to cause> > > > > > > > some compression> > > > > > > >
loading on the mast. The advantage was full length > > > battens> > > > > giving> > > > > > > > a big roach on the sails,> > > > > > > > > retaining the wishbones, and not needing a sailtrack > to > > > be> > > > > nailed> > > > > > > > to the mast. There was> > > > > > > > > some correspondence about it last year, I think, but > > > there was a> > > > > > > > problem with putting the> > > > > > > > > pictures into the files at that time.> > > > > > > > >> > > > > > > > > I suspect Gio is the only person with any great > > > experience of> > > > > this> > > > > > > > sailplan,
although> > > > > > > > > apparently quite a few others have seen it from well > > > astern!> > > > > > > > >> > > > > > > > > Gerald Freshwater> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > > — In > freedomyachts2003@yahoogroups.com, “lance_ryley”> > > > > > > > <lance_ryley@> wrote:> > > > > > > > > >> > > > > > > > > > Hmm… What’s a G10 sail plan?> > > > > > > > > >> > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “John > Jones”> > > > > <a1john@>>
wrote:> > > > > > > > > > >> > > > > > > > > > > Hi Freedom Lovers: Has anyone experience with > the G > > > 10 sail> > > > > > > > plan?> > > > > > > > > > > I am still considering replacing my F33 Cat > Ketch > > > wrap> > > > > around> > > > > > > > sails.> > > > > > > > > > > Thanks John Jones-1982 hull#55-Lady Marion> > > > > > > > > > >> > > > > > > > > >> > > > > > > > >> > > > > > > >> > > > > > >> > > > > >> > > > >> > > >> > >>
Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail Beta.
Posted by Peter Schäfer (petersch@…>)
Hi Jack, hi all,
Would be nice if you could post the photos to the PHOTOS section of the board!
Besides: there is a F35/33 for sale in Plymouth/UK with zippered pockets around the masts. Have a look at it at boats.com. I contacted the owner some time ago and this is what he mailed to me:
…My sails are a modification to the original in that they have a zipped sleeve around the mast. This cuts down the weight aloft by almost half. I notice the difference when sailing as i have to reef less. The sail is also easier to shape using the outhaul and halyard tension as well as being much easier to stow.
I have two sets of sails, one by Dolphin Sails of the UK (on web) and one set made by a local sailmaker. In both the profile is about 2 meters so you can get “inside” the envelope to reach halyards etc - which run inside the fold. In one set the wrap is of a lighter material to make stowing even easier.
The single skin also makes reefing more effective…
May be this is of interest to some of you,
Greetings
Peter
Jack George wrote:
Hi John, Remember me, I have a printed 4pg.brosure on gio,s saill plan. I was going to have one made,but after more thought did somthing els. Iam using a soft wing on my mizzen, it has a three ft. gaff boom on top giving the sail the profile of a air plane wing. the sail wraps around the mast, and 2ft. back it has a zipper running the lingth of the sail. It sounds nuts but I have testing it and I got to tell you it workes!!! Iam still fooling around with the upper boom fitting. Ive got some photos of the wing mizzen under sail, and you can really see the differnce between the old main. Let me know if you want me to send you Gios sail plan Jack “chamela”
Hi Jack: Nice to hear of your new soft wing. Interesting, hmm.
Please send me a copy of your G10 sailplan. I have what GIO has
posted on this group in the past. Thanks John Jones
— In freedomyachts2003@yahoogroups.com, Jack George <chamela7@…>
guess)
soonest Rudy
great
scale
35
wishbone
means
rope
from
Rudy
1982,#55,
wishbone,
then
out to
but is
seen
wishbone
adapting
better?
to
John
Jones
very
happy
sails quite
owner
in
sails… if
this
Freedom
John Jones
— In
current boat.
of “Samiel” on a
is a
frequent
and knowledgable
contributor.
Gerald
<dave_benjamin@>
— In
F35
seem
to cause
some compression
battens
giving
to
be
nailed
there was a
experience of
this
sailplan, although
astern!
Gerald Freshwater
— In
Jones”
<a1john@>
the G
10 sail
plan?
Ketch
wrap
around
sails.
SPONSORED LINKS
Sailing schools Sailing instruction Sailing lesson
Sailing course Sailing adventure Sailing
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003" on the web.
Service.
Do you Yahoo!?
