I own a 39 Express and several years ago I purchased two vangs from
Mark Garhauer. I explained to Mark that I had installed a unique
seal around the mast {thats another story}which I did not want to
disturb with their collar. So together we designed a fitting that
attaches to the original bail on the aluminum mast collar. It works
fine, is less expensive and easy to install. Anyone interested
could contact Mark at Garhauer.
John Little— In freedomyachts2003@yahoogroups.com, “markedwards55”
<markedwards55@y…> wrote:
The issue of vang collar slippage just came up last week with a
Freedom 38 owner in CA. Even with the hard rubber material
between
the mast and vang collar wall there can still be some movement in
this compression ring. What I suggested and what I have seen
done
is to add stainless brackets from the port and starboard bolts
that
compress the vang bracket around the mast to the aluminum mast
collar that is bolted to the deck. You might also lash the vang
collar on the centerline just under the vang axle down to the mast
collar. This two or three point approach should keep the vang
bracket from moving. Good luck, Mark Edwards, Freedom Yachts
I installed a Garhauer rigid boom vang and it came without any
sort of
rubber sleeve. Thinking that some sort of sleeve would prevent
slippage
(since there’s a limit to how hard you can tighten it without
risking
crushing the mast), I used a hard rubber sleeve. The sleeve
seems
to
have moved a bit in a year, but I’m not sure if that was due to
insufficient tightening or the sleeve itself.
This email and any files transmitted with it are confidential
intended solely for the use of the individual or entity to whom
they
are addressed. If you have received this email in error please
notify the system manager. This message contains confidential
information and is intended only for the individual named. If you
are not the named addressee you should not disseminate, distribute
or copy this e-mail.
works
between
done
that
mast
sort of
slippage
risking
seems
to
they
distribute
So how can I contact Mark Garhauer? I am interested in adding a
solid vang and will need the mast collar to go with it. I have seen
the collar on other Freedoms - some with brackets that run between
the mast collar seem and the mast ring deck bolt and others with
just the rubber. It would seem that aome mechanical connection to
the deck collar is recommended for these things?
from
unique
to
that
works
a
between
in
done
that
vang
mast
any
sort of
prevent
slippage
without
risking
seems
to
to
confidential
whom
they
you
distribute
seen
from
unique
to
that
works
interested
with
a
between
movement
in
seen
done
bolts
that
mast
vang
mast
vang
any
sort of
prevent
slippage
without
risking
sleeve
seems
to
due
to
confidential
whom
they
please
confidential
If
you
distribute
Just get their phone number from the web site, call and ask for Mark. I spoke to him when they made my vang and collar.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of lance_ryleySent: Wednesday, July 20, 2005 8:01 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Garhauer mast collarYou could start here:http://garhauermarine.com/--- In freedomyachts2003@yahoogroups.com, “Bruce” <bcw@f…> wrote:> So how can I contact Mark Garhauer? I am interested in adding a > solid vang and will need the mast collar to go with it. I have seen > the collar on other Freedoms - some with brackets that run between > the mast collar seem and the mast ring deck bolt and others with > just the rubber. It would seem that aome mechanical connection to > the deck collar is recommended for these things?> > — In freedomyachts2003@yahoogroups.com, “sailing20027” > <sailing20027@y…> wrote:> > I also have a 39’ Express. We cut up an old fender to use between > > the mast and the collar. Has been working great for 7 years> > > > Killin’ Time > > SF Bay> > — In freedomyachts2003@yahoogroups.com, “wink50109” > <jlittle@o…> > > wrote:> > > I own a 39 Express and several years ago I purchased two vangs > from > > > Mark Garhauer. I explained to Mark that I had installed a > unique > > > seal around the mast {thats another story}which I did not want > to > > > disturb with their collar. So together we designed a fitting > that > > > attaches to the original bail on the aluminum mast collar. It > > works > > > fine, is less expensive and easy to install. Anyone interested > > > could contact Mark at Garhauer.