Ok John, send me your land add. and I will send you what I have Plus a photo of what Iam doing. JackJohn Jones <a1john@…> wrote: Hi Jack: Nice to hear of your new soft wing. Interesting, hmm. Please send me a copy of your G10 sailplan. I have what GIO has posted on this group in the past. Thanks John Jones — In freedomyachts2003@yahoogroups.com, Jack George <chamela7@…> wrote: > > Hi John, Remember me, I have a printed 4pg.brosure on gio,s saill plan. I was going to have one made,but after more thought did somthing els. Iam using a soft wing on my mizzen, it has a three ft. gaff boom on top giving the sail the profile of a air plane wing. the sail wraps around the mast, and 2ft.
back it has a zipper running the lingth of the sail. It sounds nuts but I have testing it and I got to tell you it workes!!! Iam still fooling around with the upper boom fitting. Ive got some photos of the wing mizzen under sail,and you can really see the differnce between the old main. Let me know if you want me to send you Gios sail plan Jack “chamela” > > John Jones <a1john@…> wrote: Hi Freedom Lovers: Rudy has graciously provided some much needed > info and clarification and I can’t thank him enough. But, has anyone > here in the U.S. of A. tried this G10 system or can add first hand > knowledge or know where I can see the rig? I intend to proceed with > such a sailplan after most of our hurricane season is over. John Jones > > > — In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@>
wrote: > > > > john, unfortuanately i dont have those particulars and the sailmaker > > that does have them went out of business a year ago.(Murphy’s law I > > guess) > > there is one alternative the friend that copied G10 sail this year > > probably has these facts i will check with him .will let you know > > soonest Rudy > > > > [— In freedomyachts2003@yahoogroups.com, “John Jones” > > <a1john@> wrote: > > > > > > Rudy, Thanks for reply. I can do that likewise and it also now > > > becomes clear how the reefing system will work. Sounds like a > > great > > > system and now all I have to do is locate a sail-maker willing to > > > venture into the “unknown”. If you have the actual dimensions of > > > your luff
and foot (all eye to eye), batten lengths, and height of > > > first batten above the “tack” it would be very helpful. I can > > scale > > > the info from drawings and pics but am unclear about your UK built > > 35 > > > luff as a starting point. John > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@> > > wrote: > > > > > > > > John,if I understand the situation correctly , you have fixed to > > > > wishbone at a specific height and by hoisting the sail the > > wishbone > > > > is automatically hoisted aswel to reflect the correct angle of > > the > > > > wishbone. The only thing that is different is the fact that by > > means
of a block(on the mast)connected at the point were the wishbone > > rope > > > > is hoisted, I can either hoist or lower the wishbone directly > > from > > > > the cockpit.I hope this makes some sense. > > > > Rudy > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “John Jones” <a1john@> > > > > wrote: > > > > > > > > > > Your posting is much appreciated. I have a question about how > > the > > > > > wishbone is “hung” from the mast and sail. On my U.S. F33, > > > > 1982,#55, > > > > > a rope “girdel” extends from the left front (port) of the > > wishbone, > > > > > back thru a gromet in the wrap-around sail,
around the rear of > > the > > > > > mast and then foreward thru a gromet on the right side and > > then > > > > out to > > > > > tie on the right front of the wishbone. Sounds complicated > > but is > > > > > very simple and I think a better system than used sails I have > > seen > > > > > from the similar U.K. F35 rig. Hoisting the sail also lifts > > the > > > > > wishbone about two feet or so. I have no problems with this > > > > wishbone > > > > > system in use for the last 16 years. I can conceive of > > adapting > > > > the > > > > > G 10 rig to this type of system but what you are using may be > > > > better? > > > > > So, please, a
description and clarification. I am reluctant > > to > > > > > drill any new holes in the masts unless desperate. Thanks, > > John > > > > Jones > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “roos8897” <rcroos@> > > > > wrote: > > > > > > > > > > > > > > > > > > I am the new owner of “Samiel” for the last four years and > > very > > > > happy > > > > > > with the new G10 sailplan, the rig stands beautiful and she > > > > sails quite > > > > > > fast. the G10 plan has now been copied
by another freedom > > owner > > > > in > > > > > > holland and I am very curious of his experience handling the > > > > sails… if > > > > > > you have specific questions please let me know . Rudy F35cb > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > freedomyachts2003@yahoogroups.com, “John Jones” <a1john@> > > wrote: > > > > > > > > > > > > > > The G10 sail plan is illustrated in the files section of > > this > > > > Freedom > > > > > > > Group and in the Freedom 44 group site. > > > > > >
John Jones > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > — In > > freedomyachts2003@yahoogroups.com, “geraldfreshwater” > > > > > > > freshwater@ wrote: > > > > > > > > > > > > > > > > That boat is a Freedom 40 or 44, I think, which is his > > > > current boat. > > > > > > > I have taken the liberty > > > > > > > > of putting a picture in the “miscellaneous” album, > > > > of “Samiel” on a > > > > > > > run. I’m sure he’ll give > > > > > > > > more info when he is next on the bulletin board, as he > > is a > > >
frequent > > > > > > > and knowledgable > > > > > > > > contributor. > > > > > > > > > > > > > > > > Gerald > > > > > > > > > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “Dave_Benjamin” > > > > > > > <dave_benjamin@> > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > Found this on the web… > > > > > > > > > http://www.200myls.nl/verslag/versl-2002-schouten.htm > > > > > > > > > > > > > > > > > > looks like conventional booms > > > >
— In > > > > freedomyachts2003@yahoogroups.com, “geraldfreshwater” > > > > > > > > > <freshwater@> wrote: > > > > > > > > > > > > > > > > > > > > Is this the system Gio Schouten had on his UK built > > F35 > > > > > > > > > CK “Samiel”? He sent out some > > > > > > > > > > data and pictures which look very interesting, but > > seem > > > > to cause > > > > > > > > > some compression > > > > > > > > > > loading on the mast. The advantage was full length > > > > battens > > > > > > giving > > > > > > > > > a big roach on the
sails, > > > > > > > > > > retaining the wishbones, and not needing a sailtrack > > to > > > > be > > > > > > nailed > > > > > > > > > to the mast. There was > > > > > > > > > > some correspondence about it last year, I think, but > > > > there was a > > > > > > > > > problem with putting the > > > > > > > > > > pictures into the files at that time. > > > > > > > > > > > > > > > > > > > > I suspect Gio is the only person with any great > > > > experience of > > > > > > this > > > > > > > > > sailplan, although > > > > > > > > > > apparently quite a few others
have seen it from well > > > > astern! > > > > > > > > > > > > > > > > > > > > Gerald Freshwater > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > — In > > freedomyachts2003@yahoogroups.com, “lance_ryley” > > > > > > > > > <lance_ryley@> wrote: > > > > > > > > > > > > > > > > > > > > > > Hmm… What’s a G10 sail plan? > > > > > > > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “John > > Jones” > > > > > >
<a1john@> > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > Hi Freedom Lovers: Has anyone experience with > > the G > > > > 10 sail > > > > > > > > > plan? > > > > > > > > > > > > I am still considering replacing my F33 Cat > > Ketch > > > > wrap > > > > > > around > > > > > > > > > sails. > > > > > > > > > > > > Thanks John Jones-1982 hull#55-Lady Marion > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
SPONSORED LINKS > Sailing schools Sailing instruction Sailing lesson Sailing course Sailing adventure Sailing > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group “freedomyachts2003” on the web. > > To unsubscribe from this group, send an email to: > freedomyachts2003-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Do you Yahoo!? > Everyone is raving about the all-new Yahoo! Mail Beta. > __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Hi Peter, I was unable to locate the UK zippered boat you told me about, and I am curious to see if he used the same triangle shape. I changed the shape with a boom on top so the sail looks like one wing of a world war 2 air plane. Just did this and havent been able to really test it out having only been out once. Ive only done the mizzen and you can see the differance between the 2 sails. Iam quite excited about it as it seems to solve the full batton problem, Plus you dont get turbulance behind the mast, like you do when you go to a track one ply system.I don’t know how to post photos yet, Jack on “CHAMELA” Jacks wing sailPeter Schäfer <petersch@…> wrote:Re: G 10 Sail plan Hi Jack, hi all, Would be
nice if you could post the photos to the PHOTOS section of the board! Besides: there is a F35/33 for sale in Plymouth/UK with zippered pockets around the masts. Have a look at it at boats.com. I contacted the owner some time ago and this is what he mailed to me: …My sails are a modification to the original in that they have a zipped sleeve around the mast. This cuts down the weight aloft by almost half. I notice the difference when sailing as i have to reef less. The sail is also easier to shape using the outhaul and halyard tension as well as being much easier to stow. I have two sets of sails, one by Dolphin Sails of the UK (on web) and one set made by a local sailmaker. In both the profile is about 2 meters so you can get “inside” the
envelope to reach halyards etc - which run inside the fold. In one set the wrap is of a lighter material to make stowing even easier. The single skin also makes reefing more effective… May be this is of interest to some of you, Greetings Peter Jack George wrote: Hi John, Remember me, I have a printed 4pg.brosure on gio,s saill plan. I was going to have one made,but after more thought did somthing els. Iam using a soft wing on my mizzen, it has a three ft. gaff boom on top giving the sail the profile of a air plane wing. the sail wraps
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