> > > John Little— In > > freedomyachts2003@yahoogroups.com, “markedwards55” > > > <markedwards55@y…> wrote:> > > > The issue of vang collar slippage just came up last week with > a > > > > Freedom 38 owner in CA. Even with the hard rubber material > > > between > > > > the mast and vang collar wall there can still be some movement > in > > > > this compression ring. What I suggested and what I have seen > > > done > > > > is to add stainless brackets from the port and starboard bolts > > > that > > > > compress the vang bracket around the mast to the aluminum mast > > > > collar that is bolted to the deck. You might also lash the > vang > > > > collar on the centerline just under the vang axle down to the > > mast > > > > collar. This two or three point approach should keep the vang > > > > bracket from moving. Good luck, Mark Edwards, Freedom Yachts> > > > > > > > — In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” > > > > <ajlorman@y…> wrote:> > > > > I installed a Garhauer rigid boom vang and it came without > any > > > > sort of> > > > > rubber sleeve. Thinking that some sort of sleeve would > prevent > > > > slippage> > > > > (since there’s a limit to how hard you can tighten it > without > > > > risking> > > > > crushing the mast), I used a hard rubber sleeve. The sleeve > > > seems > > > > to> > > > > have moved a bit in a year, but I’m not sure if that was due > to> > > > > insufficient tightening or the sleeve itself.> > > > > > > > > > Al Lorman> > > > > F30 Ab Initio> > > > > > > > > > -----Original Message-----> > > > > From: freedomyachts2003@yahoogroups.com> > > > > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of > andre > > > > laviolette> > > > > Sent: Saturday, June 11, 2005 1:45 PM> > > > > To: freedomyachts2003@yahoogroups.com> > > > > Subject: Re: [freedomyachts2003] Freedom-38 Vang Collar > Slipping> > > > > > > > > > > > > > > Jettebleu> > > > > > > > > > My Garhauer rigid vang has a rubber material between the > mast > > > and > > > > the> > > > > stainless mast collar. It is simillar to inner tube rubber.> > > > > > > > > > Andre " Scaramanga"> > > > > > > > > > jettebleu <jettebleu@y…> wrote:> > > > > > > > > > My Vang collar slipped up my mast last week. Is this > a common> > > > > problem?> > > > > Is there a recommended solution?> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________> > > > > Do You Yahoo!?> > > > > Tired of spam? Yahoo! Mail has the best spam protection > around > > > > > http://mail.yahoo.com > > > > > > > > > > _____ > > > > > > > > > > Yahoo! Groups Links> > > > > > > > > > > > > > > * To visit your group on the web, go to:> > > > > http://groups.yahoo.com/group/freedomyachts2003/> > > > > > > > > > * To unsubscribe from this group, send an email to:> > > > > freedomyachts2003-unsubscribe@yahoogroups.com> > > > > <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?> > > > subject=Unsubscrib> > > > > e> > > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! > Terms of> > > > > Service http://docs.yahoo.com/info/terms/ . > > > > > > > > > > > > > > > This email and any files transmitted with it are > confidential > > > and > > > > intended solely for the use of the individual or entity to > whom > > > they > > > > are addressed. If you have received this email in error please > > > > notify the system manager. This message contains confidential > > > > information and is intended only for the individual named. If > you > > > > are not the named addressee you should not disseminate, > > distribute > > > > or copy this e-mail.IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Try Garhauer.com. BTW,I hve 2 of his vangs,for 4 seasons,and am vv
satisfied. He also made mast collars to replace the aluminum originals.
Sent: Tuesday, July 19, 2005 9:51 PM
from
unique
to
that
works
a
between
in
done
that
vang
mast
any
sort of
prevent
slippage
without
risking
seems
to
to
confidential
whom
they
you
distribute
Sorry to jump in on this thread, but could someone let me know the
advantages of having a solid boom vang vs the standard block and
tackle that comes standard on the Freedom rig?
originals.
seen
between
to
from
unique
to
that
works
interested
with
a
between
movement
in
seen
done
bolts
that
mast
vang
mast
vang
Yachts
any
sort of
prevent
slippage
without
risking
sleeve
seems
to
due
to
confidential
whom
they
please
confidential
If
you
distribute
I did it to get the lazyjacks out of the way when making sail. The upper
battens will catch on the jacks.
Sent: Tuesday, July 26, 2005 1:58 PM
originals.
seen
between
to
from
unique
to
that
works
interested
with
a
between
movement
in
seen
done
bolts
that
mast
vang
mast
vang
Yachts
any
sort of
prevent
slippage
without
risking
sleeve
seems
to
due
to
confidential
whom
they
please
confidential
If
you
distribute
Paul
The main advantage of a rigid vang is that you can discard the topping lift. In this maner the boom never drops on your head or… Also, very practical when reefing as there is no need to reset topping lift. In very light airs ( racing ) you can delete the weight of the boom .
Andre " Scaramanga "bespokebermuda <bespokebermuda@…> wrote:
Sorry to jump in on this thread, but could someone let me know the advantages of having a solid boom vang vs the standard block and tackle that comes standard on the Freedom rig?Thanks Paul.— In freedomyachts2003@yahoogroups.com, Jerome Weinraub <zayde@o…> wrote:> Try Garhauer.com. BTW,I hve 2 of his vangs,for 4 seasons,and am vv > satisfied. He also made mast collars to replace the aluminum originals.> > > > ----- Original Message ----- > From: “Bruce” <bcw@f…>> To: <freedomyachts2003@yahoogroups.com>> Sent: Tuesday, July 19, 2005 9:51 PM> Subject: [freedomyachts2003] Re: Garhauer mast collar> > > > So how can I contact Mark Garhauer? I am interested in adding a> > solid vang and will need the mast collar to go with
it. I have seen> > the collar on other Freedoms - some with brackets that run between> > the mast collar seem and the mast ring deck bolt and others with> > just the rubber. It would seem that aome mechanical connection to> > the deck collar is recommended for these things?> >> > — In freedomyachts2003@yahoogroups.com, “sailing20027”> > <sailing20027@y…> wrote:> >> I also have a 39’ Express. We cut up an old fender to use between> >> the mast and the collar. Has been working great for 7 years> >>> >> Killin’ Time> >> SF Bay> >> — In freedomyachts2003@yahoogroups.com, “wink50109”> > <jlittle@o…>> >> wrote:> >> > I own a 39 Express and several years ago I purchased two vangs> > from> >> > Mark Garhauer. I
explained to Mark that I had installed a> > unique> >> > seal around the mast {thats another story}which I did not want> > to> >> > disturb with their collar. So together we designed a fitting> > that> >> > attaches to the original bail on the aluminum mast collar. It> >> works> >> > fine, is less expensive and easy to install. Anyone interested> >> > could contact Mark at Garhauer.> >> > John Little— In> >> freedomyachts2003@yahoogroups.com, “markedwards55”> >> > <markedwards55@y…> wrote:> >> > > The issue of vang collar slippage just came up last week with> > a> >> > > Freedom 38 owner in CA. Even with the hard rubber material> >> > between> >> > > the mast and vang collar wall there can still
be some movement> > in> >> > > this compression ring. What I suggested and what I have seen> >> > done> >> > > is to add stainless brackets from the port and starboard bolts> >> > that> >> > > compress the vang bracket around the mast to the aluminum mast> >> > > collar that is bolted to the deck. You might also lash the> > vang> >> > > collar on the centerline just under the vang axle down to the> >> mast> >> > > collar. This two or three point approach should keep the vang> >> > > bracket from moving. Good luck, Mark Edwards, Freedom Yachts> >> > >> >> > > — In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.”> >> > > <ajlorman@y…> wrote:> >> >
I installed a Garhauer rigid boom vang and it came without> > any> >> > > sort of> >> > > > rubber sleeve. Thinking that some sort of sleeve would> > prevent> >> > > slippage> >> > > > (since there’s a limit to how hard you can tighten it> > without> >> > > risking> >> > > > crushing the mast), I used a hard rubber sleeve. The sleeve> >> > seems> >> > > to> >> > > > have moved a bit in a year, but I’m not sure if that was due> > to> >> > > > insufficient tightening or the sleeve itself.> >> > > >> >> > > > Al Lorman> >> > > > F30 Ab Initio> >> > > >> >> > > > -----Original Message-----> >> >
From: freedomyachts2003@yahoogroups.com> >> > > > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of> > andre> >> > > laviolette> >> > > > Sent: Saturday, June 11, 2005 1:45 PM> >> > > > To: freedomyachts2003@yahoogroups.com> >> > > > Subject: Re: [freedomyachts2003] Freedom-38 Vang Collar> > Slipping> >> > > >> >> > > >> >> > > > Jettebleu> >> > > >> >> > > > My Garhauer rigid vang has a rubber material between the> > mast> >> > and> >> > > the> >> > > > stainless mast collar. It is simillar to inner tube rubber.> >> > > >> >> > > > Andre " Scaramanga"> >> > > >> >> > > >
jettebleu <jettebleu@y…> wrote:> >> > > >> >> > > > My Vang collar slipped up my mast last week. Is this> > a common> >> > > > problem?> >> > > > Is there a recommended solution?> >> > > >> >> > > >> >> > > >> >> > > >> >> > > >> >> > > > __________________________________________________> >> > > > Do You Yahoo!?> >> > > > Tired of spam? Yahoo! Mail has the best spam protection> > around> >> > > > http://mail.yahoo.com> >> > > >> >> > > > _____> >> > > >> >> > > > Yahoo! Groups Links> >> > > >> >> >
To visit your group on the web, go to:> >> > > > http://groups.yahoo.com/group/freedomyachts2003/> >> > > >> >> > > > * To unsubscribe from this group, send an email to:> >> > > > freedomyachts2003-unsubscribe@yahoogroups.com> >> > > > <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?> >> > > subject=Unsubscrib> >> > > > e>> >> > > >> >> > > > * Your use of Yahoo! Groups is subject to the Yahoo!> > Terms of> >> > > > Service http://docs.yahoo.com/info/terms/ .> >> > > >> >> > > >> >> > > > This email and any files
transmitted with it are> > confidential> >> > and> >> > > intended solely for the use of the individual or entity to> > whom> >> > they> >> > > are addressed. If you have received this email in error please> >> > > notify the system manager. This message contains confidential> >> > > information and is intended only for the individual named. If> > you> >> > > are not the named addressee you should not disseminate,> >> distribute> >> > > or copy this e-mail.> >> >> >> >> >> > Yahoo! Groups Links> >> >> >> >> >> >> >__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Holds up the boom (no topping lift needed) Much more powerful than a soft vang. My Garhauer has a 20:1 ratio, while most soft vangs are 4, or occasionally 5:1 ratio. This obviously facilitates sail control over a much wider range of conditions. Also, you don’t have to leave your “jacks” rigged as a topping lift.
